#701 |
Re: intro + 66 black bagged long fleet
Thanx man!! You and jdoisher and a few others got me wishin i would have pancaked my front crossmember. Its really cool how everybody feeds off each others ideas
![]() Posted via Mobile Device Posted via Mobile Device
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#702 |
#703 | |
Jason |
#704 |
I really want to but im gonna wait till after i drive it a while and have the money to build.a 496 out of a spare block i have. This is just phase 1 of this build. If i keep it i plan on tearing it back down after i drive it for a while to build a motor. Powder coat everything and do all the body work with a glossy black paint job. Since this was my first build i didnt wanna go all out with the paint on the frame and stuff cause i knew i would need to change things like i have
#705 |
Thanks you. Yeah I hear you man. The more I think about it I may have gone a little overboard on the painting for my first build
![]() ![]() Posted via Mobile Device
My frame Layin 63 short bed project ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
#706 |
ya but i would cry if i had to mess up that pretty paint!!!! lmao
#707 |
Keepin it old school
You gotta start making two of everything. One for you and one for me
![]() Nice job on those rear arms. |
#708 |
haha i wish it were that easy
thanx man!!! i got some updates today.. got one side of my exhaust pretty much all fitted and tacked together.. gotta make some more hangers then do alot of welding.. i made some pie cuts around the tranny crossmember to make it clear.. ill take some better pics of that when i go to weld it up.. was hard to get a good shot from under the truck the exhaust is prolly gonna be way too loud but im gonna try it out and see how i like it.. i can always add more mufflers under the cab. also i got a question?? since there really insnt room under the cab i thought about adding an H pipe right after where the the exhaust comes through the rear crossmember.. would i benifit much for doing this or is it a bad idea??
#709 |
also u can see i took my trailing arm brackets off my rear crossmember. im gonna try to get them modifyed tonight
#710 |
Nice job buddy! almost ready to fire up? ive been waiting patiently!
![]() ![]() ![]() Posted via Mobile Device
#711 |
man thats pretty!!! ya im really tempted!! im running 2" drop spindles. i would like to be able to use stock ones like you are.. i bet ur ground clearance is way better than mine in the front.. and it goes lower!!! lol
#712 |
SSN 706
Nice work on the exhaust.
#713 |
![]() Join Date: Oct 2009
good work man... closing in on a driver.
#714 |
When I added my cross over pipe (White '67 Camaro behind shop) the exhaust note did seem to be a little less loud.
Nice work on the exhaust. |
#715 | ||
![]() ![]() ![]() thanx man!!! ya im getting pretty excited!! i would love to be able to cruise it to one of ur bbq's this year ![]() ![]() ![]() Quote:
i did get a lil farther this weekend.. there first couple pics are of the mods i did to the trailing arm brackets.. since i set up my bag brackets with those huge lowering blocks the bags were bottoming out before going all the way down with the smaller lowering blocks (another nooby mistake learned the hard way ![]() ![]() ![]() also got my exhaust most of the way done.. just need to finish 1 more hanger, finish my H pipe and do all the final welding.. also gonna need to reroute the air line for the front bags now but thats no biggie. its hard to tell from the pics but ive got about 3/4 inch of clearance between my exhaust and my tranny crossmember. btw all the exhaust under the cab will get heat wrapped to keep my fuel line as cool as possible anyway enough blabbing and on with the pics
#716 |
and ya i know this exhaust is gonna be a lil overkill being 3 inch on a basically stock 454 but one day i plan to build a pretty nasty 496 so i dont wanna have to upgrade that later on
#717 |
looks like careful planning is paying off. there is alot of stuff going on in that small area.definitely think routing the exhaust thru the trailing arm front bracket is the way to go. no ground clearance issues.3 inch ehaust is HUGE. nice job
#718 |
Looking great man! I'm ready to hear it start up!!!
![]() ![]() I bet it's going to sound mean!!!! ![]() Posted via Mobile Device
#719 |
Thanx guys!!! I got my crossover pipe done. Just gotta do some final welding and the exhaust will be pretty much done
#720 |
That is some twisted wicked exhaust!
Dig it ![]() |
#721 |
Ya its pretty crazy lookin and not normal so i knew you would like it
#722 |
never seen anyone do their exhaust like that. Its cool looking!
#723 |
thanx Bazooka!!
i got a chance to do a little more work. im waiting on some header wrap and some flex couplings. then i will finally be able to finish the exhaust up. besides that i got the holes drilled for the crossover pipe, and all the welding done today. i noticed that some H pipes have a smaller hole than the diameter of pipe. I had a hole saw to cut a hole for a door knob so i just used that.. i believe it was 1 3/4" anyway on with the pics
#724 |
Rollin' Old Skool
Nice fab work on the exhaust! Just curious to know if the smaller diameter hole in the H-pipe affects anything much (I'm no exhaust expert, haha)?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#725 |
thanx man!
im really not sure.. i think its just so the pressures can equalize without too much exhaust getting trapped in the crossover pipe but thats just a guess.
