06-12-2018, 10:41 AM | #676 |
Re: What did you do to your truck today part IV
This fiberglass dash for 60-66 C10 was purchased from US Body Source. Around $300 bucks plus shipping of $150. Took 8 weeks to receive it and comes very very rough. It needed a lot of work fitting and smoothing to get ready for paint. When it is all done I think it will be awesome, but if I had to do again for the price and work, probably not. Probably just weld on the original.
06-16-2018, 12:58 AM | #677 |
Installed the mid shift kit on the tremec this evening. Now the shifter won't be under the cab floor anymore.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-16-2018, 11:58 PM | #678 |
Got the trans installed and both inner fenders painted.
06-18-2018, 08:08 AM | #679 |
Had my front fender, hood, grill, bumper and headlight straightened. First time I've ever seen one of these awesome machines work. It was fun watching a pro work and move it all back to its proper place, or at least close enough.
06-18-2018, 10:08 AM | #680 |
Getting closer and closer...
06-20-2018, 12:50 AM | #681 |
Finished up the bed last weekend, new headache rack, mud flaps and painted with POR-15, installed toolbox. One headlight was held in with the bezel, broken headlamp adjusters and rivots broke between grill and mounting bracket. Time to put used grill on I had bought. Finished that tonight.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
06-22-2018, 09:36 PM | #682 |
Today I wired up the electric choke, and added on a little somethin that my buddy found when someone dropped of a donation to his dad's ministry. Maybe tomorrow Frankentruck will come to life again?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-25-2018, 02:32 AM | #683 |
Active Member
stick on CHEVROLET
06-28-2018, 12:03 AM | #684 |
Got more done this past weekend. The steering was jacked up because of the lower bearing in the steering column was worn out. It was one of the original bearings without sides or grease in it. We replaced it with one of the good, heavy duty bearings that should last a long time. We did have to weld on the steering shaft to fill in where the bad bearing had ground a groove in the shaft and then grind it smooth of course. Now the steering feels nice and tight without any slop. Along with that, we cut off the gear selector mounting lug and, removed the gear indicator, filled up the holes with bondo, sanded and painted it to make it a floor shift steering column. Then, we fitted a sheet metal patch that I purchased from LMC, in the hole on the left side of the cab where the old fuel filler was located. After grinding it down, putting on some bondo, sanding that down, we slapped on a couple coats of good primer. Next weekend, we're gonna finish the exhaust. Amoung the things left to do is, installing a tach, installing a horn, lining up the body panels and, doing a little touch up painting. I'm not going to do a full new paint job. Besides not having the money for that, I'd rather it have a rat rod type paint job. It's gettin there!!
06-30-2018, 01:45 PM | #685 |
[attach][/attach]
Assembled front end |
07-01-2018, 12:28 AM | #686 |
Did a little more work on my guage cluster today. The little bow ties have chrome behind them and the bezel is going to be chrome.
07-03-2018, 05:57 PM | #687 |
mocked up the firewall,
07-04-2018, 08:35 AM | #688 |
I see you have the Clifford intake and headers. Did you do anything to the motor, ie cam head ect. or is it stock?
07-04-2018, 12:18 PM | #689 |
Moderator
I dont have a clifford intake...
07-04-2018, 12:19 PM | #690 | |
07-04-2018, 04:49 PM | #691 |
Revitalizing a 6T C10
CLR and red scotchbright by Keith, on Flickrtried the CLR and scotchbright thingy :
CLR and red scotchbright by Keith, on Flickr CLR and red scotchbright by Keith, on Flickr worked like a charm |
07-04-2018, 08:37 PM | #692 |
07-04-2018, 10:06 PM | #693 |
hillbilly
Epoxy primed my inner fenders
-1962 C-10 |
07-05-2018, 05:36 AM | #694 |
Had 4 cars come to the Car Care Barn in need of help so front brakes and the axle install is all I got done this weekend.[ATTACH][/ATTACH]
07-07-2018, 05:54 PM | #695 |
great thread!
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-07-2018, 09:00 PM | #696 |
1965 Chevy C10, 2005 4.8L/4l60
A little sound/heat shield!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
07-08-2018, 02:32 PM | #697 |
It's Better With Nitro
Windshield is in and bed back on...
07-09-2018, 02:47 PM | #698 |
I like the wheel so far, going from a stock custom wheel to this, should be rather different. Haven't had to chance to drive it yet, but give me a few weeks.
07-09-2018, 03:00 PM | #699 |
07-09-2018, 05:50 PM | #700 |
Thanks! I used Precision glass seals throughout, including the front windshield (back glass, vent windows, door channels, etc.). It took me a couple of hours with the help of a friend. I've had really good luck with Precision on the curved glass applications. I had good experiences with Steele on flat glass windshields in the past when they were the only premium seal maker around...not so much on the curved windshields recently.
