Closed Thread
Old 07-23-2013, 05:23 PM   #1
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: What did you do to your truck today?
Originally Posted by Grizz1963 View Post
Also started to remove the non matching bolts from the towbar where it is mounted under the chassis, will be replacing them all with 30mm M12 nuts and bolts.
How do you remove domed bolts that just turn around when you tru move the nuts? Vice grips ?
??? what the... oh yeah! Brittan... metric... thats why you are using 30mm...
I use a grinder to take off rusted, stubborn carriage bolts..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline
Old 07-23-2013, 05:00 PM   #2
craig7070
craig7070's Avatar
I thought about all the stuff I want to do to the truck.....
1972 C10 Custom Deluxe 2 Owner Project "Lumberjack" 83K Original miles
Work in progress....Got the truck for free all original
craig7070 is offline
Old 07-23-2013, 08:56 PM   #3
bigblock79
67 Chevy Stepside
bigblock79's Avatar
bought a parts truck for it
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline
Old 07-23-2013, 11:07 PM   #4
mud.man.rj
mud.man.rj's Avatar
Helped my buddy install his cab on his mudracer went from a 76 to an 81 cab with quad headlights, nice difference. Looked at my truck.
mud.man.rj is offline
Old 07-24-2013, 10:12 AM   #5
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thought about what to do on mine today.....So much to do....Hmmm...were do I start....
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 07-25-2013, 01:09 AM   #6
donthekawguy
donthekawguy's Avatar
I drove around and tried to motivated to pull the bed off to clean up the frame and get the rest of the busted up wood out. The heat won that battle.
66 shorty
donthekawguy is offline
Old 07-27-2013, 04:56 PM   #7
Grizz1963
Grizz1963's Avatar
Loads of little jobs done today.
Starting off with fitting the following item.....
Had a text from Rob, the previous keeper/owner of the truck a couple of weeks ago to ask for my postal address, as he had a "thing" to post off to me that he thought I would appreciate.
So this week he had time to pop into the post office to post out the "thing" which came to me on Thursday.
I have to say, his parcel was a challenge, and only when the "thing" came out the last layer, did I know what it was.
I have always loved these and they make me chuckle when people use them in public. Just never got to buy one myself.
Seems that when I tested it down at the garage, Duke, our ginger cat shot upstairs without waiting the see what it was..... RESULT !!
So, Huge Thanks to Rob, as he had planned it for the truck when he had it.
After the rear end kissing I got from Nicola when we fetched the truck, I realized the nuts n bolts on the rear bumper and towbar need to be seen to.
So this week I ordered some M12 x 25mm high tensile bolts with nuts to replace the existing items.
I have seen some bodging on this truck and stuff done to a standard below my own expectation, but the fact that there were 4 different nuts, bolts used to secure (loose description) the bumper at some point in its past, just made me shrug and bite my tongue.
It took some time to get these all removed, the domed head bolts were the biggest problem, as there was no way or room to grip the heads while addressing the nuts, which I had given some WD40 the last three days.
In the end I gripped the threaded ends with the vice grip and had a ring spanner in place over the nuts, getting them undone slowly.
The one bolt just turned off in my hands.
You will note there are no two the same here.
While I was at it, I also fitted new longer bolts to the plate on which the light socket plug was fitted.
When Scott wired the truck lights I decided to fit the plug under the load body, to keep it out of sight and the weather.
Next job, which I was actually not looking forward to (though it was actually surprisingly easy in the end) was to make up a sleeve/spacer for the tow ball Tim had sent me.
Remember I had a 40mm hole drilled in the bumper and tow bar as the shop did not have a 32mm drill on site the day I went there with Mickey.
So this was a bit of reverse engineering.
I had got a 300mm length of scaffolding pipe from Charley the farmer this week.
After measuring for what I needed, I cut a 25mm section off with the angle grinder with a 2mm blade fitted.... easy with the right tool.
I had also cut a slot into it length ways.
Using the grinder repeatedly to cut slivers out of it, and using the bench vice to push it together, then also shaping it the opposite direction, I eventually had a 33mm hole and 40mm outside diameter.
Before and after.
Using a large shifting spanner I recently bought for an art project I am working on, I tightened the whole lot, and ended up with a result that pleased me.
Tow ball fitted and some red reflective tape added to the rear step for night time visibility.
As always, Mickey popped around through the day.
Then once these jobs were done, we also rolled up the tonneau cover and fitted the bed sides as he wanted to see the dark painted sides up, the cover tucks in nicely behind the uprights.
At this point I had a coffee and left overs from last night as Nicola was out shopping (not my favourite pastime)and visiting her parents.
