#701 |
Re: What did you do to your truck today? Chapter II
I mocked up the NV4500, range box, and NP205...
I think I need to rotate the box a bit left. 2.6 time 1.96 makes for a good cheap setup. I parted a 91 sub to get the TC so I have 500 in the whole thing and _all_ parts needed to put it together except the clutch fork boot. Last edited by franken; 05-26-2014 at 01:17 AM. |
#702 |
#703 |
![]() Join Date: Apr 2013
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#704 |
#705 |
![]() Join Date: Aug 2011
I have my seat being reupholstered with original fabric and vinyl from SMS, laid down some sound deadener and insulation and installed new carpet from ACC.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#706 |
I like that sound deading stuff!
I sprayed NAPA Rust Inhibitor onto the vent line I derusted yesterday. |
#707 |
playing with my vinyl cutter and lettered the truck, not sure if it like it or not.
also found some really trick marker lights and they are gm, check it out. ![]() ![]() |
#708 |
Allchevy58- looks good, I'm doing the same, where did you screw the under dash light mounts into, did you have to drill a hole?
Outlaw- they look smooth, and the decal looks cool!
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#709 |
Old member
Did some paint work on the truck the other day and have the front half waxed! I did the paint repair last year too before the HRPT. It takes a couple of days to do but worth it I think. I start by wiping the whole area down with mineral spirit's . Then dry good and use my touchup paint and dab it on in the bad spots. Let it dry good for 2 days and then take a clean tee shirt and mineral spirit's again and rub until smooth. Then wipe off good and wax it.
Here is the front of the hood with paint dabed on and then after I waxed it. It's not 100% but way better than what it was. ![]() ![]() ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#710 | |
1970 C10 Short Stepper with 71/72 front clip. |
#711 |
I painted my canister lines (those under the truck) with 1 coat of flat black today. Tomorrow I hope to put those back on.
#712 |
Finished the Restoration yesterday and just have been sitting back and looking at her
#713 | |
One teaser picture is not going to get it....we have to see more of your outstanding work.
#714 | |
I made a crafty mount for the DLC. Used a paint chip sample to make it and found a home in this factory hole that had a switch for the saddle tanks. Used it to make a template but it's pretty sturdy so I may just leave it there.... And forget the effort of making one out of thicker steel. Thoughts? 1972 GMC Sierra Grande Factory Tool Box 4.8L Ly4 with whipple supercharger. 356 dana 60 4l80e overdrive ![]() |
#715 |
2WD Jimmy
![]() Join Date: Mar 2005
I had a toggle switch there and moved it. I was worried what it would do to my knee or leg in an accident. Jmi
#716 |
![]() Join Date: Nov 2010
Most of the heavy lifting is done on my 61' so I decided to sand down "rails" of bed to get em ready for paint....It's been so long since I broke down the beds(yes two beds, long story) that I forgot where this "short rail goes"
![]() thanks in advance.... |
#717 |
I got the box sides, bulk head, steps and cross members assembled and sitting on the frame. Next I have to mount the rear fenders and box side filler tube to the fuel cell.
#718 | |
#719 |
#720 |
![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Fixed my horn button, swapped my gauge bezel lights for leds and replaced the shift indicator glass fibre light with an led, rebuilt that annoying little spring button thing that releases the headlight switch shaft! What a PITA.! Now to get on the rack and straighten my back.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
#721 |
Old member
Polished and waxed the wheels in preparation for the 2014 HRPT next week.
![]() ![]() Got the oil changed and all the fluid levels top off too. Added a little color to the pulley's as well! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 05-31-2014 at 02:38 PM. |
#722 |
![]() Join Date: Apr 2010
#723 |
![]() Join Date: May 2013
Things just got serious. The tear down begins.
Pulled the cowl and driver's side front fender off. Spent a few hours trying to straighten it up and beat the wrinkles out. Not a bad start and much better than it was. Then, I painted my aluminum intake to get ready for the engine swap.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#724 |
Got the under dash lights from board member thelonerife thread TN Underdash lights. Bulbs are cheap LED's from Ebay.
#725 |
Looking good!
