#701 |
Re: My Dusty 71 GMCe Electruck
I for one say well done! Looks darn good.
#702 |
Post Whore
![]() Join Date: Aug 2014
starting to show some forward momentum
#703 |
Post Whore
the key is to spend 86% of your time cleaning and wire brushing the internal cavities from below, where only the pit guy at the local Jiffy Lube will notice the next time you bring the truck in for an oil change... oh wait...!?!?!?
#704 |
Post Whore
I just love this primer
#705 |
Post Whore
also got Big Sexy back from the shop and popped it right in, fits like a glove
#706 |
Post Whore
then it was back to more grunt work and cheater bars
#707 |
![]() Join Date: Sep 2017
I mighta used an "all-wrench" on that.
That's refinery worker slang for a cutting torch. It'll remove bolts that are stuck a lot faster, but I guess you wanted to save that part. You sir are the king of wire wheeling!!!!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#708 |
Post Whore
ha ha, thanks I need COSTCO to start carrying these:
#709 |
You need a supplier who will sell them by the case!
#710 |
Post Whore
tricks of the trade:
#711 |
Post Whore
so a few grunts, moans, and uncontrollable farts later...
#712 |
Post Whore
it should take you no longer than a beer and a half per lower control arm, unless you are an IPA drinker then it should take your mechanic two per side, cause she normally works on BMmmmmers (tongue and cheeks folks, it's a joke)
#713 | |
![]() Join Date: Apr 2008
You know when you ask a facetious question to a teacher he is going to give you a lengthy answer. Now if you asked what makes teflon stick to the pan? I would have no answer for you. Since I let it marinate in the minds of your readers and gave it plenty of time with zero guesses I feel it is fair game for me to solve the riddle. The two upper control arms differ at the ball joint. One has been replaced at some point so it has bolts rather than hot rivets.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#714 | |
Post Whore
#715 |
All of your tedious, mind numbing, wire impaling, hand vibrating, work will pay off in the future and I am sure you will get lots of complements from the Jiffy Lube guy.
Drop members are really cool and look great but the factory X member can turn some heads too. I have been down this grimy road before. I like to see original celebrated. Still lots of work to go...
#716 | |
Post Whore
#717 | |
Posted via Mobile Device |
#718 | |
![]() Join Date: Mar 2011
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#719 |
Post Whore
#720 |
Yes gotta love that chrome powder coating. Just be careful when topping off your radiator. The Ethylene Glycol will ruin the finish and you'll be left with what looks like water spots.
#721 |
thanks for that tip
#722 |
Post Whore
so Friday night was baff night at our residence
#723 |
Post Whore
but more importantly having hit the 100,000 mile wire wheel mark I decided to treat myself
say hello to my little friend |
#724 |
Post Whore
and since I like my power equipment to glide across the garage floor at random
#725 |
Post Whore
I won't lie to you that thing showed up a few weeks ago and since then I've been playing the NPT, MPT, FPT, 1/4" 3/8", 1/2" and 3/4" round peg square hole game before settling on 3/8th hose from compressor to air gun (for now) I also got some 1/2" hose cause Mike Finegen recommended it, ha ha
