#701 |
Re: What did you do to your truck today?
Made a 3 gauge panel to replace the heater controls in the Camaro dash. I like to call it the rare "Heater Delete" option.
![]() Also spent some time organizing all the under dash wiring with wire ties in preparation for hooking up gauges. It might look nightmarish but now I know what every wire is thanks to my trusty 1965 Shop Manual. Last edited by lakeroadster; 01-19-2010 at 08:05 PM. |
#702 |
#703 |
#704 |
#705 |
Shlong Bed Club
Replaced a heater core in a customers Chevy Equinox. Job calls for 10hrs and the car only had 60k on the odo. I know it doesnt pertain to our trucks, but i thought you guys might be interested.
I did however get my front suspension out from under my truck tonight. cant seem to be able to post the pics. i'll try again later Last edited by DWright; 01-20-2010 at 12:54 AM. |
#706 |
Senior Enthusiast
That's why I drive a 50 year old truck, the heater along with most everything else can be fixed or changed in minutes instead of days.
#707 |
Spent 3 hours grinding and sanding rust/dirt off the the rear 1/3 of the frame. Tomorrow plan is to finish the rust removal with a wire brush , then paint it with POR-15.
#708 |
I worked on modifying my rear shock c.member....
#709 |
Shloooooong bed member #2
Started on some panel replacements..
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#710 | |
![]() Join Date: May 2009
#711 |
On the GMC trucks. only the back area (behind the barbell) was blacked out, no trim color was done.
Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
#712 |
#713 |
Thanks guys for the answer on the GMC grills. Hey today I bought a 63 Chev swb knee knocker from a guy that was hurtin for sure. $500 and the title was mine. It needs bed wood and I will have to replace the rockers maybe just the drivers side. I'm a GMC guy but I wasn't passin' this up bbw an all. It has an I6 in it and it runs good. I'll start on it when I get my GMC done, it needs paint and some body work.---Vernski
#714 |
Congrats Vernski...I don't know if I jealous or envious or both. Keep us posted and nice score.
#715 |
Member of the longbed union.
Good score, looks pretty straight..
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#716 |
I did some work yesterday and today on my rear backhalf. I made my top tri link tabs and today I squared up my frame and rearend, set the pinion angle and built the top links. I ran into a small problem with where my links were headed so I had to bend them so they would hit the middle adjustment. But I'm glad I did because it turned out sweet. I had to pie cut it because I don't have a tube bender and didn't want to wait. My bungs are tacked in and its tacked in the front and the tabs are tacked aswell. Anyways here are some pics and I did a walk around and video'd it and I'll have that up later.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#717 |
Sunburst C10!!!
i did some measuring for a y pipe then set it back on the ground and tried a little
Gage 1967 C10 Shortbed Stepside |
#718 |
Rods
![]() Join Date: Nov 2002
bench tested the dash and a/c from the 08 chevy. it works so ill be tryin to figure out how to get it in the 66
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#719 |
Sam60 Do you know what your ride height is going to be set at on your truck?
#720 |
Should be about the same as or around about a 5'' drop on a shortbed.
#721 |
#722 |
Resistance is Futile
Nice work sams60
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#723 |
I parked mine in the neighbor's carport to keep tree limbs/trees from falling on it while it's windy....they park in the street since there's no tall trees in front of the building.
Martin Gibson
USAF Retired 1964(-ish) C10 |
#724 | |
#725 |
Senior Enthusiast
With unseasonal temps in the high 40's and low 50's, I got mine out of storage and back in the garage for new trailing arm bushings, a relay for the heater and maybe more upholstery.
