Old 01-24-2013, 02:09 PM   #701
67cheby
67cheby
67cheby's Avatar
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
i am going to use a remote mount resivor and the carpet will be removable in that area !
67cheby is offline   Reply With Quote
Old 01-24-2013, 02:18 PM   #702
babyblueoval
babyblueoval's Avatar
The carpet? So you can clean up spills? Where will the remote mount go since it needs to be higher that the M/C? Up inside your smoothed cowl? Sorry for so many questions.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-24-2013, 02:22 PM   #703
67cheby
67cheby
67cheby's Avatar
yes inside the cowl, it will have a door
Old 01-24-2013, 02:27 PM   #704
babyblueoval
Ok, I've seen it done that way just not sure I'd be comfortable with it on my vehicle. It will look AWESOME though.
Jim
Old 01-24-2013, 03:31 PM   #705
watahyahknow
watahyahknow's Avatar
it will be hard to get to the MC as long as you can get too it to take off the lid you can use a seringe and a little piece of hose to fill it up from underneat the dash
two small holes in from the top under the hood would be eazier but you cant see when the reservour overflows
i guess a daiper on the floor under the MC should be enough to catch any spilling but im not sure if it absorbs oil like substances , its eazy to test if it does though
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-24-2013, 03:47 PM   #706
67cheby
67cheby
67cheby's Avatar
hmmmmm..i like that , maybe a drain pan with a hose going outside !
Old 01-24-2013, 03:48 PM   #707
67cheby
67cheby
67cheby's Avatar
if you want to build a really clean / custom truck that is unique....nothing is going to be "EASY" !
Old 01-24-2013, 03:54 PM   #708
xxlf250
xxlf250's Avatar
Amen to that!
xxlf250 is offline   Reply With Quote
Old 01-24-2013, 03:54 PM   #709
babyblueoval
Now that sounds like a good idea.
Jim
Old 01-24-2013, 04:51 PM   #710
widewhite70
widewhite70's Avatar
Looking good Mike!
-Calvin
http://67-72chevytrucks.com/vboard/s...d.php?t=512270 my build, tube chassis and LS2
How I keep the truck shining, Detail thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=697902
widewhite70 is offline   Reply With Quote
Old 01-25-2013, 11:04 AM   #711
67cheby
67cheby
67cheby's Avatar
For you guys that know alot more about the LS stuff then me, i want to run one of the corvette or camaro intakes that set down lower and look alot cleaner , is there anything in particular i need to look for when trying to find one ?
Old 01-25-2013, 11:07 AM   #712
6772owner
Gearhead
6772owner's Avatar
Mike, I think that the "hot ticket" is the LS6 intake (Vette?) as far as factory goes, or a something like a FAST unit for built stuff... Im not terribly familiar with the LS stuff, I mostly do LT1's.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 01-25-2013, 11:14 AM   #713
67cheby
67cheby
67cheby's Avatar
i will check that out !
Old 01-25-2013, 11:47 AM   #714
Scottshotrods
You can use the LS instake off a corvette and it will bolt on no problems at all.You might want to calll Mark at Street performance in Arkanasas.(479)394-5711.He will more in likely have several in his shop and might give you a good deal.Prepare to be on hold for long time.Mark is very sharp on the ls motors
Justin
Scottshotrods is offline   Reply With Quote
Old 01-25-2013, 11:58 AM   #715
watahyahknow
http://www.highperformancepontiac.co...s/viewall.html
http://www.gmhightechperformance.com...t/viewall.html
http://www.ls1gto.com/forums/showthread.php?t=289456
looks like it gains about 15 to 20 hp with the change , from wat i read a camshaft gives a lot of gain too
Old 01-25-2013, 12:10 PM   #716
DrppdBlazr
DrppdBlazr's Avatar
I got mine off ebay with fuel rail and injectors included for around $300
sorry kinda crappy pic of the intake itself....
I wouldnt do a ls6 intake unless you find one for a really good price cause at the cost they go for you might as well get a nice aftermarket one like fast as mentioned before.
DrppdBlazr is offline   Reply With Quote
Old 01-25-2013, 12:14 PM   #717
RocketKing
RocketKing's Avatar
Watch the water pump and idler pulley...
http://67-72chevytrucks.com/vboard/s...+swap+manifold
...post #3
Rex
RocketKing is offline   Reply With Quote
Old 01-25-2013, 12:31 PM   #718
DrppdBlazr
DrppdBlazr's Avatar
yep def need a new waterpump since the truck waterpump top hose hits the tb. THen you can either switch out to camaro/corvette accesories or use spacers for waterpump
Old 01-25-2013, 01:21 PM   #719
67cheby
67cheby
67cheby's Avatar
Justin
Thanks Justin, i will give him a shout !
Old 01-25-2013, 01:22 PM   #720
67cheby
67cheby
67cheby's Avatar
...post #3
this is what is so great about this board !!!!!!!! Thanks guys !
Old 01-25-2013, 01:28 PM   #721
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Mike, something to think about with the LS1/LS6 intake. You will lose some torque with these intakes, as compared to the "truck" intake. The HP numbers are pretty even when comparing the two (Truck & LS Vette), until about 5500 RPM or so, then the HP numbers fall off the truck intakes.
I don't know the exact numbers, but if you're going to be doing some towing, you may want to look into that a bit, plus the blazer, I'm assuming, is a little heavier than a truck.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 01-25-2013, 01:48 PM   #722
jkeating1
jkeating1's Avatar
Gives a whole new meaning to 'Slosh Tub'
JK
jkeating1 is offline   Reply With Quote
Old 01-25-2013, 01:49 PM   #723
thor
thor's Avatar
for you guys that know alot more about the ls stuff then me, i want to run one of the corvette or camaro intakes that set down lower and look alot cleaner , is there anything in particular i need to look for when trying to find one ?
Originally Posted by jnjchev77 View Post
mike, something to think about with the ls1/ls6 intake. You will lose some torque with these intakes, as compared to the "truck" intake. The hp numbers are pretty even when comparing the two (truck & ls vette), until about 5500 rpm or so, then the hp numbers fall off the truck intakes.
I don't know the exact numbers, but if you're going to be doing some towing, you may want to look into that a bit, plus the blazer, i'm assuming, is a little heavier than a truck.
FAST intake will provide low end torque that the truck intakes are famous for and deliver that top end HP too. Check it out. Kinda spendy though!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-25-2013, 02:02 PM   #724
jkeating1
jkeating1's Avatar
a buck and a quarter seems to be the market:
http://dallas.craigslist.org/ndf/pts/3556232473.html
JK
Old 01-25-2013, 02:30 PM   #725
DrppdBlazr
DrppdBlazr's Avatar
^^^ nice deal for sure...
Hey Mike..not sure if you measured this at all when the tank and axle were still in but what was the space like between the axle and front of the gas tank? Is there any room in there at all? Any idea of how many inches it is, In other words do you know if a bag would fit behind axle and infront of gas tank...its hard to get under mine right now to tell. Thanks for any help
