Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-19-2012, 03:31 PM   #701
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Originally Posted by quadzero View Post
Like me, glad I found this thread right away. The work and results are amazing. Plus you could shave in that paintjob it's so shiney, fantastic effort you are putting into this.
Thanks.. The paint is very nice...
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 12-19-2012, 04:41 PM   #702
sdailey
The Few, The Proud
sdailey's Avatar
Re: Crash's 72 K10
Here you go Mark. They're real nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=543799
Shannon
sdailey is offline   Reply With Quote
Old 12-19-2012, 04:44 PM   #703
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks..... Just what I was looking for..
Mark
Crash's 69 4x4 SWB
Old 12-20-2012, 11:37 PM   #704
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Filled and bleed the brakes today. Decide to go with DOT5, not sure if it is the right thing, but it is what I decided.
Also installed the vacuum booster hose. I got one at the GM parts place.. it is designed for a LS..
Part number 15097187
After that I installed the antenna coax. Had to drill the hole for he coax.
Tomorrow I will be working on the remote door locks, gas pedal, front side marker wiring, etc..
Mark
Crash's 69 4x4 SWB
Old 12-21-2012, 10:15 PM   #705
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Installed the remote door openers.. They worked out well. I little bit of a learning curve on calibrating the system.
Installed some of the door hardware.. I decided to use buttonhead hardware instead of the original phillps screw style.
Installed the gas pedal.. A lot of trial and error to get it like I wanted.
Mark
Crash's 69 4x4 SWB
Old 12-21-2012, 10:21 PM   #706
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 72 K10
Few things can top the joy of working on the inside of doors. You're really making headway now!
Zoomin is offline   Reply With Quote
Old 12-21-2012, 10:24 PM   #707
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
No doubt Steve.. I am still amazed how much time each step takes..
Mark
Crash's 69 4x4 SWB
Old 12-21-2012, 10:30 PM   #708
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 72 K10
I hear ya. It really gives you an appreciation for what goes into getting one of these done. Yours is really going to be worth all the aggravation.
Old 12-21-2012, 10:38 PM   #709
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
I know.. After Kyle finishes up jobs for you and Bryan he is going to try and give me a hand on lining up the front sheet metal on mine.. once I get that done I will be on the downhill side of this..
Mark
Crash's 69 4x4 SWB
Old 12-21-2012, 10:38 PM   #710
calvin78612
calvin78612's Avatar
Re: Crash's 72 K10
Are those lock poppers from VH Coachworks? I am getting ready to install mine soon along with the SS door wire looms.It looks like a straight forward install but i'm sure it won't be.Truck looks great.Calvin.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 12-21-2012, 10:43 PM   #711
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Calvin,
Yes they are from VH coachworks.. No problems with the install.. just time consuming..
Mark
Crash's 69 4x4 SWB
Old 12-22-2012, 10:57 AM   #712
Zane M
Re: Crash's 72 K10
Just read through the entire build. Great job!
Zane M is offline   Reply With Quote
Old 12-22-2012, 11:39 AM   #713
Daaaanz67
Re: Crash's 72 K10
Phew just got done reading through this also. Nice build, I'm usually over at the 2wd 67-72 section but something has been drawing me to the 4wd side. Recently just got done on my 69 ls build just want to say your going to love this motor power output is great and no matter how long you let the truck sit as long as the battery isn't dead it will start and run just like when you left it. The magic of efi I'll never go back to carbs. Think my next build will be a 4wd. Thanks for the inspiration. Again nice work I'm following this to the end.
Daaaanz67 is offline   Reply With Quote
Old 12-22-2012, 09:28 PM   #714
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Installed the condenser and lines…
Third Brake Light finished and installed.
Dome light..
Cargo light
Mark
Crash's 69 4x4 SWB
Old 12-22-2012, 09:29 PM   #715
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks...
Mark
Crash's 69 4x4 SWB
Old 12-22-2012, 09:32 PM   #716
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks I hope so.. I have to start it up every few days to keep me motivated.
Mark
Crash's 69 4x4 SWB
Old 12-22-2012, 09:32 PM   #717
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 72 K10
That combo cargo/brake light is trick!
Posted via Mental Telepathy
Old 12-22-2012, 09:36 PM   #718
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Steve... much happier with it than my first attempt... using a late model 3rd brake light.. Kyle talked me out of it pretty quick...
Mark
Crash's 69 4x4 SWB
Old 12-23-2012, 09:51 AM   #719
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
I like the brake light idea. I assume you used some LEDs?
I'm gonna need more info on that for sure. Just another subtle touch that really pushes your build over the top. Keep up all that hard work. Downhill you are headed
mcbassin is offline   Reply With Quote
Old 12-23-2012, 10:03 AM   #720
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike...
Yes... 8 red leds.. I got you covered when you are ready..
Have a great Christmas..
Mark
Crash's 69 4x4 SWB
Old 12-23-2012, 06:04 PM   #721
67c10rustbuket
67c10rustbuket's Avatar
Re: Crash's 72 K10
Looking great, I like that LED dome light and 3rd brake light.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-23-2012, 08:25 PM   #722
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Dan... Getting a little closer each day...
Mark
Crash's 69 4x4 SWB
Old 12-23-2012, 08:25 PM   #723
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Installed the front side marker lights and wiring..
Still having a little trouble getting the cargo light to seal up right.. Anybody have any ideas?
Rebuilt the window regulators…
Installed the windshield sprayers ..
Debating on installing the steps bars now, or waiting. I think I might go ahead and install the brackets and leave the bars off until after Kyle does the final pass on the paint.
Mark
Crash's 69 4x4 SWB
Old 12-25-2012, 12:13 AM   #724
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Decide to work on a method to hide the fatmat on the back of the cab.
Looks really good.. I still have a small spot I will need to hide.. thinking a strip of black duct tape or maybe a small piece of carpet..
I also went ahead and mounted the step bars with the help of my wonderful wife
Merry Christmas to all…..
Mark
Crash's 69 4x4 SWB
Old 12-25-2012, 12:27 AM   #725
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Crash's 72 K10
I say small piece of carpet. Is a bench seat going to be in there?
Why weren't you at the mall today?
