Old 01-15-2013, 12:17 AM   #701
thelonerife
thelonerife's Avatar
Re: Project 78 High Sierra
looks good Jeff
thelonerife is offline   Reply With Quote
Old 01-15-2013, 12:36 AM   #702
JRANGER
JRANGER's Avatar
Thanks!! From the pic I may need to get another wash to life the cab a bit to match the lines up but until its bolted down im not sure...May even still be sitting on some cardboard lol
Rus is like a leprechaun....When he comes around you can see da gold finger!! lol
JRANGER is offline   Reply With Quote
Old 01-15-2013, 12:40 AM   #703
cubber
Insert finger joke here.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 01-15-2013, 06:20 PM   #704
JRANGER
JRANGER's Avatar
Played with Photoshop today...This is what im thinking for the door panels
Old 01-15-2013, 06:25 PM   #705
motornut
78K & 79C Jimmys
motornut's Avatar
nice!
modern look ,classic red n black
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-15-2013, 07:44 PM   #706
UPNADM
UPNADM's Avatar
Those will look mint. I like the design.
UPNADM is offline   Reply With Quote
Old 01-15-2013, 08:53 PM   #707
cubber
Those are SLICK!
=MATTHEW
Old 01-16-2013, 01:39 AM   #708
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Originally Posted by JRANGER View Post
Cut out the bolts with my angle grinder....Easy business but still a PITA!!!! Will.....A Dremel????? How the hell...That would suck!!!!!
Eitherway new bumper installed with grade 8 bolts
Yeah man, it SUCKED. Lots of cussing going on. They were the bolts that were inside the bumper that held the bumper to the bracket. I couldn't get an angle grinder in there, so I busted out the dremel and the tiny cut off discs. I couldn't get to the bolt stems, so I hit the nuts with the dremel. Finally came apart though.
killthewabbit is offline   Reply With Quote
Old 01-16-2013, 08:08 PM   #709
JRANGER
JRANGER's Avatar
OK I think I know the answer to this because it seems like the most logical answer but ill ask anyway.... I bolted my bed back up tonight and the lines are all sorts of messed up.... The bed lines are too high on the drivers side and slightly lower on the passenger side to match up to the cab.... Replacing the rear cab bushing might of done this and i tightened them with my impact until they wouldnt anymore....So does that mean I probably tightened them too much or un-evenly???
Thats what i think because the bed is on the frame with no additional things underneath it....Allthough the rear bumper needs to be adjusted a bit as its lower on the passenger side
Old 01-16-2013, 08:25 PM   #710
cubber
Put a level across the top of the front bed rail, and this will tell you if the bed or the cab is uneven. I was replacing the bushings on my radiator support, and the fenders wouldn't line up, and I had the wrong bushings in there ,lol. Idk what kind of instructions came with your set, but mine sucked and didn't say anything about what went where. If your bed is out of level, you could use washers to shim it. If its the cab, you might have something else goin on.
=MATTHEW
Old 01-16-2013, 08:31 PM   #711
JRANGER
JRANGER's Avatar
Bed is level
Old 01-16-2013, 08:43 PM   #712
Rusbuilt
Rusbuilt's Avatar
Its not uncommon to have to shim (add washers) the cab to match the bed when replacing the cab bushings..
Rusbuilt is offline   Reply With Quote
Old 01-16-2013, 08:49 PM   #713
JRANGER
JRANGER's Avatar
ok its just weird since one side is high one side is low but cool....Hopefully i can level it out....Hopefully i can get the brake lens reinstalled tomorrow
Old 01-16-2013, 08:58 PM   #714
Rusbuilt
Rusbuilt's Avatar
If you don't get it right perhaps we could help you at Chuck's meet!
Old 01-16-2013, 09:01 PM   #715
JRANGER
JRANGER's Avatar
haha ill bring some stuff so we can...Much easier with a real jack to wedge stuff in Prob would only take a few secs...Chuck stuff first though
Im thinking of skipping training as im try to rehab this knee and stay off it so im gonna try to get there early
Old 01-17-2013, 12:10 AM   #716
cubber
Glad you will be there early, but sorry about the knee. with all the people that will be at Chuck's, I'm sure you will be able to get some help. Matter of fact, I KNOW you can, cause I will help you if I can.
=MATTHEW
Old 01-17-2013, 10:01 PM   #717
JRANGER
JRANGER's Avatar
FRUSTRATION!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So i ws determined to get the truck in running condition for sat so today goal was to reinstall the tail lights....Tested brakes and running light then blinkers.....Passenger side would work but driver side would just turn off the running light and not blink!!!! WTF!!!!!!!!!!!!!!!!!!!!!!!!! I think i figured it out....The hacked in trailer wiring is using butt connectors at the connection point..They were all wrapped together so i unwrapped them and bent each in a different direction...Put the rear light wire back together and everything seems to work but thats it...Nothing else has been done as i now need to either wrap them with electrical wire separately or re-wire the trailer wire all together....ERG ERG ERG ERG...So basically i accomplished nothing for the last 2 hours other then running my batt dead and having to jump the truck twice
Old 01-18-2013, 02:58 AM   #718
cubber
Wiring sucks!
=MATTHEW
Old 01-18-2013, 11:43 AM   #719
chevybuilder18
chevybuilder18's Avatar
well that might be whats going on with my truck!
Her name is Quicksilver
1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER
gotta pay $$ if you wanna play
chevybuilder18 is offline   Reply With Quote
Old 01-18-2013, 10:17 PM   #720
JRANGER
JRANGER's Avatar
Success!! All lights are now working...Re-Installed the gauge cluster, dashpad, bezel, and readjusted the throttle cable AGAIN!!! UGH.....lol Also removed the second spring as it was making it too hard to push the pedal....Much better now.....Drove her around a few million times to get her just right....LOL
Old 01-20-2013, 02:57 PM   #721
JRANGER
JRANGER's Avatar
Picked up some stuff this weekend from Matt (Cubber).. Cant wait to put the rims on and cant wait to see if the headers fit
Old 01-20-2013, 06:38 PM   #722
cubber
dang I'm glad you cleaned those rims up before you took em inside
=MATTHEW
Old 01-20-2013, 07:39 PM   #723
motornut
78K & 79C Jimmys
motornut's Avatar
nice!
John
Old 01-21-2013, 05:48 PM   #724
chevybuilder18
loving the headers and rims. you mentioned there chevelle headers, some guys on here have used them on there squares. said they fit with little to no problems just like the flowtec headers i have. which ill be making them like new again and selling for an offer.
Old 01-23-2013, 10:57 AM   #725
JRANGER
JRANGER's Avatar
Ordered a new throttle bracket that should prevent my throttle bracket from getting loose. Also ordered some more wiring to work on the cluster as the last set I had issues with pulling pins loose but i ordered a auto wire stripper to prevent that from happening as well.. So soon back to doing some crazy wiring o yeah!!! lol
