Old 10-04-2014, 05:28 PM   #701
WCHLVR
WCHLVR's Avatar
Re: How about some pics of Static dropped 60-66
Redd with new shoes
WCHLVR is offline   Reply With Quote
Old 10-04-2014, 09:43 PM   #702
Raceaprilia
Cpp 5,5/7 with small notch at back.
Vision Torque 143 18", Toyo proxes STII tires, 255/50 front and 295/45 rear.
Put a cover over it, have a beer or two, kool down, and look at it in a couple weeks, we all have to take a break!
64 Short Fleetside, 283, T5 http://67-72chevytrucks.com/vboard/s...d.php?t=572500
Faded 87 soon to be LS powered http://67-72chevytrucks.com/vboard/s...d.php?t=653667
Raceaprilia is offline   Reply With Quote
Old 10-06-2014, 07:43 AM   #703
ChrisDollins
ChrisDollins's Avatar
Looks killer with the new wheels WCHLVR!
Raceaprillia, love the truck! Looks perfect, any more pics of it?
Chris
ChrisDollins is offline   Reply With Quote
Old 10-06-2014, 11:09 PM   #704
low6four
low6four's Avatar
5" rear coils. Camaro front sub-frame.
Low6Four
'64 SWB
low6four is offline   Reply With Quote
Old 10-09-2014, 08:40 AM   #705
schpeen
schpeen's Avatar
installed 2.5" drop spindles sway bars front and rear and new kicks
schpeen is offline   Reply With Quote
Old 10-09-2014, 09:55 PM   #706
Beautiful truck. Love that color!!
Old 10-12-2014, 11:13 AM   #707
Raceaprilia
Chris
Thanks, just posted some updates on build. Click in my signature to see it.
Old 11-06-2014, 11:14 PM   #708
1962BlackBetty
Torsion bars cranked down, chopped rear springs
[IMG][/IMG]
[IMG][/IMG]
1962BlackBetty is offline   Reply With Quote
Old 11-18-2014, 09:02 PM   #709
Jgowin
Jgowin's Avatar
Originally Posted by WCHLVR View Post
Redd with new shoes]
What size are these tires and wheels?
Jgowin is offline   Reply With Quote
Old 12-03-2014, 01:26 AM   #710
endlessearth
endlessearth's Avatar
Low and level C20.
endlessearth is offline   Reply With Quote
Old 12-03-2014, 09:22 AM   #711
gnd efcs
Originally Posted by 1enick72 View Post
Mine with some new rubber, I think I need to drop another inch or two
sweet truck bro..;whats the backspacing ?
gnd efcs is offline   Reply With Quote
Old 02-06-2015, 07:56 PM   #712
Mjminino
instead of going through all 25 pages, does anyone have any pictures of specifically a 2.5 inch drop spindle and a 1 inch lowering spring in the front, 5 inch spring in the rear not including blocks and no notch. please and thank you
Mjminino is offline   Reply With Quote
Old 02-06-2015, 09:25 PM   #713
This one has the 3.5 front drop, but I can't remember if it is a 5 or 6 drop springs in rear No blocks or C-notch..
Old 02-06-2015, 10:50 PM   #714
likaroc13
Rollin' Old Skool
I thought it had the same ECE 4/6 drop as yours.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 02-07-2015, 06:21 AM   #715
His front had only the 1" drop springs, mine had the 2" Your probably right about the rear , I just can't remember if it was a 5 or 6 drop in the rear.
Old 02-07-2015, 07:24 AM   #716
Mjminino
Going into my build of lowering it kind of blindly, I am hoping it turns out sweet. with the aforementioned stats of 2.5" spindles with a 1" lowering spring and a 5" rear spring. I hope it sits mildly level.
Old 02-07-2015, 09:29 AM   #717
J & E Speed Center
J & E Speed Center's Avatar
My 64 two coils cut up front and five inch lower coil and 2" blocks in the rear. I'm an old school guy that has never had anything with air ride ever. Everything I've ever had has either had cut coils or heated springs. I have to admit that I just ordered up air bags for my 64, I'm doing a 3"dropped lower control arm cup and keeping my drum brakes, still kind of old school I guess. The rear will be on air with the standard C notch.
J & E Speed Center is offline   Reply With Quote
Old 08-24-2015, 03:44 PM   #718
russellrox
Awesome stance, how much lowered in the rear, I am currently 3" in the rear with springs and 1" in the front, truck sits way too high in the front, I am hoping that if I put a 2.5" drop spindle instead of drop springs in the front this should fix my issues. I wanted a slight bit of rake so your setup looks perfect.
Originally Posted by chadh100 View Post
I finally got it where I wanted it today!
After I did the disc brake conversion using the 2.5" dropped spindles, I had to have spacers in the springs because the 11" wide tires were rubbing on the fender . But I stumbled across these 15x7 rims the other day at my boys wheel shop and now the tires fit in the front fenders beautifully!
russellrox is offline   Reply With Quote
Old 08-24-2015, 03:58 PM   #719
Evoracer
New suspension has settled in...
Evoracer is offline   Reply With Quote
Old 10-09-2015, 01:07 PM   #720
sags
Just 'finished' mine this weekend. 2" drop spindles and 2" drop coils on front. 4" drop coils in back with shock relocators. Only 'finished' because the panhard bar was frozen to the bolt. Will cut off and replace with new one this weekend. Have to look at what size tires.
sags is offline   Reply With Quote
Old 10-20-2015, 02:20 PM   #721
19SIKtySix
19SIKtySix's Avatar
Originally Posted by steve'62 View Post
Another pic
I love the wide whitewalls on this truck, killer look.
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 10-23-2015, 01:06 PM   #722
Horribilis
Nice looking ride!
Originally Posted by Fuzzy0810 View Post
CPP 3/5 spring drop on 20" rev classics
Horribilis is offline   Reply With Quote
Old 10-29-2015, 10:10 PM   #723
66redw/white
made in america
66redw/white's Avatar
3/5 from cpp
31 inch tires tucked into the back
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
Old 10-29-2015, 11:59 PM   #724
C/10 King
C/10 King's Avatar
The Seahag... a lot cut in the front and 7 inch (I think) in the rear.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 11-03-2015, 04:03 PM   #725
nibulus
nibulus's Avatar
nibulus is offline   Reply With Quote
