Old 03-21-2018, 02:18 PM   #676
69BUCKET
Re: LS swappers, post up your pics!!
Getting there...
69BUCKET is offline   Reply With Quote
Old 03-21-2018, 10:54 PM   #677
brownge
Not sure what you're asking. I bought the hydroboost unit from O'Reilly. I think it was a refurbed Astro van unit from early 90's. It is mounted upside down so the lines go to the bottom.
brownge is offline   Reply With Quote
Old 04-01-2018, 10:59 PM   #678
60apache
60apache's Avatar
where did you get your brackets to mount it?
60apache is offline   Reply With Quote
Old 04-02-2018, 09:20 PM   #679
brownge
I bought those from another board member - Captainfab. He does great work. I bought the power booster bracket and hydroboost mounting plate.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
http://www.67-72chevytrucks.com/vboa...d.php?t=347480
Old 04-06-2018, 10:30 PM   #680
jessemthompson
Since my swap thread lost all its pics
jessemthompson is offline   Reply With Quote
Old 04-07-2018, 02:00 AM   #681
z71se
Really really nice. Love the L92 engine cover, no unnecessary wires, and the Chevy orange. I plan to do mine similarly. Thanks for the ideas!
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 04-08-2018, 04:51 PM   #682
1slowM6
Originally Posted by 69restomod View Post
My turbo 6.0 4l80 combo work in progress!
Did you have to run a high hump or anything to run the 80e?
1slowM6 is offline   Reply With Quote
Old 04-08-2018, 04:54 PM   #683
1slowM6
Originally Posted by Captainab View Post
New truck harness and holleys dominator system
What kit did you buy for the fuel system?i have only been able to find the setup with the fpr that only goes to 15psi
Old 04-23-2018, 06:10 PM   #684
Ghost's68
Ghost's68's Avatar
As it sits right now.....
Ghost's68 is offline   Reply With Quote
Old 04-23-2018, 06:56 PM   #685
332rick
332rick's Avatar
Progress update on my swap!
332rick is offline   Reply With Quote
Old 06-26-2018, 10:45 AM   #686
Reed123
Reed123's Avatar
2006 6.0 w/ 4L80E trans putting in my 1971 SWB C-10
Reed123 is offline   Reply With Quote
Old 06-28-2018, 05:32 PM   #687
RockhoundII
My work in progress. 2002 lq4 into a 79 Blazer. Still have a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=765788
RockhoundII is offline   Reply With Quote
Old 08-03-2018, 01:15 PM   #688
doug_p
doug_p's Avatar
62 LBFS LQ4/4L80E, with torsion bars still in place-
doug_p is offline   Reply With Quote
Old 08-03-2018, 01:22 PM   #689
doug_p
doug_p's Avatar
Hey 67chevySupercharged, what kind of mods were required on the headers with the 4l80? I read somewhere with the 4l80, the Doug Thorley headers needed some grinding?
Thanks-
Doug
Old 08-04-2018, 08:21 AM   #690
davecarney2
davecarney2's Avatar
Here's mine as it sits right now. 2003 6.0. 4L80E. Where's everyone getting their trans cooler lines and power steering lines and fittings. I'm running a mustang power rack and my radiator has a built in trans cooler
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
http://67-72chevytrucks.com/vboard/s...d.php?t=592878
davecarney2 is offline   Reply With Quote
Old 08-04-2018, 08:33 AM   #691
davecarney2
Originally Posted by Mjminino View Post
Just added AC, and recently added rack and pinion.
Looks like were running the same rack anemic pinion. Where did you get your power steering lines?
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 08-04-2018, 08:38 AM   #692
doug_p
doug_p's Avatar
I had the pressure side line made locally at a hydraulic hose supply house. The return line I just used what was existing (truck had ps when I bought it).
DP
Old 08-05-2018, 09:13 PM   #693
bears_den_customs
bears_den_customs's Avatar
just finish my 5.3 swap in my 72 c10. Just getting started on my engine coverName:  IMG-1597108167.jpg
bears_den_customs is offline   Reply With Quote
Old 08-05-2018, 09:22 PM   #694
bears_den_customs
my 4.8 swapped 50 suburban.Name:  1950-chevy-3100-suburban-engine.jpg
Old 08-06-2018, 04:02 PM   #695
Root2812
Root2812's Avatar
Originally Posted by bears_den_customs View Post
my 4.8 swapped 50 suburban.Attachment 1808711
That looks great! What did you do for steering column and linkage? Did you recess the firewall at all? I'd love to see a few pictures of your steering linkage and radiator fan and shroud.
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 08-06-2018, 05:19 PM   #696
verdell
verdell's Avatar
Which engine mounts did you use?
verdell is offline   Reply With Quote
Old 08-06-2018, 07:06 PM   #697
bears_den_customs
here some pics 77 gm van column. 71 camaro clipped and no i didin't recess the firewall
Old 08-31-2018, 10:49 AM   #698
jrusher
Just finished mine up , little more tuning left to do Glad to be driving it again I started ls swap in April but ended up pulling cab and replacing floor and repaired all other rusted areas.
jrusher is offline   Reply With Quote
Old 09-04-2018, 12:17 PM   #699
1971Stepside
Almost Satisfied
1971Stepside's Avatar
So far to go, but excited about the progress.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 09-14-2018, 09:48 AM   #700
DaHos
DaHos's Avatar
She's DONE !!!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
