Closed Thread
Old 04-08-2013, 08:41 PM   #7351
socaljess
socaljess's Avatar
Re: What did you do to your truck today?
setting up checking out how things will look
project 66 flat n low
socaljess is offline
Old 04-09-2013, 12:10 AM   #7352
garett
put on new rear breaks
garett is offline
Old 04-09-2013, 01:42 AM   #7353
azdude1964
azdude1964's Avatar
changed the oil with brad penn
and balanced the front tires.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline
Old 04-09-2013, 08:01 AM   #7354
robber grin
Cool look SoCalJess.
robber grin is offline
Old 04-09-2013, 08:05 AM   #7355
robber grin
Thanks Chris!
Old 04-09-2013, 09:04 AM   #7356
luvbowties
luvbowties's Avatar
Smile Re: What did you do to your truck today?
Originally Posted by markeb01 View Post
Thanks for sharing that they fit well. I'd like to add those to my truck someday, along with the chrome frames on the side glass. I think they'd upgrade the cab every bit as much as the stainless windshield trim.
Mark, hope you don't have to do like me: apply for an FHA loan to purchase a pair! Of all parts for our trucks, the price of vent-windows has blown my mind about as much as any thing I easily recall. I ended up buying a fairly nice pair on Ebay--including good glass and chrome--and re-building them. Luckily, they made a very nice 'driver-quality-plus' set. Even lucked up later & sold my originals to a guy whose set was much worse than mine.
sam
luvbowties is offline
Old 04-09-2013, 01:22 PM   #7357
socaljess
socaljess's Avatar
Thanks Robber
Old 04-09-2013, 04:39 PM   #7358
garett
well painted front drums, and put in new sparkplugs, also bled brake lines!
garett is offline
Old 04-09-2013, 08:56 PM   #7359
robber grin
Cleaned, primered, and painted the front sway bar and mounting brackets.
Worked on repairs to my hacked up low floor tunnel cover while the parts were drying...
I hope to finish it up tomorrow.
rg
Old 04-10-2013, 06:14 PM   #7360
ole paint
Installed clutch master cyl and linkage, bent a line and bled. Works like a million bucks. Started on power booster, thanks to Captain Fab for the quality parts to work with.
ole paint is offline
Old 04-10-2013, 08:29 PM   #7361
78f1hundo
Wheel and tire sizes please!!!!!!!
65' Chevy C-10 Shortbox
78f1hundo is offline
Old 04-10-2013, 08:48 PM   #7362
robber grin
Installed factory front sway bar (78 burb) on drop frame brackets.
With the frame being boxed and a REZ kit, I had to drill and elongate some access holes for the wrench on each of the back two frame bracket mounting bolts, but it worked out okay.
I think I'll get fresh bushings since these had quite a few cracks show up after everything was all tightened up.
rg
Old 04-10-2013, 09:02 PM   #7363
T Smith
T Smith's Avatar
Spent the afternoon at the alignment shop....
T Smith is offline
Old 04-10-2013, 09:15 PM   #7364
socaljess
socaljess's Avatar
@78f1hundo im running 20 inch velocity 5 spoke wraped with 255/45/20 yokohamas parada spec x tires
Old 04-10-2013, 09:21 PM   #7365
Bigru
Bigru's Avatar
Painted the front half of the 65 frame with POR-15.
Bigru is offline
Old 04-10-2013, 09:34 PM   #7366
Trsmotrhed
Trsmotrhed's Avatar
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 04-10-2013, 10:56 PM   #7367
socaljess
socaljess's Avatar
[IMG][/IMG]Cleaned out old bed wood and took the inner wheel tubs out
Old 04-10-2013, 10:58 PM   #7368
socaljess
socaljess's Avatar
[IMG][/IMG]Start sanding bed
Old 04-10-2013, 10:59 PM   #7369
socaljess
socaljess's Avatar
Why are my pics so huge ????????
Old 04-11-2013, 12:53 PM   #7370
dantimdad
dantimdad's Avatar
Painted the bellhousing and moved the rear end up on a big wooden box to finish cleaning and painting it.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-11-2013, 03:27 PM   #7371
Bigru
Bigru's Avatar
Originally Posted by Trsmotrhed View Post
Here you go..
Bigru is offline
Old 04-11-2013, 04:18 PM   #7372
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Here you go..
Hey... that's not showing much frame! Nice 292 though!!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline
Old 04-11-2013, 04:52 PM   #7373
Bigru
Bigru's Avatar
Lol. I notice that after I sent it, but I did paint the 292 also.
Bigru is offline
Old 04-11-2013, 07:53 PM   #7374
socaljess
socaljess's Avatar
Just finished sandblasting a arms and motor mounts [IMG][/IMG]
Old 04-11-2013, 08:55 PM   #7375
rideblue00
rideblue00's Avatar
I disassembled and painted my deluxe heater switch setup. I just dremeled the rivet heads off an painted it then drilled and tapped for a 4-40 machine screw right where the rivets were. Be careful not to drill through now! Really easy. I can't seem to add a photo from my phone as i don't know how. I will add it later from my computer.
rideblue00 is offline
Closed Thread
