Re: 1956 Chevy Pro-Street Build
Ptc, have a question on your paint, is that a satin paint, matte paint, semi gloss,? It looks good, thanks
#2 | |
Dont thin it much at all - i did too much and basically had to wash it all off with a garden hose the first go around. It looks decent in the pics but its kinda splotchy in places. Im sure if I had a paint booth and controlled environment to spray in, it could have been better, but it was a driveway paint job and thats it.
My Build: 57 Chevy Pro-Street |
Haven't been on this board for a while, too busy...
Now I see the pics that weren't on FB, I see what I missed, my bad. Looks like I have got to see it in person ![]() American tour in the making.....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
Bring your brushes, Ill buy paint - I want some of the "Rockin'Kees" pinstriping on my rig!
![]() Join Date: May 2015
man that truck looks sooooo good...that stance is killer
![]() Join Date: May 2007
how did I miss this? the grille is amazing!nice work and congrats on the drive
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#7 | |
"Amazing" is a bit much but thanks, I did have really big ideas for that grill but had to dial back my expectations just a bit. but it came out ok after it was all done and said. Overall I wanted to keep the truck body exterior looking 'old'... and I didn't want any chrome. The satin Stainless color came out pretty nice. Gonna be some more of that. Still doing some fine tuning of things here and there before I take the big cruise.... down to the alignment shop!
last I checked in I think you had just modded the hood, still one of the most unique mods I have seen!
that was probably a year ago
#9 | |
![]() I have all the metal in the rear bed to complete and the inner fender wells to custom make, so I do have some more winter work to do yet. But once I get it aligned and I can take it for drives to the store or just locally wherever. The dirt this thing kicks up is incredible!!!! needs a bath everytime I take it out.
Got all the 5" intake tubing at a Trucker Supply Store and its all welded up into place and had to make a support rod for it since it hangs out so far off the supercharger.
I had to redo the hat as the 1/4-20 air cleaner rod was not holding the hat on. I spoke with the guys at Extreme Velocity and they said yea you need to get rid of that, drill and thread it 5/16-18 and put in stainless steel rod. It wont stretch when it comes on boost. I was wondering why I kept blowing out the air cleaner paper gaskets no matter how tight it was. So I drilled it and re-threaded it and put a 5/16 S/S rod in there, a new Fel-Pro composite gasket that is metal lined , double nutted with a nylock too and it holds boost now! Got all the boost reference lines done in Vibrant poly tubing and quik insert fittings, I love these things! they work great. And then I got the hood onto the truck finally and it looks almost complete. Needs alot of adjustment but its on for now. I tried riggin up a remote latch release because of my grill but found an easier way. If anybody needs a really nice custom latch release I got one! ![]() ![]()
Super clean design.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Looking good PTC!
#13 | |
Thanks DG |
#14 |
I know your question wasn't directed towards me but I'll throw this out there anyway. I grafted a VW style hood latch in place of the stock one. It's a lot cleaner looking and has a better secondary latch...
#15 |
This is the latch I used, they can be found used on '85-'92 VW Jettas, Golfs and other models. It is set up for a cable release FWIW.
http://www.yogisinc.com/index.cfm/pa...d/prd13796.htm Keep in mind that the filler between the radiator and the grille is different on a '56 and '58 so installing one might be a little different. I cut out the oval shape in the filler panel and welded in the lower latch from underneath. The upper latch was bolted to the existing under hood latch plate, only minor shimming and trimming was necessary. Sorry no other pics and with the truck blown apart I cant go take one for you. |
#16 | |
![]() ![]() Join Date: Nov 2008
Also for you, others and ptc (maybe) I once found someone who used ordinary metal desk type locks on the leading edge of his hood to provide a secondary lock/protection against the hood flying open at speed. Up until I saw yours, I was planning to do this too but only after all final adjustments to the hood fitment because there’s little room or error. No cable release, but I can live with that if I can be certain my hood is secure. I’ll see if I can find the old pic and will post it here.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 12-19-2017 at 06:11 PM. |
#17 | |
#18 |
Ok guys well here it is.... for now...
https://www.facebook.com/paul.christ...4885428631793/ Took the old man for a ride down to the gas station just to give him a little thrill!!!! --- Not that he hasnt had a few in his 94 years of life so far.... ![]() He was pretty happy with what the "kid" put together!
#19 | |
As long as someone on earth still thinks of you as a kid, you’re good to go!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#20 |
![]() Join Date: Jan 2015
wow, what cam and what mufflers are you running. sounds REAL good
#21 |
clean work on the battery box, slammed57 does some nice work
#22 |
Everything looks great!
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
#23 |
I didn't realize 12lbs of boost would create so much pressure, now I understand why it's hard to keep a hose in place.
Mudman.
#24 |
Looks and sounds great. Nice work
My taking way longer than expected 58 build |
#25 |
![]() Join Date: Mar 2011
Sweeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
| Bookmarks |
