Old 12-10-2009, 02:51 AM   #1
smokedat
smokedat's Avatar
LS1 into a 73 cheyenne
I'm in the process of doing a swap. Ls1 from a 98 Camaro into a 1973 Chevy truck s/wheelbase.
Engine: LS1 from 98 Camaro, modified with LS6 heads, LS6 intake manifold, 5 pin mass air flow, twin horn air intake. comp cams kit LSR 281-289 113. Headers from Street & Performance. Taylor 10.4mm ignition wires. Full set of billet pullys
No heater or A/C unit
Transmition: 4L60E
ford 9"
Strage center section with 4.11 gears
Rear suspension : 4 link from ridetech with ridetech adj. coilovers
Exhaust: dual, headers from Street & Performance 2 1/2" collectors, Hooker aero chamber mufflers, on 2 1/2" pipes, stainless tips from Cherry Bomb
Radiator: Griffin aluminum with trans cooler, in/out water lines on passenger side. Trans cooler lines on driver side.
Gas Tank: I will be running only 1 16 gallon tank from a 87 with in tank fuel pump, reason for upgrade is for the in tank baffles so the engine wont starv.
Gauges: Autometer
Harness: stock harness and computer, modified harness and re-tuned computer
Brakes:2010 C6 Corvette style front- 14" 6 piston rear-13.5" 4 piston - master cylinder from Wilwood note: may encounter vaccum issues due to cam and massive breaks, if so i will run an electric vaccum canister
More to follow.....
smokedat is offline   Reply With Quote
73c10, c10, cheyenne, ls1, swap
