Old 04-17-2011, 09:21 PM   #701
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
I found a old video
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-20-2011, 08:48 PM   #702
flamingbig10
6.0 powered square
Re: my 80 build
got a few things done, picked up a tail shaft plug from matco, made some power steering hoses, hooked up a oil pressure and temp gauge, but now it won't idle and when it dies its hard to start
Aaron
Old 04-20-2011, 11:16 PM   #703
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-23-2011, 01:08 PM   #704
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-23-2011, 02:45 PM   #705
baclay9
Re: my 80 build
What transmission crossmember are you using? is it stock? I need to come up with something I can run 3" exhaust over the top of on both sides.
baclay9 is offline   Reply With Quote
Old 04-23-2011, 05:44 PM   #706
flamingbig10
6.0 powered square
Re: my 80 build
yes its the stock double hump one
Aaron
Old 04-23-2011, 06:33 PM   #707
nbpro
Re: my 80 build
Coming along nicely. Can't wait to see the finished product.
nbpro is offline   Reply With Quote
Old 04-23-2011, 08:34 PM   #708
baclay9
Re: my 80 build
Would it be a huge inconvenience to take a good pic of that trans crossmember for me. What did those come on?
Old 04-24-2011, 02:41 PM   #709
flamingbig10
6.0 powered square
Re: my 80 build
thanks Gary, and baclay9 the cross member I believe came with 73-87 with out a catalytic converter
here is bad picture of it
no more unneeded holes on the fire wall and started removing the ribs on the fire wall
Aaron
Old 04-26-2011, 07:07 PM   #710
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: my 80 build
Originally Posted by flamingbig10 View Post
fuel line all done
HI, just starting my fuel lines tonight...how did you connect you lines to the gas tank "spouts"?
Looks like you used a fitting right there from the braided line to the fuel sender, do you remember the part number for it? Is it one off Glock's list?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-26-2011, 07:24 PM   #711
flamingbig10
6.0 powered square
Re: my 80 build
for the sender lines I shortened both the return and feed line a inch or so and used this one for a return line
http://www.summitracing.com/parts/EAR-165056ERL/
for feed line
http://www.summitracing.com/parts/RUS-660570/
http://www.summitracing.com/parts/RUS-660650/
http://www.summitracing.com/parts/SUM-220166/?rtype=10
Aaron
Old 04-27-2011, 04:36 PM   #712
menace121978
menace121978's Avatar
Re: my 80 build
awesome progress Aaron! looking good man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-27-2011, 09:51 PM   #713
Gordonr1973
Home Built '87
Re: my 80 build
for feed line
Thanks, I bought these parts too from Glock's list....just wondering though how you got the line started at the fuel tank / sender? (I've never used braided lines before)
So, did you:
1. cut the ends off the 3 fuel sender's tubes,
2. then put a nut on each fuel sender line,
3. then flared the fuel sender line with your 37' flaring tool,
4. then threaded your a/n end onto the nut?
One other question, are you running one or two fuel tanks?
Thanks for your help!
Gordon
Old 04-30-2011, 12:21 PM   #714
flamingbig10
6.0 powered square
Re: my 80 build
I havent used the braided line before either
1.I cut the end for the feed and return spout and bent the vent line to get a mini tubing cutter in
2.yes
3.yes
4.yes
I'm running one tank
Aaron
Old 04-30-2011, 08:43 PM   #715
flamingbig10
6.0 powered square
Re: my 80 build
thanks dennis
Aaron
Old 05-01-2011, 05:05 PM   #716
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: my 80 build
Glad to see the progress Aaron. Keep at it man!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 05-01-2011, 06:25 PM   #717
bayou boy
bayou boy's Avatar
Re: my 80 build
it looks like everyones going ls well gas prices i can see why thanks for the pics and info on the fuel tank i was thinking along the same idea with only one tank
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 05-01-2011, 11:07 PM   #718
bbbc10
Diggin The SquareLife
Re: my 80 build
lookin good!!! finally got mine lowered!
bbbc10 is offline   Reply With Quote
Old 05-01-2011, 11:25 PM   #719
Gordonr1973
Home Built '87
Re: my 80 build
2.yes
3.yes
4.yes
Thanks for the info Aaron!
I think I have a pretty good idea of what I need to do on mine now.
I am running 2 tanks though. Will get started on it tomorrow night.
Am suscribed to your thread!! Looks great so far!
Gordon
Old 05-03-2011, 09:23 PM   #720
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Gerald
yes they are getting very comun
Thanks, your tuck looks good
no problem I would just run them like Dennis's
Aaron
Old 05-06-2011, 09:30 PM   #721
Chris Guthro
Re: my 80 build
Your Truck looks amazin man! Someday id love to do a 6.0L swap into a square, on a scale of 1-10 how hard would you say it is? Did you finish the dash yet? Ive about to start welding the holes up in mine
Chris Guthro is offline   Reply With Quote
Old 05-06-2011, 09:43 PM   #722
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Chris, the swap has been pretty easy so fare, I decided not to do the dash
Aaron
Old 05-07-2011, 08:18 AM   #723
spudz
spudz's Avatar
Re: my 80 build
Cool beans!
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 05-13-2011, 12:07 AM   #724
flamingbig10
6.0 powered square
Re: my 80 build
thanks
Aaron
Old 05-14-2011, 10:55 PM   #725
flamingbig10
6.0 powered square
Re: my 80 build
got a little done today got the cab and bed pulled off and cut the old frame up in about 8 pieces
Aaron
