Old 03-03-2025, 01:05 AM   #676
washington blue
Re: norms 55 chevy pu build
Time for some LED headlights, spendy little buggers.
After that i decided to hook up some wires to the front lights.
Pleasant way to spend a Sunday, in a warm shop with country music.
washington blue is offline   Reply With Quote
Old 03-03-2025, 08:45 AM   #677
8man
Nice, productive day!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-03-2025, 11:54 AM   #678
57FleetsideC4
Moving right along. I like productive days. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-04-2025, 01:24 PM   #679
washington blue
I have 2 systems. PSI harness for the engine and Painless for the rest, lights radio etc.
Since the PSI has everything on the engine covered I'm thinking I won't use several wires from the Painless harness. they include:
electric choke.
regulator exiciter.
alt. regulator - - PSI has wires that plug into the alt.
coil + ignition- hot - LS has 8 coils all plugged into PSI
temp sender - PSI has a plug into the temp sensor
tachometer to coil.
oil sender - Dakota Digital has a seperate oil sensor and wires.
cooling fan relay - PSI has a wire for that relay and the other is to switched hot
I'm thinking I won't use these wires, thoughts?
Old 03-06-2025, 12:12 AM   #680
washington blue
sorted some wires for the Headlight switch today.
Old 03-06-2025, 02:13 AM   #681
caseyjones
I’m planning to use the ignition coil power as the switched ignition to my EFI computer on my truck. Electric choke feed could be repurposed as an accessory ignition feed.
caseyjones is offline   Reply With Quote
Old 03-06-2025, 10:54 AM   #682
washington blue
Smile Re: norms 55 chevy pu build
Wow, thanks CaseyJones, that's a great idea. I've been wondering what would be a good switched source for the relay triggers. I think I shall do that too.
I spoke to a speed shop/ tuner person, and he agrees I will not use the 8 wires I have listed so re-purposing them will work.
Old 03-17-2025, 11:33 PM   #683
washington blue
some random wiring pictures, slow but going forward with it.
Old 03-17-2025, 11:34 PM   #684
dsraven
Slow hut sure gets it done. Do it right the first time takes time. Looking good.
Old 03-18-2025, 09:46 AM   #685
8man
Wiring means you are getting close to driving it. Keep at it.
8man-aka Robert
Old 03-18-2025, 11:27 AM   #686
youngrodder
youngrodder's Avatar
Wiring (to do correctly) can be a real time thief. It seems to take 4x longer than it should.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-18-2025, 05:21 PM   #687
washington blue
It certainly is taking me a long time for sure.
Old 03-22-2025, 10:11 AM   #688
washington blue
Still plodding along with wires. Got my horns wired and made a mount for them.
Been reading my books so much I've got them half memorized, lol.
I'm thinking I have the neutral safety/reverse light switch and the Dakota digital gear indicator to do. Both are on the transmission in the same area, and I have the wires run there, so just hookup to the switch is left to do, and mount the Dakota indicator.
after that I have the Vintage air wires and the radio left, at least I think so.
Old 03-26-2025, 01:39 AM   #689
washington blue
Been working on the neutral safety and reverse lights. Also the Dakota Digital gear indicator. Still have a little to do.
Stuff looks closer to the exhaust than it is, about 2 inches away.
Old 03-26-2025, 10:46 AM   #690
dsraven
looking good. gonna be driving soon.
I kmow you have 2 inches between your exhaust pipe and the electrical stuff but it wouldn't take much to fab up an L shaped sheet metal heat guard that could be screwed onto the trans pan bolts to keep from having an issue. you could use studs in place of a couple of the bolts to make life easier. if you found a couple of studs with the nut in the middle you could install them in place of a couple of the original bolts then a flat washer, then the guard, another flat and finally a locknut. the pan bolts are M8-1.25 and 16mm length. here is a link to a stud that is a stock GM number just to what I mean for a stud or flange bolt or whatever they are actually called. lol
https://www.ebay.com/itm/332785338193
Old 03-26-2025, 01:29 PM   #691
washington blue
I've been wondering about some kind of shield for heat. What about exhaust wrap? Say for about 16 inches or so.
Old 03-26-2025, 07:43 PM   #692
washington blue
Thinking about using some of this stuff. I have enough left I can even double it up for a 1/2 inch thick layer. 1/4 is supposed to stop 70% of heat radiating, so 2 layers should do it.
I've spent quite a bit of time looking at this heat barrier and I think if I double it, and I have just enough to do that, then wrap the 2 layers 65% of the way around which leaves the opposite side to breathe, it ought to be good.
Old 03-27-2025, 10:49 AM   #693
dsraven
That may do the job. It will bring the pipe closer to the trans and electrical though. I always try to think if it from a service standpoint and find a removable heat shield easier to work with than something more permanent. It's your truck though so you gotta do what suits you. The trans switch and wiring probably won't need much service once it's up and running and proven. The shifter itself should also be fine once up and running and having found its happy place after everything bodywise has shifted around and settled. Servicing the trans should be straight forward enough because the pan drops straight down. Personally, I just like space around things that's all.
There is also heat shielding wrap available for items like wiring.
Old 03-28-2025, 01:04 AM   #694
washington blue
Finished the neutral safety, reverse lights, gear indicator area.
Old 03-31-2025, 10:43 PM   #695
washington blue
Got started putting in the radio and some floor insulation
Old 04-06-2025, 10:36 PM   #696
washington blue
Still tidying up some wiring stuff. Got the engine compartment wrapped up, lol.
Old 04-10-2025, 09:20 AM   #697
washington blue
104 bolts later and poof, instant box. I still have to hang some of the exhaust back and heat shields, raise up the gas tank and tighten some nuts yet.
Old 04-10-2025, 10:00 AM   #698
8man
That looks good!
8man-aka Robert
Old 04-11-2025, 09:03 AM   #699
57FleetsideC4
Looks awesome!!
Old 04-18-2025, 10:32 AM   #700
washington blue
Got the front bumper on and the steering wheel too.
