12-22-2020, 07:23 PM | #701 |
low n' slo
Re: Project 67 DRGNWGN - 67 Burban!!
its an 01? so it should be dbc. so im thinking at least motor trans pcm engine harness. not sure yet about anything else. what ya lookin for?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-23-2020, 11:42 PM | #702 |
low n' slo
quick question, i have everything unbolted and unplugged, ready to pull out....except the driveshaft. im having a huge mental lapse with pulling this driveshaft. is this the kind of ujoint that needs to be pressed out? i removed the clips but the damn u joint doesnt move at all.
12-24-2020, 01:31 AM | #703 | |
The Older Generation
I can't remember what you have there. Does that shaft just pull out of the tail housing or does it have a nut on it? Do you have the other end of the shaft loose? You are probably not going to get that u-joint apart while it is still under the truck. LockDoc
12-24-2020, 01:35 AM | #704 |
low n' slo
ill check in the AM but i believe it slips out, i dont remember seeing a nut. and nope, other end is still intact
12-24-2020, 01:38 AM | #705 | |
LockDoc
12-24-2020, 01:41 AM | #706 |
low n' slo
ill have a look in the morning. i dont think ive ever pulled this driveshaft but i couldve sworn i had the trans out before
12-24-2020, 03:55 PM | #707 |
low n' slo
guess that was the easiest way! i dont know why i was trying to avoid removing the driveshaft, it will need to come out anyways.
12-25-2020, 02:11 AM | #708 | |
It really isn't too bad to remove them, just takes a little time. LockDoc
12-26-2020, 01:09 PM | #709 |
low n' slo
well, i feel like rewinded 5 years but it will be worth it in the end....plus i can do some things to the inner sides of these panels i should of done the 1st time.
used this tiny truck to pull the motor out *edit* i dont know why these pics always turn out sideways
12-30-2020, 11:14 PM | #710 |
low n' slo
found a knock off holley 302-2 pan kit for the motor. trying to stock pile some stuff together for now.
https://www.ebay.com/itm/402091342885 also, going with this 21 circuit rewire kit off amazon. basically a knock off of the EZ wire kit. i know, its not a big name brand, but im on a budget here and hope it works out
12-31-2020, 11:08 AM | #711 | |
The wiring kit may be a little more work but it shouldn't be that hard to get sorted out if you have the old one to lay out and duplicate. Let us know how it works out. LockDoc
12-31-2020, 11:27 AM | #712 |
low n' slo
oh, im sure ill be asking questions here lol. i plan to take pictures of everything i mount or attatch. not really a how to, but hey this is what i did kind of thing. ive been reading a lot on here about the ls swaps and wiring. i wont know what exactly ill be reusing off the old harness until i see what this one has. from the pictures it looks like it has a lot of our original plugs though
01-01-2021, 10:48 PM | #713 |
low n' slo
just ordered these, hope they work out
01-07-2021, 06:25 PM | #714 |
Coordinator of Synchronicity
Hey Kevin, were you running a York
motor mounted compressor for your suspension?
Rick 1971 Suburban ... W.I.P. Build Thread Customization is ones personal touch-- not what other people think it should be |
01-07-2021, 08:33 PM | #715 | |
low n' slo
i still have it if ya want it, im gonna to start cleaning stuff up around here and trashing whatever doesnt sell. yard starting to look like sanford and son
01-20-2021, 11:54 AM | #716 |
LOL nothing out of an '01 , was just wondering.
05-27-2021, 12:47 PM | #717 |
Nudge ... Hey Kev
06-05-2021, 08:20 AM | #718 |
low n' slo
heyyyyy....
no updates yet, been putting a little money in my avalanche but about to get started on the suburban again soon hopefully. been doing some remodeling in my house also, floor guy is supposed to come this week. either way I have no choice to at least get my motor in by October, as the city now all of a sudden wants my neighborhood (non HOA by the way) to not have any "junk vehicles" unless they are behind a fence. soooo, had to spend 400 to make a fence around my suburban, and have until October to get rid of the donor vehicle.
09-21-2021, 09:00 PM | #719 |
low n' slo
finally a little progress....somewhat. drove my donor truck in the driveway and started the teardown. I been picking at it since Sunday but I'm hoping to have the drive train out by next week. meanwhile, after pulling the intake... this motor looks filthy
09-26-2021, 09:41 PM | #720 |
low n' slo
heeyyyyyy got my motor and trans out the donor and on the ground. went and bought my engine stand from northern tool today so hopefully will get it on the stand this week and start the teardown
09-27-2021, 08:32 AM | #721 |
Sounds good! It all takes time, especially if you are still working. I started on a new project too and have had some interruptions. Just keep plugging away at it a little bit at a time and before you know it you will be driving it. LockDoc
10-02-2021, 02:50 PM | #722 |
low n' slo
huge setback with this motor...was draining the oil to get it on the stand and a ton of milkshake came out....kind of down to 2 options now. called my buddy where I got it from and he said he has another 2001 tahoe I could get. but I have to sell what I have and whatever I get would go to him for the other truck. other option would be to pull the heads and send them to get rebuilt and/or pressure tested for cracks or warps.
10-02-2021, 07:58 PM | #723 |
Well that sucks. Maybe it will be something simple like a gasket or "O" ring somewhere. I know that isn't really simple either but maybe you won't have to pull the whole thing.... LockDoc
10-03-2021, 09:39 PM | #724 | |
Post Whore
Personally I would probably pull the heads and have them checked then I would know what kind of shape the cylinders are in. And of course I wouldn't be able to NOT pull the oil pan and inspect the oil pump. The evil demon "Project Creep" has arisen again.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-03-2021, 10:11 PM | #725 | |
low n' slo
I started of the frame clean up to keep me busy
