#51 |
Active Member
![]() Join Date: Dec 2004
Re: 1972 Chevy SWB 4x4 First Project. Pics
I found the truck about 30 miles west of Brookings in the country sitting next to a garage
![]() I plan on looking over the frame good before I make a move to repair it. I will post some pictures of the frame. Is their something up in the steering that rotts away? I believe the truck is bowing that way form the rusted through frame in that spot. The other side seemed much better.
_________________________________ 1972 Chevy SWB 4x4 350 4speed |
#52 |
I have done that I put the wires on backward on the selenoid
1968 c10 250/3spd ![]() |
#53 | |
I wish I was a cowboy
![]() Join Date: Apr 2008
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
#54 |
it is a good looking truck for sitting for 4 years running a jumper is a good way to test the motor when your key is not working but like you said it is only temp until your new distributor gets there. anyway good find. Good luck with your frame
#55 |
Active Member
#56 |
Thats not gonna be an ez fix...
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB 1967 Custom Short Fleet - 327/4spd |
#57 |
That frame is rough.
It is VERY easy to take the bed off these trucks. Pulling the bed will make the frame much easier to work on. It looks like the cross rails on your bed are toast too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#58 |
Picture's like that sure make me glad I live in california.
#59 |
set your points to .018/ or use a dwell meter and set the dwell to 28-32. The purple wire in your pictures comes from the key to the s side of the solenoid, then a black wire goes from the I side of the solenoid back to the - side of the coil. This gives you full 12 volts of power to the coil while cranking for easier starting.
#60 |
the main wire from your ignition switch to the coil is a resistance wire that only allows about 6 volts to the + side of the coil. You should check the voltage at that point. Good luck, nice project.
#61 |
They call me the Breeze...
![]() Join Date: Jul 2007
Yikes!! That frame is very bad, personally I would try to find a more solid frame if possible...
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
#62 |
I hate to say it but that frame is junk. It would take even an experienced welder way more time and metal than it is worth.
If you really want one of these trucks save your money for something better, or at least a good frame to start. Although the bed rails look like toast also. I hope you don't plan on driving that truck..........Bummer for sure. EDIT, did the prior owner warn you about the rotted frame? I think I would be looking him up for a refund. chas
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van Last edited by chas350; 01-02-2009 at 10:29 AM. |
#63 |
Active Member
Would it work to splice in new frame rails the same as guys shorten long box frames? I dont drive the pickup it just sits while I frame hunt.
#64 |
when you mount the the started check to make sure that the leads are touching the frame if both are it doesn't matter if you turn it off it will try to turn over
#65 |
Active Member
I have had the truck running. The starter works fine. I put in an HEI distributor the other day and had it running for a short time.
#66 |
good deal. yeah i almost turned something as easy as started installation into a nightmare for my hands. i thought that i had the battery disconnected already and i didn't the started arced and started alsmot ripped my fingers off...... thats why you don't get drunk and work on your truck lol
#67 |
Active Member
I am fairly certain it was the bendex in the starter. Im not mechanic but it fixed the problem for me putting a new starter in. I try not to work on my truck drunk but hung over is another story ha.
