#701 |
Happy to be here
![]() Join Date: Mar 2000
Re: 85 GMC Sierra "Scarlett"
While Chris prepped and masked the frame, I wrapped the evaporator core in cardboard to protect the fins and painted the ends in cast iron. I replaced a couple of the fasteners with polished button heads to give it a bit of personality.
#702 |
![]() Join Date: Oct 2014
Dang, that turned out good! But when does anything you guys do, NOT turn out good. I wish I could see this truck in person, it is just awesome.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#703 |
Still Learning
Very nice work as always Ken!
#704 | |
Happy to be here
Thank you sir
#705 |
Happy to be here
I had limited progress tonight. I found out Summit Racing sent me the wrong pan gasket. It turns out they had it listed wrong on the Summit site. I had to research on the Fel-Pro site to get the correct number. I installed pan in with a couple of bolts anyways to keep dust out of the bottom end.
The good news is I finally found the correct starter bolts. I researched Dorman site and found the correct length. What I had was 3/8 16 x 4.5 and what I needed was 3/8 16 x 4 5/16" . That seemed a little long too, but I installed them very tight and they didn't bottom out.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-17-2017 at 08:50 AM. |
#706 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#707 |
fantastic!
#708 |
I'm just glad to be here!
Looks great Ken.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#709 |
Happy to be here
Thanks for the kind words guys.
#710 |
Happy to be here
I am waiting on the correct pan gasket to be drop shipped from Fel-Pro so I cant finish the bottom of the motor. I have to say, I think this is the first time Summit sent me the wrong part. In the interim, I hung the pan in place to keep dust out.
Meanwhile I need to move forward so I worked on small parts last night. I stripped the transmission cooler and vacuum lines and painted them. I blasted the dipstick and some small brackets and sprayed them too. The HVAC blower motor, and the alternator got a coat of cast iron too.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-18-2017 at 11:16 AM. |
#711 |
Can I bring my Big Red to your place? You can unleash your OCD on it.
#712 | |
Happy to be here
#713 |
![]() Join Date: Feb 2011
The cast iron paint really sets that off...years ago, I saw someone use trunk spatter paint under the hood of a truck in a magazine. I liked the look of the small blue paint flecks because my truck was blue. I tried the same thing but had lousy results...problem was the paint would pretty much wash off when water hit it. I later found that a satin clear sealed it, but it was still extremely easy to scratch off...live & learn
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#714 | |
Happy to be here
#715 |
Happy to be here
I stopped by the muffler shop yesterday and got my headers welded. I had planned to smooth the welds and install the new pan gasket. I was anxious to get the oil pan installed so I did that first.
The Fel-Pro gasket comes with plastic guide pins that screw in to the corner holes. The gasket is supposed to slide over the pins and lock in place till you get the pan bolts started. Great idea in theory, not so much for my situation. With the pins in place there was not enough slack to work the pan over the crossmember and clear the oil pump pickup. After some time of frustrated wrestling with it, the pan came back off and the pins were tossed aside. All I had to do now was hold the gasket in place, along with the pan and the reinforceing rails. Doing all that while reaching over head is quite the task. Determined not to give up, I manged to get one side started with out the rails, start the opposite side with rails then alternate sides till all bolts were in. Frustrating and tiring, but I was successful. With the pan snugged down I reinstalled the starter and the oil filter. I touched up the paint and called it done. Unfortunately my victory celebration was brief. I removed the headers from the back of my truck. I inspected the welds and discovered two more pinholes. Great! Another trip to the muffler shop. I really need to get my MIG welder back in operation.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-19-2017 at 12:32 PM. |
#716 |
Man, so many things on your engine detailing and sealing up remind me of what I went through on my '82 stepside...
I tried those pins and ended up using small dabs of VHT gasket sealer to hold the gasket in place, had to replace my starter in a dimly lit parking lot and for the piece 'de resistance, finding antifreeze in the header collectors after I got the freshly rebuilt engine set back in the truck....that last one made me walk away from the truck for about a week until I could be objective again! Lol
#717 | |
Happy to be here
I completely understand your frustrations. I went through it with the water pump on my 77 Cheyenne. I let it set for a season after it started leaking the second time.
#718 |
...and yet, we keep coming back for more
![]() ![]() ![]() If I can find a picture of it, I'll try and post it... That was just a small story of that truck, but it was a good experience for the ones that came after and memorable because it was our getaway vehicle on our wedding day.
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 01-19-2017 at 01:52 PM. |
#719 |
Still Learning
Too bad you're not closer Ken, I would gladly weld your headers up for free....
Very clean work on everything! Your OCD is shining through ![]() |
#720 | |
Happy to be here
#721 |
Happy to be here
Baby steps last night since I got a late start. I picked up new gaskets for the fuel pump and installed it. I decided to replace the gasket behind the adapter plate while I was there. Of course the actuator Rod slid out while I was cleaning up.
It wasn't until after I bolted the adapter plate and new gasket on that I realized the rod would not go in through the hole in the plate. Time to blast the plate again and create a new gasket. With the rod lubed up and firmly in place I finally got the pump on.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-20-2017 at 10:43 AM. |
#722 |
Happy to be here
Earlier I made a trip to see my buddy johnnyc new shop. I dropped off some goodies for him to put his magic touch on. Let's see what he comes up with.
#723 |
Can't wait to see what he does to the air cleaner and the valve covers.
#724 |
Happy to be here
Last night's project was the a/c compressor. I pulled all the brackets off of it and bead blasted them clean. They were scuffed and prepped, then painted cast iron too.
My buddy Jared dropped off the red paint for under the hood, so prep begins soon. Let's spice things up a bit.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-21-2017 at 09:23 AM. |
#725 |
Happy to be here
Are you running 22s on a static dropped #squarebody? Would you like to turn with out rubbing the fender liners? Do you even have fender liners? The new Mild Tubz from @slosh_tubz is what your looking for.
Designed for static or mild bag drops on #73_87 GM trucks to bolt in with minor changes. Here's a comparison of stock tubs versus #mildtubz so much smoother, wider and of course taller! Pre-order now if you want in on the first run of parts $689 shipped to a commercial address PayPal (loshmike@hotmail.com) They can be delivered at Lonestar Throwdown if you order now
