05-23-2015, 09:02 AM | #676 |
Re: Project Roxy
It's at ride height and set a 6 degrees down. When I first installed the dropmember the oil pan hit the rack, so Nate made some engine plates to raise the motor 1/2". There is about 1/16th" between them now. I thought about beating the area of the cab with a hammer to make room. But not sure if that's the best option.
Posted via Mobile Device |
05-27-2015, 09:21 AM | #677 | |
Re: Project Roxy
I sent a bunch of emails to Nate regarding the issue. However, with the holiday weekend and new stuff he's building I figured he is busy. My fix for the steering rack/motor issues is that I ordered some Steeda offset bushings .25 and .40. I'm hoping to lower the rack .40 and the motor 1/4" to solve my issue of the trans yoke hitting the cab.
///Relaxed Atmosphere |
06-25-2015, 10:38 PM | #678 |
Re: Project Roxy
Does anyone see anything wrong with this. Not sure with the lines above the m/c outlet if that would cause no pedal pressure
06-28-2015, 10:04 AM | #679 |
Re: Project Roxy
I would change both of those lines. The line on the left looks like it's crimped really bad by the fitting. I would make sure they both go straight down. If you are going to loop them, loop them on a horizontal plain, not a vertical one like they are now. Here's what mine look like.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-28-2015 at 10:14 AM. |
06-28-2015, 10:42 AM | #680 |
Re: Project Roxy
I don't see anything that would prevent pedal pressure there but the line on the left does looked kinked a bit.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
06-28-2015, 07:52 PM | #681 |
Re: Project Roxy
Thanks for the advice guys
06-28-2015, 08:44 PM | #682 |
67-72 parts collector,…
Re: Project Roxy
With the way your prop valve is mounted,... Two "U-shaped" bends would work perfectly,... From the M/C.
06-28-2015, 10:39 PM | #683 |
Re: Project Roxy
The slosh tubs make it difficult to make the lines come out very far.
I adjusted the length of the parking brake cable and let the rear parking brake adjust itself by setting and releasing the brake. My wife helped me bleed the brakes and they seem to be ok now.
09-22-2015, 11:46 AM | #684 |
A guy with a truck
Re: Project Roxy
What's happening lately with Roxy? All your pics are gone...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-10-2016, 08:26 PM | #685 |
Re: Project Roxy
I deleted them for whatever reason I was thinking at the time. I should update a few.
02-10-2016, 08:36 PM | #686 |
Re: Project Roxy
02-10-2016, 08:37 PM | #687 |
Re: Project Roxy
02-10-2016, 08:38 PM | #688 |
Re: Project Roxy
02-10-2016, 08:39 PM | #689 |
Re: Project Roxy
02-10-2016, 08:40 PM | #690 |
Re: Project Roxy
looks good!!!^^^
02-10-2016, 10:22 PM | #691 |
Re: Project Roxy
Roxy looks great!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-10-2016, 11:39 PM | #692 |
Re: Project Roxy
Killer truck, I've been looking through a lot of builds on here this winter and can't believe all of them I've missed out on!!!
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
02-11-2016, 12:50 PM | #693 |
Re: Project Roxy
Where'd you get the speaker pods? Likey?
02-11-2016, 01:50 PM | #694 |
Re: Project Roxy
02-13-2016, 08:06 PM | #695 |
Re: Project Roxy
02-13-2016, 08:14 PM | #696 |
Re: Project Roxy
Nice work!!!
02-13-2016, 10:36 PM | #697 |
Re: Project Roxy
What color is truck. Maker of paint?
02-13-2016, 11:02 PM | #698 |
Re: Project Roxy
Maroon poly. Basf/RM
02-14-2016, 12:01 AM | #699 |
Re: Project Roxy
Okay, thanks. I want to paint mine some shade of burgundy .
02-14-2016, 10:23 AM | #700 |
Re: Project Roxy
I had sticker shock when I bought it.. The base was $1400 a gallon and the clear was $400 (needed 2 gallons of clear). All said in done, I had roughly $2500 in materials alone.
