Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 10-07-2018, 09:37 AM   #701
M.A.C.'sFAB
Re: D52 Caliper Rear Disc Brake Brackets
Originally Posted by Captainfab View Post
The prices for all of my products are Exactly the same as in post #1 of each for sale thread just as it says in bold text. Both of the 6 lug brackets are $177.50 plus $13.65 for shipping.
I have never in 40+ years of working on Chevy's seen a truck 12 bolt with disc brakes from the factory. The only 10 bolts with disc brakes are the '88+ 8.5" & 8.6" 10 bolts. I did not use any dust shield when designing any of my rear disc brackets. I have no idea if any factory dust shield will work. Additionally adding any thickness of metal in between the brackets and spacers will alter the alignment of the caliper with the rotor.
Well... 1st off. Yes, your right I can read. Just seeing if price is "still" current. You didn't actually need to point out that it was in bold text. Are you trying to be a f-ing jackass?
2nd. The dust shields I'm looking at are through Inline tube (seen them on ebay). And I'm currently using them on my 67 Chevelle (4 wheel disc conversion). They don't just fit 8.5 and 8.6 rears, they fit 8.2, 8.875, etc. 10/12 bolt "CAR" rears up to '81. Maybe you should take a look at those?
When did I ever say that 12 bolt trucks came with rear disc's??? I didn't, I was referring to the shields. Why do you think I pointed out the tube flange is bigger on these then car 12's...… Answer.... because I already know that!! And yes, I know it will add thickness to the setup, about 0.050 worth of thickness
Now if you want, I can keep going on talking to you like a jackass, like you are to me or we can BOTH go back to being civil?
I asked you the questions because I didn't feel the need to scroll through a 1000 posts and waste 2 weekends to see if I could "potentially" find answer to my simple questions. If that's too much to ask, then maybe I'll just pass on these....
M.A.C.'sFAB is offline   Reply With Quote
Old 10-07-2018, 11:19 PM   #702
Captainfab
60-66 Nut
No I'm not trying to be a jackass, but you say that you can read that it says in my for sale threads that "these prices are always current and up to date" then why are you asking what the price is? I don't know what I need to do to make that more clear? I get asked that same question 10+ times a week. I created and maintain my for sale threads so that I hopefully don't have to repeat myself multiple times a day or week. So yes I do get a bit irritated when I keep getting asked the same question repeatedly when I feel that I have made it clear what the answer is.
Since this thread is about a rear disc brake conversion for a truck differential and we are on a truck forum, when you say "I was planning on using 10/12 bolt rear dust shields", that sounds like you are talking about truck 10/12 bolt rear dust shields? Doesn't it? You originally said nothing about aftermarket dust shields from Inline Tube for passenger 10/12 bolt diffs.
And when I told you that the F44 rotors would not accommodate the D52 pads, you seemed like you didn't believe me until I posted a pic to verify my statement. You want to ask questions but don't believe me when I do give an answer.
Originally Posted by M.A.C.'sFAB View Post
I see what you mean.... How much is a set of your brackets for a 6 lug rotor with Cadillac/Camaro calipers? I seen it listed for 177 plus shipping?
I was planning on using 10/12 bolt rear dust shields (knowing I will have to change the bolt pattern), will those shields be able to be sandwiched in between your brackets still clear the rotor and caliper? I ask because they already have a cutout section at a specific angle already and was wondering if that angle is close to the angle of your brackets?
Old 10-12-2018, 11:50 PM   #703
Captainfab
60-66 Nut
Here is another option for those wanting an e-brake caliper with these brackets.
https://www.ruffstuffspecialties.com...m_medium=email
Old 05-22-2019, 07:08 PM   #704
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Hi Captain: I'm having Moser turn a custom set of axles for my 90 burb rear and was planning to use 5x4.75 to have more wheels options. Do you foresee any issues getting 5x4.75 rotors to fit "truck" calipers?
I have a set of brackets cut off a race car that we were going to weld on, but I think your brackets may just be a lot easier in the long run.
Thanks-
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 05-22-2019, 11:18 PM   #705
Captainfab
60-66 Nut
There is no such thing as a rotor with the 5 x 4.75" wheel stud pattern that is a direct interchange with the Astro van rotor. There are 2 options. 1) drill the 5 x 4.75" hole pattern in the Astro van rotors in between the 5 x 5 pattern. 2) purchase the set of brackets that I make specifically for the 5 x 4.75" pattern. I do not have a for sale thread for them but they are pretty much the same as these brackets that I make for the 6 lug.
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
Thanks-
Old 05-23-2019, 01:39 PM   #706
PhilaTruck
PhilaTruck's Avatar
Thanks for the info. Option 2 sounds better to me. I forgot to mention one IMPORTANT detail.
I'm planning to install c-clip eliminators. Would they affect fitment?
Subscribe here!
