Closed Thread
Old 04-11-2013, 09:02 PM   #7376
T Smith
T Smith's Avatar
Re: What did you do to your truck today?
Got dark on me so no pictures but I got my rear sway bar on, man what a difference!
T Smith is offline
Old 04-11-2013, 09:04 PM   #7377
Minesinger
Finished today!!
Turned out to be a bit bigger job than I originally thought. Really happy with how it turned out.
Minesinger is offline
Old 04-11-2013, 09:09 PM   #7378
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by Minesinger View Post
Finished today!!
Looks great, now you don`t want to use it....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 04-11-2013, 09:12 PM   #7379
Minesinger
I know. Not sure what to do about that. Might need to buy another truck?
Old 04-11-2013, 09:14 PM   #7380
jayoldschool
Moderator
Polished or unpolished strips? Where did you buy your parts from?
jayoldschool is offline
Old 04-11-2013, 09:16 PM   #7381
Rich 5150 69
Get yourself a heavy duty rubber mat to throw in the bed when hauling bad stuff..
Old 04-11-2013, 09:20 PM   #7382
Minesinger
They are unpolished. I got the center strips from Classic Parts USA and the bolt kit and corner cover strips for LMC. Shipping was really slow from Classic but they were a lot cheaper for the center strips but more on the corners so I split it up.
Old 04-11-2013, 09:23 PM   #7383
lowslow64
lowslow64's Avatar
After 4 months of body work and paint, it is finally home. Now put it back together
lowslow64 is offline
Old 04-11-2013, 09:42 PM   #7384
rideblue00
rideblue00's Avatar
I disassembled and painted my deluxe heater switch setup. I just dremeled the rivet heads off an painted it then drilled and tapped for a 4-40 machine screw right where the rivets were. Be careful not to drill through now! Really easy.
rideblue00 is offline
Old 04-11-2013, 10:30 PM   #7385
socaljess
socaljess's Avatar
@rideblue heater control turned out sweet did you replace the plastic lens if so what did you use mine is all scratched up
project 66 flat n low
socaljess is offline
Old 04-12-2013, 05:17 AM   #7386
rideblue00
rideblue00's Avatar
Thanks. Mine looked good so I reused it. I don't know if they are available to buy.
Old 04-12-2013, 04:31 PM   #7387
donthekawguy
donthekawguy's Avatar
I finally go the old rear end out. I also discovered a lot of shoddy electrical for the tail lights so all of that is coming out. I am having trouble with the trailing arm bolts but soaking them in PB Blaster should work. I also found the rear springs to be cut and not attached to the trailing arms. So now I need springs both rear wiring harnesses and brake parts. Soon as I get the arms off they are going to the powdercoat guy.
66 shorty
donthekawguy is offline
Old 04-12-2013, 04:34 PM   #7388
hopped up
hopped up's Avatar
Nice!! This body style def loks good with well placed scallops!!
hopped up is offline
Old 04-12-2013, 05:14 PM   #7389
Coboyle04
Coboyle04's Avatar
installed intercooler lines as well as my new lense covers and e brake cable...project is beginning to move along
Chuck
Coboyle04 is offline
Old 04-12-2013, 05:28 PM   #7390
gofastnut
gofastnut's Avatar
Pulled of the stinkin carb for a rebuild! Cause now that I've got it registered and insured it won't start! GRRRRRR!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline
Old 04-12-2013, 06:49 PM   #7391
gimmy 64
very nice. i like the color and the scallops
gimmy 64 is offline
Old 04-12-2013, 07:07 PM   #7392
SCHRUMGMC
SCHRUMGMC's Avatar
I like the Paint Job man !!
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 04-12-2013, 07:51 PM   #7393
markeb01
Senior Enthusiast
markeb01's Avatar
Filled the truck with gas this morning and used it to haul a load of metal to the recyclers.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-12-2013, 07:56 PM   #7394
SCHRUMGMC
SCHRUMGMC's Avatar
Trying to get my truck
1971 GMC Sierra
1959 GMC 100
Old 04-12-2013, 08:26 PM   #7395
robber grin
I had my rear end handed to me by this transmission tunnel cover today. It's welded up and "patched" but I need to finish outside in better light because of pin holes and a couple of thin spots.
lowslow64 that's some swanky paint - I like it.
Chuck - tail lights are cool too.
Living the dream -
rg
robber grin is offline
Old 04-12-2013, 10:48 PM   #7396
ChrisDollins
ChrisDollins's Avatar
Had a good day with the truck. Pulled it in the shop to change the oil, then tinkered a little afterwards. Fixed the sticky column shifter, and loose column bearing.. (my fault). Truck drives like its new again! Very happy!
Chris
ChrisDollins is offline
Old 04-12-2013, 11:23 PM   #7397
akaupp
Today I swapped out the voltage regulator and adjusted the headlights. Hopefully tomorrow morning it will still start...
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline
Old 04-13-2013, 12:59 AM   #7398
Trsmotrhed
Trsmotrhed's Avatar
Cool diesel in there. What engine and drivetrain?
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 04-13-2013, 05:20 PM   #7399
tincan1966
tincan1966's Avatar
Installed power steering box on the '65 daily driver. Made my own adapter plate. Just need to get new hoses and connect steering column with new u-joints and shaft. Going to install front drop springs tomorrow.
tincan1966 is offline
Old 04-13-2013, 07:13 PM   #7400
sixTsix
after recently finding a major fuel leak,(q-jet dumping fuel from accelerator pump, gaskets ect..) i decided to purchase a new holley 1850 series 600 cfm carb instead of rebuilding it .....the ol q-jet is done .....looks like tomorow ill be having some some fun with the old girl again
sixTsix is offline
Closed Thread
