Old 03-16-2011, 07:41 PM   #676
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks Jeramy
the part # is 2289-1HKR I got them from summit for 690 shipped to the door
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-16-2011, 10:26 PM   #677
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-16-2011, 10:30 PM   #678
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
looking great. whats the intake/aircleaner made to fit?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-16-2011, 10:41 PM   #679
flamingbig10
6.0 powered square
Re: my 80 build
thanks it fits a 99-06 gm truck with a ls motor
Aaron
Old 03-18-2011, 10:40 PM   #680
lapaipaxxx
Re: my 80 build
have you had any issues with headers?
lapaipaxxx is offline   Reply With Quote
Old 03-19-2011, 08:40 PM   #681
flamingbig10
6.0 powered square
Re: my 80 build
the fly wheel cover will require some trimming to fit, the passenger side ear on trans missions is real close and starter is close but I get some kind of heat wrap for the starter and the factory plug wires don't fit
Aaron
Old 03-21-2011, 09:47 PM   #682
lapaipaxxx
Re: my 80 build
so witch wires will you be using
thanks Jesse
Old 03-21-2011, 09:53 PM   #683
flamingbig10
6.0 powered square
Re: my 80 build
maybe msd's
Aaron
Old 03-23-2011, 10:40 PM   #684
flamingbig10
6.0 powered square
Re: my 80 build
I got the engine harness from psi and slapped it on
Aaron
Old 03-24-2011, 12:43 AM   #685
twoodson
Re: my 80 build
Aaron parden my ignorance but who is psi? Is LS a drive by wire? How much did the harness run you and how is the quality & post some pics if you can. Thanks boss and keep up the good work.
twoodson is offline   Reply With Quote
Old 03-24-2011, 09:59 PM   #686
flamingbig10
6.0 powered square
Re: my 80 build
http://www.lt1conversion.com, and yes min is drive by wire, it was a little over 700 for the harness and computer reprogrammed, I get some pics
Aaron
Old 03-24-2011, 11:40 PM   #687
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-28-2011, 11:34 PM   #688
flamingbig10
6.0 powered square
Re: my 80 build
got a little done and got a billet trans dipstick, msd wires, 15ft of 6an hose, hose clamps, starter heat shield and 02 sensors
Aaron
Old 03-29-2011, 10:54 AM   #689
twoodson
Re: my 80 build
Hell yeah, keep up the good work Aarron. I like the look of the braided hose and -am fittings.
Old 03-31-2011, 01:17 AM   #690
flamingbig10
6.0 powered square
Re: my 80 build
thanks, yes the an fitting are nice just a little hard to assemble
Aaron
Old 04-01-2011, 08:52 PM   #691
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-02-2011, 11:35 AM   #692
bark
Re: my 80 build
I see you got some plug wires on it, which ones did you end up with, how do they fit? and part #
thanks, build looks great so far, keep up the good work
bark is offline   Reply With Quote
Old 04-04-2011, 10:44 AM   #693
JohnC
JohnC's Avatar
Re: my 80 build
Coming along nicely man!
JohnC is offline   Reply With Quote
Old 04-04-2011, 08:08 PM   #694
flamingbig10
6.0 powered square
Re: my 80 build
thanks the p/n msd 32823
Aaron
Old 04-06-2011, 11:20 PM   #695
flamingbig10
6.0 powered square
Re: my 80 build
I made some mock up power steering hoses
Aaron
Old 04-11-2011, 01:00 AM   #696
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-12-2011, 12:53 AM   #697
flamingbig10
6.0 powered square
Re: my 80 build
fuel line all done
Aaron
Old 04-13-2011, 01:15 AM   #698
flamingbig10
6.0 powered square
Re: my 80 build
got some work done, finished up the fuel lines, got clamps on the radiator hoses, bypass hose for the heater hoses on the water pump, bolted down the driver side header, and put in the new spark plugs
Aaron
Old 04-13-2011, 09:35 PM   #699
flamingbig10
6.0 powered square
Re: my 80 build
was going to start my engine today got it all hooked up and went to crank it and click click so I turned the engine over by hand and tried again click click so I checked the connection at the starter and ground cable on the solenoid was loose so I tightened it and the stud snapped out of the solenoid, so I'm going with a min starter
Aaron
Old 04-16-2011, 10:09 PM   #700
flamingbig10
6.0 powered square
Re: my 80 build
its alive, it took me two days though first I had a new solenoid put on the starter, same thing the starter would engage but not turn the motor over, checked the battery it was putting out 12.8 volts, so had the starter tested at orielly auto parts, tested bad, so got a new rebuilt starter put it on same thing, so took the plugs out to see if the motor was hydro locked did the same thing, pulled the trans off to see if it was binding up look ok, then I thought I don't have a single ground on the engine so added one directly to the starter bolts to the block turned right over, then got the trans bolted back in turned right over so cranked it for a little bit to prime the oil system hooked up the ecm power primed the fuel pump and fired right up let it run for about 15 second and Idled right up but still need get a trans plug or tail shaft so I can get more the 6 qts of trans fluid with out it making a mess on the floor, put coolant in it, make power steering hoses, and hook up a oil pressure gauge
Aaron
