Closed Thread
Old 02-15-2013, 02:04 PM   #6976
Trsmotrhed
Trsmotrhed's Avatar
Re: What did you do to your truck today?
Got some Silverado seatsfor my truck and some 18" Cragar rims. I'll post pics when installed.
Finally figured out how to post pictures from mobile phone.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 02-15-2013, 02:06 PM   #6977
88Lt1wagon
Originally Posted by Trsmotrhed View Post
Got some Silverado seatsfor my truck. I'll post pics when in.
I'm jealous, those are high on my list of needs because I don't have seatbelts which means I can't take my son in the pickup which means it doesn't get driven.
-Jason
'66 C10 LWB 2 BBL 283 w/ T-5
'90 V1500 Suburban TBI 350 w/ 700R4
88Lt1wagon is offline
Old 02-15-2013, 02:26 PM   #6978
Trsmotrhed
Trsmotrhed's Avatar
Lt88 wagon, sent you a PM.
You can have my seat belts from my truck. PM if you want them.
63 SWB C10
Old 02-15-2013, 03:28 PM   #6979
dantimdad
dantimdad's Avatar
Picked up motor mounts and paint for engine today.
Going to bolt in drive train this weekend. Then, it's on to gas tank, flatbed and patch panels.
I can finally feel it coming together!
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 02-15-2013, 09:33 PM   #6980
gimmy 64
Originally Posted by jbgroby View Post
Steven, Best tool I ever bought, although "I" did not use it, the guys in the pics used the tool at $25.00 per hr. to get the dents out. BTW the cab went under 12 feet of water. BUT if you get the harbor freight like I did, you will replace the vicegrip tool quick.
what tool for the puller did you replace with. i have the harbor frieght stud welder and it seems to onley work with the big studs
gimmy 64 is offline
Old 02-15-2013, 10:06 PM   #6981
jbgroby
jbgroby's Avatar
What we did was go to a hock shop and buy a heavy duty made in the USA vicegrip and put it on the slide hammer. then migged welded it secure. worked great.
jbgroby is offline
Old 02-16-2013, 12:04 AM   #6982
Trsmotrhed
Trsmotrhed's Avatar
I bought a harbor freight stud gun and the studs you get there didn't work good for me. I had read to get some studs from a body supply place. I Did and work so much better than harbor freights.
63 SWB C10
Old 02-16-2013, 07:55 AM   #6983
Hx16457
Hx16457's Avatar
Seats look great, I have the same set with power! I hope your not a tall person though, they will not go back far enough for taller people! I'm only 5'-3" so they work great for me!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline
Old 02-16-2013, 12:25 PM   #6984
Trsmotrhed
Trsmotrhed's Avatar
Oh no, I'm 6'5". Guess I'll try them today and if they don't fit I'll put em up on Graigslist.I sure hope I fit. Thanks for the heads up.
63 SWB C10
Old 02-16-2013, 02:51 PM   #6985
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Finished pulling my 556 HP factory Supercharged LSA and 6 speed automatic for my project Low and Go....So far so Good
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 02-16-2013, 02:53 PM   #6986
wutnxt
Well the picture didn't load so I wll try again....
wutnxt is offline
Old 02-16-2013, 03:06 PM   #6987
Trsmotrhed
Trsmotrhed's Avatar
Smile Re: What did you do to your truck today?
Trial fit for the seats to see if I'd fit. I'm 6'5" and a little less room than the stock seat but not bad. I can see a tilt wheel in my future.
63 SWB C10
Old 02-16-2013, 06:46 PM   #6988
Hx16457
Hx16457's Avatar
Lol see I told you, u must be sitting straight up. If u get a custom steering wheel, 13" it will help too! My boss is 6' and his truck came with these seats....
"I just sold him my OEM bench seat" because of this space issue! Be sure you can live with them before you mount-um, just saying...
Hx16457 is offline
Old 02-16-2013, 06:49 PM   #6989
Hx16457
Hx16457's Avatar
Oh & today I started prep 700r4 for install, also Put in a new flexplate.
The r4 will need the speedo changed to mech. and the tc lock up kit is on its way!
Hx16457 is offline
Old 02-16-2013, 07:51 PM   #6990
wutnxt
Wicked stripe.......you did a great job on that
wutnxt is offline
Old 02-16-2013, 10:48 PM   #6991
Trsmotrhed
Trsmotrhed's Avatar
I just went for a test ride before I mount the front bolts. I can see a tilt wheel in my future and it wasn't that bad. Was very comfy.
63 SWB C10
Old 02-16-2013, 10:49 PM   #6992
akaupp
Today I picked up and installed the new master cylinder, bought and installed a tow hook rated at 10,000 pounds, installed 3/8" eye bolts in the stake pockets for tie downs and started cleaning up the step bumper I got for it.
akaupp is offline
Old 02-17-2013, 12:00 AM   #6993
Trsmotrhed
Trsmotrhed's Avatar
Got my new CPP 4" drop coils. Much nicer ride than stock springs.
63 SWB C10
Old 02-17-2013, 12:46 AM   #6994
hemifalcon
Man!!!! Those are some whimpy looking springs!!!
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 02-17-2013, 01:04 AM   #6995
Trsmotrhed
Trsmotrhed's Avatar
I think the ones I had were from a heavy half ton from a 72. Sure rides much better now.
63 SWB C10
Old 02-17-2013, 01:49 PM   #6996
hemifalcon
CPP sent me a set of those "wire gauge" springs for my suburban-- I was like "that $hit ain't gonna work!"
Old 02-17-2013, 03:17 PM   #6997
77lesabre
77lesabre's Avatar
Painted the Jeep rear coil springs to prepare to install them, stripped the interior and prepped it for sound deadner(once it arrives) and wrapped the bench seat! Name:  10.jpg
Instagram: 77lesabre
*1961 Chevy Long Stepside-350/700r4
*1977 Buick Lesabre Lowrider-350/th350
*2003 Chevy Silverado 2500HD-Duramax Diesel
77lesabre is offline
Old 02-17-2013, 03:19 PM   #6998
hopped up
hopped up's Avatar
The old springs look like they were heated up to me, for the old school drop
hopped up is offline
Old 02-17-2013, 04:42 PM   #6999
dantimdad
dantimdad's Avatar
I got to use my new stud welder today.
Modded the slide hammer to start with:
Then I took out all the dents in the cab.
This one had at least an inch of bondo:
This is a shot downward to show how flat it came out. No dolly work at all just pulling on the studs:
Took 13 pins strategically located.
This tool is one of the best things I have EVER purchased.
Steven
Old 02-17-2013, 06:51 PM   #7000
jbgroby
jbgroby's Avatar
I agree!
jbgroby is offline
Closed Thread