After lunch I decided to give the greasing a go, which was interrupted by a sudden thunder storm,( so need to do it again, this time without the wheels and jacked up, followed by trying to figure out why every light on the truck works off the main switch, but the headlights continue to be non functional..... STILL NO IDEA, or lights.
I also gave the tonneau a second coat of polish, Rain-X'd all the glass and stuck some stickers I had laying about onto the boat fuel tank that is now the trucks Jerry can.
Just after 6pm I decided to call it a day.
Tomorrow is bootfair day, so we will be using the truck to go there, and possibly a couple of other places.
All in all, a great weekend so far.
Still loving this truck.
I do wish I could have my brother here to enjoy it with me, as he is mad about trucks too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 07-27-2013, 08:08 PM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Bought some new/used tires for mine today! Only have 500 miles on them. No more running around on inner tubes!lol
Old 07-28-2013, 04:14 PM   #9
Grizz1963
Grizz1963's Avatar
Took the truck out for the day to Rochester, Kent today after we came back from a successful bootfair. Think Charles Dickens - Oliver Twist, Christmas Carol, Tale of two cities, David Copperfield for our foreign readers.
Got loads of thumbs up, and pics taken.... Nicola said she forgets the truck has a distinct presence and does sound rather menacing when cruizing slowly by.
When we came home, I got into the garage and got onto a job that has stared at me for three years....... I will not be saying too much, but this was one pic I took.....
After this I removed the Transit's number plate from the rear and fitted the Chevy's plate to the Grizz-Pod. (In the UK, the trailer carries the same registration as the car towing it, and has no insurance or roadworthy testing, s you could tow a cardboard box on wheelbarrow wheels, as long as it has a number plate)
This concluded a great weekend.
I still do not have headlights, but many other odd jobs have been done.
Old 07-25-2013, 01:13 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
I painted and bolted up the battery tray on the frame and took out the crappy Wilwood master cylnder and replaced it with a stock unit. What a great idea, now I just have to rebleed the brakes.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 07-25-2013, 04:04 PM   #11
craig7070
craig7070's Avatar
I have my son out cleaning out the cowl and sanding down the hood since Im at work and cant help..Im a great director....lol
Old 07-25-2013, 08:07 PM   #12
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Got it all shined up for a company car show tomorrow..
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 07-25-2013, 10:12 PM   #13
ChrisDollins
ChrisDollins's Avatar
What, no pics? You can't say you shined it up without a pic lol.
Chris
ChrisDollins is offline
Old 07-25-2013, 11:31 PM   #14
endlessearth
endlessearth's Avatar
Chris
x2!
endlessearth is offline
Old 07-26-2013, 06:18 AM   #15
61_FL_Apache
Who Me?
Chris
None yet. I hope to post some pics from the show later today.
Steve
2001 Blazer 4D 2WD
Old 07-25-2013, 10:49 PM   #16
19666Trucker
19666Trucker's Avatar
Posted via Mobile Devicefinally got my picture to post after the coil cut and exhaust done, maybe the cab lights are next. Has any body done them I wondering how to run the wires.
19666Trucker is offline
Old 07-25-2013, 11:33 PM   #17
endlessearth
Wow. I don't think I have seen that style exhaust on one of these before. That is going to be something when you mount the cab lights.
Old 07-26-2013, 12:36 AM   #18
19666Trucker
Yeah that is the trucker blood in me. I plan cruising it out to the pavilion s this weekend
Old 07-26-2013, 12:58 AM   #19
endlessearth
I might go as well if it isn't swampy hot outside.
Old 07-26-2013, 09:33 AM   #20
dbos
dbos's Avatar
I had them on my 65 but i removed them. The wire went up the windshield post, into a small hole in the ceiling then across. they must have drilled all the holes, fished a wire in with a snake then pulled it up through the roof holes and made the connections.
Were these roof lights an option from the factory? or was this an aftermarket thing dealers and owners put in. I have owned a 64 and 65 and they both had those lights.
dbos is offline
Old 07-26-2013, 10:50 AM   #21
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps these instructions from the 1960 Accessory Installation Manual will be helpful:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 07-26-2013, 12:16 PM   #22
jbgroby
jbgroby's Avatar
Ordered $20 bucks worth of stuff from LMC (2) front hood light sockets and the hood to cowl seal.
jbgroby is offline
Old 07-26-2013, 11:30 PM   #23
weaintscared
weaintscared's Avatar
Smoked up the road,,First time backing it out the shop.
http://m.youtube.com/watch?feature=s...eature%3Dshare
weaintscared is offline
Old 07-25-2013, 11:58 PM   #24
Chevy Fleetside
I made it move under its own power...
Old 07-26-2013, 12:07 AM   #25
the_evil_monk
Replaced the passenger side rear view mirror and steering wheel and started filling body in the cab...good day!
the_evil_monk is offline
Closed Thread
