09-17-2009, 09:25 AM | #676 |
Next project: 1970 K10
Re: Glock's new project: "Fred"
Looks like if one were to use this compressor, price-wise it would be better to find a junk yard one. The Delco part goes for $360 (with core) at Rockauto.com, and the Delphi number is $286 (no core).
With that in mind, I think I am going to stay with the Kwik Performance high mount ($342 for brackets and compressor). On my truck, I still have issues with the tranny cooler lines between the block and AC bracket. Had I known this sooner, I could have cut the cooler lines back near the trans and ran braided line all the way up and routed them under the engine stands. If a person is just starting their swap, and not as far along as I am, this style of compressor would definitely be the ticket though! Of course, I don't plan on installing the AC until spring, so I might have a wild hair by then to re-do the tranny lines and install this one in the stock location! With me, you never know!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-17-2009, 10:43 AM | #677 |
just a thought... if someone were to go with the BRP kit for $450 they wouldnt need to get a different compressor or anything? only because the kit sits the motor higher up? it would end up almost a wash compared to buying the high mount a/c kit right?
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-17-2009, 11:04 AM | #678 |
The mount, and it's interference with the compressor and bracket, is a only one issue. The other is how and where the fittings connect to the compressor and what is in the way.
The problem with the compressor used on the 03 and up motors is that the only blocks that I can find available have threaded fittings that project straight up from the compressor body. Now, with the one Cody is using (99-02), there is a manifold available that has the threaded fittings exiting toward the rear: Manifolds for my compressor (x2): Manifold for Cory's compressor: The adapters for my compressor are about 1-3/4" tall, NOT including the 90° fitting that threads on to it, and I only have 2" from the compressor body to the under side of the frame rail for the discharge fitting. All moving the compressor up does (where my engine sits -vs- Cody's) is give me less room under the rail. At least with his compressor, he will be able to have 90° fitting that come straight up from the compressor, then loop over toward the inner wheel well, completely missing the edge of the frame rail.
09-17-2009, 11:19 AM | #679 |
Still plays with trucks
09-17-2009, 11:25 AM | #680 | |
Would the mechanical fan blade clear the top of the shroud if the engine was an inch higher or would you have to raise the shroud? |
09-17-2009, 12:06 PM | #681 | |||
So in a few months the clutch fan, shroud and stock intake tube will all be bye-bye.
09-17-2009, 04:31 PM | #682 | |
Still Learning
I could make one of these fittings for you out of 303 Stainless. I doubt it would strip as easy as the aluminum fitting. Also, I would almost bet if that part you purchased is made from 6061 Aluminum. It's readily available and it's pretty strong. Seriously, send me a drawing with the male end thread specs and I can program that part and send it to you. Not a problem we have fall off that would probably work for you. Mike |
09-17-2009, 04:44 PM | #683 |
Mike, that's awesome!! I'll get something drawn and send it to you.
09-17-2009, 05:17 PM | #684 |
Mike - PM me an email address, and I'll email you a .DXF drawing. It's not to scale, but it should give you what you need.
09-17-2009, 05:47 PM | #685 |
Hmmm, how's this? The female (top) is 3/8NPT, and the male threads are M12x1.5 and about 1/2" or so long. It is of course drilled straight through too.
It's about 1.75" tall (not including the 1/2" of male threads), and I think I used a 7/8" wrench to tighten it.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-17-2009 at 06:18 PM. |
09-17-2009, 06:05 PM | #686 |
Low & Fast!
What a cool pic. Looks sweet from the top..
09-17-2009, 06:19 PM | #687 |
Thanks Travis! Even got the spider webs in the pic!
09-17-2009, 09:09 PM | #688 |
Formerly- 1972SuperCheyenne
Man, that thing couldn't look more at home in that engine bay. Great work.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-17-2009, 09:29 PM | #689 |
Low & Fast!
Is that what that is.
