#51 |
Re: 1972 GMC Shorty Conversion
A few more pics...
#52 |
And more...
#53 |
All for now...
#54 |
Look what I found on Craigs List... a 1970 Chevy 3/4 ton coil spring frame. I was able to buy just the back half of the frame which will have everything I need to go ahead and swap over to a coil spring/trailing arm set up. I figured I should just go ahead and do the swap now since I have the truck tore down this far.
Now the fun begins - grinding/drilling/removing the 26+ rivets on the original leaf spring chassis (leaf spring hangers, shock mounts, crossmembers etc) and the 35+ rivets on the trailing arm frame. Here's a few pics... the seller even delivered it. |
#55 |
How much do you plan on lowering.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#56 |
#57 |
Nice work, thatīs a flawlees GMAW weld. It seems you are a good welder.
#58 |
Did you use an assortment of grinding disks to level your welds on your box or grinder all the way? Im posting a little late but I am at the stage of grinding my box welds off after shortening the box in the front and back.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 01-26-2010 at 12:56 AM. |
#59 |
Sorry for not getting back to you sooner. I used an assortment of 4" sanding discs on my Makita grinder. No hard discs... only flexible aluminum oxide sanding discs. I believe I started with 36 grit and finished up with 60 grit.
#60 |
wow....great job....great welding!
#61 |
I can see those disc's doing a lot better job as compared to a hard disk that risks going so deep. Thanks for the advice I'm sure it will come out alot better now.
#62 |
awesome build man can't wait to see more ur skills are amazing
#63 |
The paint on the cab looks good; you gonna paint the box to match or redo the works?
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
#64 |
I wish the paint looked as good in person as it does in the pics. The truck needs to be repainted. The paint on the hood/top of the fenders is faded and the clear coat is breaking down. Eventually, I pull the truck completely apart for a repaint, but not anytime soon. I've been thinking about what color/colors I would paint it when the time comes, but I'm undecided.
#65 |
Any thoughts on Patina? Give it a light sanding and she'll look great.
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" ![]() ![]() |
#66 |
Made some progress today.
I picked up the bed from the sand blaster... they did a great job! I spent a few hours removing the crossmembers from the donor frame. I removed over 60 rivits... ouch. Anyway, got the crossmembers all cleaned up and ready for paint. Some pics... |
#67 |
A few more...
#68 |
All for now.
#69 |
Made some progress today. Removed all the leaf spring crossmemberss and hangers on the GMC frame in preparation for the new coil spring crossmembers. I got all the new crossmembers in place and ready to drill.
Some pics. |
#70 |
![]() Join Date: Apr 2005
Just and FYI, the rear crossmember in the last picture SHOULD NOT be square to the frame. It should be further to the rear on the passenger side.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#71 | |
You can't tell from the pics, but its actually longer (farther back) on the passenger side by over 1". I measured all the crossmember locations on the doner frame before I removed them. The passenger side measurement was about 1 1/8" longer than the drivers side. I placed the crossmember accordingly on my GMC frame, you just can see it the pic. This pic shows the angle. |
#72 | |
#73 |
Hey Rob, I've always kinda wondered about this - just figured it was a track-bar thing? Is it?
#74 |
That bed looks amazing after sandblasting, I thought you would still be able to tell where you welded though. You know with this forum my build will be alot better that going solo. What a wealth of information on here to absorb.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 02-02-2010 at 11:08 PM. |
#75 |
Hi all -
The big brown truck delivered some goodies. All ECE stuff... rear 6" lowering kit which includes coil springs, KYB shocks, u-bolts, super track bar and a shock relocator kit. The shock relocator kit was on back order but Jeff from ECE said I should have it late next week. I also ordered up some new spring cups/bolts, trailing arm bushings, trailing arm bolts and axle saddles/perches. My donor 12 bolt rear was from a leaf spring truck, so I'll need to install the correct axle perches to work with the trailing arm set up. Once the shock kit arrives, I should have everything I need to wrap up the rear end install. I plan on installing exhaust cut-out/pass thru in the center crossmembers so I stopped by the local metal supply house to pick up some 4" OD pipe. I also picked up some 1/4" plate for the c-notch. Should be a productive weekend. Here's some pics - |