Old 05-24-2019, 12:49 AM   #707
Captainfab
60-66 Nut
None of my rear disc conversion brackets will work with c-clip eliminators. The base brackets need to bolt to the backing plate flange on the same side as the c-clip eliminators do
Old 05-24-2019, 03:42 PM   #708
PhilaTruck
PhilaTruck's Avatar
Thanks for that info. Those brackets are sweet
Subscribe here!
Old 06-10-2019, 04:46 PM   #709
turbobuick1
turbobuick1's Avatar
Would like to buy your brackets ASAP , just sent a PM. Thank you!
turbobuick1 is offline   Reply With Quote
Old 06-10-2019, 11:34 PM   #710
Captainfab
60-66 Nut
I replied to your email.
Old 06-13-2019, 07:40 AM   #711
turbobuick1
Any chance these could work with a 79-85 Seville/Toronado/Rivera rear caliper? I have a manual transmission truck and a parking brake is a must.
I’m hesitant to buy the kit because the 76-78 El Dorado calipers are few and far in between, given their limited original application. I’ve called a few parts stores and they simply cannot get them at this time.
The 79-85 are much more readily available.
Also, the 79-85 Seville calipers come with all the brackets for the brake cable, the 76-78 calipers do not.
Is anyone who converted to rear disc successfully using the 76-78 Cadillac calipers with parking brake cables?
Old 06-13-2019, 09:04 PM   #712
turbobuick1
I guess I should add that the 79-85 Seville calipers are equally hard to come by at your local auto parts store, but classic performance parts make brand new reproduction 79-85 Seville calipers; currently on eBay for $120 for a pair.
https://rover.ebay.com/rover/0/0/0?m...2F262552370871
Old 06-14-2019, 01:05 AM   #713
Captainfab
60-66 Nut
No the '79-'85 calipers will not work. Those are a completely different caliper. I do make the lever, cable brackets and sporing kit for the '76-'78 Eldorado calipers. Or you can just buy new calipers here.
Unfortunately they are currently out of stock. You might call or email and ask when they will be receiving more.
There are a few of the reman calipers on ebay.
https://www.ebay.com/sch/i.html?_fro...liper&_sacat=0
Old 07-24-2019, 11:57 PM   #714
KMC3420
KMC3420's Avatar
Captainfab, I was curious if you have any feedback on using this kit on a 68 that was originally a 6 lug, but has been converted to 5 lug using conversion axles?
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 07-25-2019, 12:02 AM   #715
Captainfab
60-66 Nut
No I do not. I seldom receive any feedback unless there is a problem and then not always in that case either. There should not be a problem using these rear disc brackets with 5 lug conversion axles. The 5 lug conversion axles should be the exact same length as the original axles.
Old 07-25-2019, 09:01 AM   #716
KMC3420
KMC3420's Avatar
Thanks, I will be ordering my axles first and that was my only concern if the conversion axles were a bit longer. I will be able to confirm that on my end but from what I am reading and what you are saying is that the axles are the same length. Appreciate the info.
Keagan
Old 08-25-2019, 02:43 PM   #717
KMC3420
KMC3420's Avatar
Captainfab, below are my measurements with my new axles. Can you get a few measurements from your setup for me once you get some free time. Thanks.
Keagan
Old 08-25-2019, 11:25 PM   #718
Captainfab
60-66 Nut
Sorry but those measurements do not tell me anything about fitment of any of my rear disc brackets. If you are unsure of the axles that you purchased, I would need to know the brake offset. That is the distance from the outside of the backing plate flange to the outside of the axle flange (WMS). It should be about 2-7/16"
Old 08-26-2019, 09:08 AM   #719
KMC3420
KMC3420's Avatar
Thanks Captain, I will get this measurement tonight.
Keagan
Old 08-26-2019, 08:29 PM   #720
KMC3420
KMC3420's Avatar
Captain, let me know if this is not the measurement you need.
Keagan
Old 08-26-2019, 11:13 PM   #721
Captainfab
60-66 Nut
That is the brake offset and 2-7/16" is correct for a truck 12 bolt.
Old 08-27-2019, 09:09 AM   #722
KMC3420
KMC3420's Avatar
Thanks Captain. Your brackets are next on my list to order. Appreciate the help.
Keagan
Old 11-25-2019, 03:28 PM   #723
HeavyHauler
I would like to buy your rear disc brake D52 bracket kit for my 1968 Chevy C10. It has the factory 12 bolt rear with conversion 5 lug axles.
I would like my bracket kit to be powder coated and will send you the additional money for that which you mentioned in your 1st post on this thread.
I will send you a PM also. Thanks!!!
HeavyHauler is offline   Reply With Quote
Old 11-25-2019, 08:52 PM   #724
Captainfab
60-66 Nut
I replied to your PM
Old 11-26-2019, 01:45 PM   #725
HeavyHauler
Payment sent and can't wait to receive them! Thanks!
