Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-03-2018, 10:27 AM   #676
UATahoe
Re: D52 Caliper Rear Disc Brake Brackets
Will be sending over funds for my brackets today. Thanks!
UATahoe is offline   Reply With Quote
Old 05-03-2018, 11:41 PM   #677
Captainfab
60-66 Nut
I have not received a payment from you today. Are you sure you sent it to the correct email address?
Old 05-04-2018, 09:48 AM   #678
UATahoe
Sorry Cap, got tied up with work yesterday and forgot to send. Sending it now. Thanks!
Old 05-04-2018, 12:26 PM   #679
UATahoe
Should see the payment now. Thanks again Cap! Hope to actually get these on this time. LOL
Old 05-05-2018, 01:17 AM   #680
Captainfab
60-66 Nut
Payment received. I will get a set over to the powder coaters on Monday.
Old 05-05-2018, 10:30 PM   #681
Jreedsac
I sent you a PM Captainfab
Jreedsac is offline   Reply With Quote
Old 05-06-2018, 12:03 AM   #682
Captainfab
60-66 Nut
I replied to your PM.
Old 05-07-2018, 10:38 PM   #683
Jreedsac
Check your PM. I need your address!
Old 05-07-2018, 11:20 PM   #684
Captainfab
60-66 Nut
Please be patient. I work 80hrs/7 days a week every week every month. I only have time to log onto this forum after I get home from my day of work. I replied to your PM.
Old 06-23-2018, 10:52 PM   #685
Tash4
Tash4's Avatar
I'm interested in a set of brackets for a 10 bolt out of a 87 r10. What do you need to know ?
Tash4 is offline   Reply With Quote
Old 06-23-2018, 10:59 PM   #686
Captainfab
60-66 Nut
To place an order you just need to make the payment. I will send you a PM.
Old 07-06-2018, 01:22 PM   #687
Tash4
Tash4's Avatar
Received parts , they are well made & fit perfect. Thanks
Old 07-07-2018, 12:21 AM   #688
Captainfab
60-66 Nut
Thanks for the compliments
Old 08-29-2018, 07:22 PM   #689
Beardedwon
PM sent for some rear disc brackets
Beardedwon is offline   Reply With Quote
Old 08-29-2018, 11:44 PM   #690
Captainfab
60-66 Nut
I replied to both of your PM's........
Old 08-29-2018, 11:47 PM   #691
Beardedwon
Back at ya for PayPal. Thank you sir!
Old 10-01-2018, 06:28 PM   #692
M.A.C.'sFAB
I'm currently working on converting my rear to disc on my '70. Can these brackets also be used when keeping the 6 lug pattern?
Planned on using 1990 K1500 w/ f44 (heavy duty) chassis 6 lug rotors (11.6 dia. and 1.29 thick) and using 71-72 front calipers in the rear. Any foreseen issues I may have? Besides some possible machining...
M.A.C.'sFAB is offline   Reply With Quote
Old 10-02-2018, 12:14 AM   #693
Captainfab
60-66 Nut
You can not just randomly change the rotor and still have the rotor and caliper line up. I have yet to find any two factory replacement rotors for different applications be exactly the same and interchangeable. I have no idea what the height is of the rotor you are wanting to use. Then there is the issue that most later model rotors do not have sufficient contact area to accommodate the D52 pads without having them hang over the outside edge.
You know that I do make 2 rear disc brackets for the 6 lug correct?
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
http://www.67-72chevytrucks.com/vboa...d.php?t=494411
Old 10-02-2018, 12:10 PM   #694
M.A.C.'sFAB
Right, I do know that. The rotor overall height is 2.6"
My intention is to keep the front brakes the same as the rear, by using the same caliper. They have a larger piston then most and are cheap to replace.
I was just wondering if you had a set of brackets that would work for my app?
Old 10-02-2018, 11:56 PM   #695
Captainfab
60-66 Nut
The Astro/Safari rotors are 3.27" tall. That is a difference of .670. I don't know if a .625" thick spacer would work. It might require a .750" thick spacer machined down to .670". It seems like I tried to use the F44 rotor when I developed my 6 lug kits, but I couldn't get the D52 pads to fit, like I mentioned previously. I would have to go back and look.
Old 10-04-2018, 09:50 AM   #696
M.A.C.'sFAB
Any info that you could give me on that set-up would be greatly appreciated.
Old 10-05-2018, 12:52 AM   #697
Captainfab
60-66 Nut
I didn't have time today to pull a rotor out of the box and again check fitment of the D52 pads. Will try again tomorrow.
Old 10-05-2018, 11:16 PM   #698
Captainfab
60-66 Nut
Here is proof of what I was saying about the 580438R/F44 rotor's contact surface not being wide enough for the D52 pads.
Old 10-06-2018, 07:54 PM   #699
M.A.C.'sFAB
I see what you mean.... How much is a set of your brackets for a 6 lug rotor with Cadillac/Camaro calipers? I seen it listed for 177 plus shipping?
I was planning on using 10/12 bolt rear dust shields (knowing I will have to change the bolt pattern), will those shields be able to be sandwiched in between your brackets still clear the rotor and caliper? I ask because they already have a cutout section at a specific angle already and was wondering if that angle is close to the angle of your brackets?
Old 10-06-2018, 11:15 PM   #700
Captainfab
60-66 Nut
The prices for all of my products are Exactly the same as in post #1 of each for sale thread just as it says in bold text. Both of the 6 lug brackets are $177.50 plus $13.65 for shipping.
I have never in 40+ years of working on Chevy's seen a truck 12 bolt with disc brakes from the factory. The only 10 bolts with disc brakes are the '88+ 8.5" & 8.6" 10 bolts. I did not use any dust shield when designing any of my rear disc brackets. I have no idea if any factory dust shield will work. Additionally adding any thickness of metal in between the brackets and spacers will alter the alignment of the caliper with the rotor.
