Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-20-2013, 10:36 PM   #676
Strodder
Daring to be Different
Strodder's Avatar
Re: Project - '69 4x4 named "Patches"
Originally Posted by sdailey View Post
The VA kit had some of the mounting bolts, for the evaporator, coming through the exterior firewall, but in keeping with the smooth firewall theme I welded some bolts to the inside of the firewall.
Like I said earlier, nothing elaborate, but progress just the same.
Good idea
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 01-20-2013, 10:44 PM   #677
greg65
greg65's Avatar
Nice work Shannon. You will be out playing in the mud before you know it.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 02-05-2013, 12:27 AM   #678
JOJABOY
I'm so jealous! Wanting to switch my 69 C20 over to 4X4......And would so love to be back in Canton. Would settle for Ball Ground. LOL
JOJABOY is offline   Reply With Quote
Old 02-08-2013, 09:03 PM   #679
RatRod68
RatRod68's Avatar
2 things...
1) Semper Fi and thanks for your service
2) Great project and of course, that MC attention to detail is outstanding
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 02-08-2013, 10:14 PM   #680
Greenlee
Greenlee's Avatar
Nice work! The truck is looking good.
Greenlee is offline   Reply With Quote
Old 03-10-2013, 11:17 PM   #681
sdailey
The Few, The Proud
sdailey's Avatar
Originally Posted by RatRod68 View Post
2 things...
Thanks for the comments everyone. I appreciate the support.
I've been trying to get back in the groove and work on the truck some more here lately.
I'm running a small cap HEI dizzy which requires an external coil. Due to clearance issues with the firewall I really didn't want to mount the coil to the engine or anywhere else in the engine bay for that matter. So after some brainstorming I came up with the idea to mount the coil inside the cab.
I found a hose clamp that would hold the coil and plug welded it to a piece of flat bar.
I found what I thought was the best place inside the cab to mount the bracket and then welded 2 bolts to the firewall. I'm not installing a radio in the factory location so the coil should have plenty of clearance.
The end result. It's kind of an optical illusion, but the top of the coil clears the firewall and the coil wire will go on with no clearance issues. Sorry for the fuzzy pictures.
I plan on running the coil wire through the firewall using the hole where the washer hoses go. I'm rerouting the washer & pump hoses so that hole works out well.
Next, I tackled mounting the hydraulic master cylinder for the clutch. I planned early on in my build to eliminate the factory mechanical linkage. After some research and reading other builds I settled on Wilwood's 3/4" bore master cylinder.
Started out by marking a template on the firewall and drilled some holes.
Next, I had to connect the master cylinder rod to the clutch pedal arm. I ended up using a 5/16 threaded yoke, a coupling nut and some 5/16" solid round rod.
I threaded both ends of the rod and then mocked up the assembly.
After I got everything lined up I marked and drilled a hole in the clutch pedal arm and installed a roll pin.
Final shot before I took it all apart again.
Shannon
sdailey is offline   Reply With Quote
Old 03-10-2013, 11:42 PM   #682
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Your doing good grasshopper!
Alan's Classic is offline   Reply With Quote
Old 03-11-2013, 12:18 AM   #683
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very nice!
Were you planning on using one of these for the coil wire?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-11-2013, 11:44 AM   #684
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Alan.
Originally Posted by 1985-GMC View Post
Very nice!
No. I'm using the factory coil wire and will run it through the firewall hole that the windshield washer and pump hoses go thru. I'll get a blank grommet and punch out the center just big enough for the wire. Basically, the coil will be on the opposite side of the firewall directly behind the distributor. See the attached picture for reference.
Shannon
Old 11-15-2013, 08:50 PM   #685
swamp rat
swamp rat's Avatar
Updates??? Been a while.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-02-2013, 09:07 PM   #686
sdailey
The Few, The Proud
sdailey's Avatar
Nothing to write about, still stock piling parts when I can. Our company is in the middle of relocating to a bigger facility and as operations mgr guess who is carrying the load. Also, my wife and I are expecting our second child, a little boy, in February. Needless to say Patches has been put on the back burner for a little while. I've been catching up on builds on here trying to get motivated again.
Shannon
Old 12-02-2013, 09:11 PM   #687
Alan's Classic
What our quality time yesterday didnt motivate you?
Old 12-02-2013, 09:49 PM   #688
4dranch
Shloooooong bed member #2
4dranch's Avatar
Shannon,
Congrats on the little one. And the new facility.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 12-02-2013, 10:04 PM   #689
sdailey
The Few, The Proud
sdailey's Avatar
It definitely helped.
Originally Posted by 4dranch View Post
Shannon,
Thanks David.
Shannon
Old 12-02-2013, 10:47 PM   #690
CUSTOM/10
CUSTOM/10's Avatar
Shannon,
I stock piled parts for 5yrs before getting back to working on my project, just saying it will always be there when the time is right !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-02-2013, 11:20 PM   #691
swamp rat
swamp rat's Avatar
Nice to know your still out there! Congrats on the new little one too.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-03-2013, 12:57 AM   #692
mud.man.rj
mud.man.rj's Avatar
Family first, then the truck for the family, congrat's.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-03-2013, 10:57 PM   #693
msgross
msgross's Avatar
Congrats, im stock piling too... Parts, not kids though!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-04-2013, 05:22 PM   #694
sdailey
The Few, The Proud
sdailey's Avatar
Originally Posted by CUSTOM/10 View Post
Shannon,
Gary
You're right Gary. That's what I keep telling myself and everyone else who asks about it.
At least it's not rusting out in a field somewhere.
Still here. Thank you sir.
Thank you. No doubt, family first.
I replied in your build thread, but I'll tell you here as well. Welcome home!!!
Is 2014 the year to complete yours?
Shannon
Old 02-27-2014, 03:30 PM   #695
my67chevytruck
Under Construction
my67chevytruck's Avatar
Shannon, hope you, and the family are doing great!!
Take care Buddy!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-27-2014, 04:05 PM   #696
swamp rat
swamp rat's Avatar
^^ Ditto that!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-28-2014, 03:21 PM   #697
msgross
msgross's Avatar
well, we are building a master suite addition this spring, then patio and then my garage gets built...
Funds will be low but at least i'll have a good man cave garage to work on it... planning a 28x34 polebarn with heat...
The Garage:
Old 03-23-2014, 03:35 PM   #698
flashed
Shannon ,I just found your build and went thru all 28 pages ,you and Alan do great work .Congrats on the new addition to your family .
flashed is offline   Reply With Quote
Old 01-03-2015, 07:33 AM   #699
Mjminino
You still around????? Your build is awesome brotha! To put it into perspective, I'm not fond of these year trucks and I read your entire build thread, it kept me engaged. Like Alan, you too, do very good explaining and I love that in a build thread!!! COME BACK.. We need more!
PS Alans thread brought me here. Saw you in multiple pictures/comments and figured I'd read yours too!
PSS Keep up that damn fine work!
Mike
Mjminino is offline   Reply With Quote
Old 02-09-2018, 03:30 PM   #700
SeventyOne
Came back to check this out - how's the build?
SeventyOne is offline   Reply With Quote
