07-20-2014, 10:46 AM | #676 |
Re: Brave or crazy? crewcab build
Also got the speaker hole in the door all filled in
check out my crew cab build http://67-72chevytrucks.com/vboard/s...d.php?t=557019 |
07-20-2014, 09:10 PM | #677 |
I had to do the same thing on my truck. someone had two holes in mine but the work was a good in the end.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
07-21-2014, 09:17 PM | #678 |
Yesterday I finished up the upper door channel and fixed the drip rail.
Drip rail was way off it was not right from the factory it was too high in the front then sloped down towards the rear. It did not match up at all,but with a little work I got it all straightened out. I marked it in the pics to show how off it was.
07-21-2014, 10:55 PM | #679 |
This is one of my favorite builds because I know every time I check it out I'm going to see some fabrication going on, great stuff.
07-22-2014, 07:08 AM | #680 |
Im with you Xeen, I love seeing each project he works on and the amazing progress he makes with each step! Killer work!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
07-22-2014, 08:25 AM | #681 |
Still Learning
Great work on the drip rail. Keep on hammering!
07-22-2014, 10:21 PM | #682 | ||
I feel like I am finally over the hump on the conversion part of the build. But there is still a long way to go!
07-22-2014, 10:27 PM | #683 |
I did find some time after work today to strip the 3rd door to bare metal.
Hopefully I can get some epoxy on it this weekend.
07-27-2014, 09:02 PM | #684 |
Finally the last peice of rust is gone from this truck the passenger side floor board was baddly pitted from the under dash ac. I bought a counter parts patch panel and I am less then impressed with it, but its better then the current floor. I got it all cut out and the new section tacked in but ran out of time before I could finish it up.
07-28-2014, 01:20 AM | #685 |
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
07-28-2014, 08:34 PM | #686 |
Totally dig how you went about truing up your door gaping issues.
Using that info on mine. Thanks |
07-28-2014, 08:36 PM | #687 |
Cool sub, looks good!
07-28-2014, 08:41 PM | #688 |
I got the idea from somebody here on the site it worked out really well.
07-28-2014, 09:05 PM | #689 |
Here's what is left from the 3 trucks i parted out this year
07-29-2014, 01:46 AM | #690 |
just finished looking in. you have done a great job and look forward to more
07-29-2014, 09:18 PM | #691 |
Looks like enough to start another!
07-30-2014, 12:20 AM | #692 |
Finished up the floor patch today
07-30-2014, 03:25 PM | #693 |
6>8 Plugless........
Nice work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-30-2014, 11:30 PM | #694 |
Love this build!
I've been enjoying checking on this over the last few months, you do great work. |
07-31-2014, 09:34 AM | #695 |
SWB 4x4 Collector
Project is coming along nicely. Wish I was over the crew fabrication hump already. Mine has involved both rust repair and fabrication, so you got it made lol. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
07-31-2014, 11:15 AM | #696 | ||
I also did alot of rust repair i'm just past all of that. I checked out your build it's lookin good!
07-31-2014, 02:55 PM | #697 |
Just found your build today, read all the way through awesome job, cant wait to see it finished.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
08-01-2014, 09:22 PM | #698 |
Started working on the firewall welding up all the holes I don't need.
I have a old air unit I am going to install but I don't want to use the outer block off plate so I am working on a way to mount it without seeing any bolts or nuts.
08-01-2014, 10:13 PM | #699 |
Soon you will be all done with the cab and you will start to see the light at the end of the tunnel.
You are almost to the fun (and the expensive) part of the build. The cool part is depending on who you talk to the cab alone is now worth anywhere between 5 and 10 grand just as it sits. Last edited by Xeen; 08-01-2014 at 10:21 PM. |
08-02-2014, 09:05 PM | #700 | |
stuff like sanding and priming. I am glad to be moving on to a different part of the build.