09-17-2009, 09:39 PM | #690 | |
Still Learning
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 09-17-2009 at 09:42 PM. |
09-17-2009, 11:39 PM | #691 | |
Well......... I got one of the tanks installed tonight, and did a pressure test of all the fittings. 55psi with key on and no leaks! That's the good part. The bad part is I tried to fire it, and nada. I've got power to the fuel pump, power at all 3 ignition points on the fuse block, and power at the 1 battery hot point on the fuse block. I didn't really get into it beyond that, or else I may have been there all night until I found the problem! I don't have the passenger side O2 sensor yet, so nothing is plugged in there, but I don't think that would keep it from starting. So I'll finish installing the other tank tomorrow after work and then leave it until Saturday. Maybe I will be able to come up with some ideas by then. I'll probably take up residence on top the engine with a wiring diagram and a DVOM and start checking all the sensors. Now the real fun begins!!!!
09-18-2009, 09:31 AM | #692 |
I thought about this last night laying in bed. I need to check for spark of course, and that I'm getting the proper power and ground signals from the PCM to the injectors. But I feel fairly confident that the injectors are plugged. It's not uncommon at all for the injectors to plug if the engine has not been ran in a month or so, and this one has sat in my shop for a month now, and who knows how long it sat at Rancho. Plus I'm sure California puts about a million different additives in their fuel, so that's just more reason to think they are just plugged.
So if all the electrical tests check out, I'll probably pull the injectors and send them out to be ultrasonic cleaned, rebuilt and flow tested.
09-18-2009, 09:54 AM | #693 |
Bob, Right on with no leaks!! I think your on the right path w/ the trouble shooting... of all the start-up threads i have read its 1) bad ground on the electrical 2) fuel pressure not between 58-61psi? and 3) there were a few with the clogged injectors and if i remember right they just lightly tapped on each injector while firing??..
09-18-2009, 10:04 AM | #694 |
Makes me wish now that I hadn't turned them 180° so they wouldn't be visible!
09-18-2009, 10:12 AM | #695 |
i know what ya mean... if it will make you feel any better i'll put mine in turned around like yours before the 1st fire up
09-18-2009, 10:16 AM | #696 | |
After a phone call to my old drag racing buddy Dave Slatten, I found out this guy in literally right down the street from me: http://www.totalinjection.us/
And I mean literally, right down the street! I can see the shop from my parking lot here at work!! I will probably be talking to him today! Quote:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-18-2009 at 10:17 AM. |
09-18-2009, 11:27 AM | #697 | |
Future: 86 on GenIV power!
09-18-2009, 11:34 AM | #698 |
True, but my experience with VATS is that it will start, but die shortly after.
Short of checking spark and power/ground to the injectors, I am leaning towards stuck injectors.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-18-2009 at 11:35 AM. |
09-18-2009, 12:07 PM | #699 |
I have car A.D.D.
Bob, I love the overhead shot. Glad to hear the preasure test went well. Now, ge the rest figured out. Way to go man!
By the way, I don't remember seeing anything about a driveshaft? Did the original one still fit or did you have one built, or did I just miss that all together?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 09-18-2009 at 12:11 PM. Reason: BTW |
09-18-2009, 12:11 PM | #700 | |
Where the small metric male threads transition to the hex stock put a 1/4" fillet radius there. It will increase the strength of the part tremendously. It doesn't need to be that long either. Less length will put less load on the threads if you accidentally lean against it while working on the truck. It would suck to snap that thing off flush with the head. The closer you can get the sensor to the head the better. If you can make it out of brass or aluminum bronze that would be much better too. The stainless will need antisieze compound on it to keep from galling the threads and getting stuck in the head plus the galvanic corrosion from the dissimilar metals will cause the aluminum head to oxidize around the fitting possibly causing it to leak down the road. Aluminum bronze or brass will only need Teflon tape as they are much closer to aluminum in the dissimilar metals range chart. You could make it out of round stock and just put a set of wrenching flats on it to use more common scrap material. If you did strip out the threads on the head you can always tap the head for the 3/8" pipe threads of the sensor and be done with the adapter. Just put some grease on the tap drill and on the tap and they will collect the shavings so they don't go into the water passage. |
