Old 05-15-2005, 07:35 PM   #51
SCOTI
SCOTI's Avatar
Originally Posted by drink2mny
.... Brackets and rotors are heavy to ship.
Sorry we don't sell just the brackets.
OK, the rotors are heavy & 'up' the cost w/shipping. Why not sell just the brackets & calipers as a kit & let people get rotors locally?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-15-2005, 08:05 PM   #52
FirstGen
Just Don't Stop!
FirstGen's Avatar
Or just sell the brackets...
Not to be a jack but why would I want to spend $350 when I can get the same thing for $300 or less from TSM?
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 05-15-2005, 10:59 PM   #53
drink2mny
drink2mny's Avatar
I'm not going to get into a how we do business thread.
Pertaining to the 10 bolt and 12 bolt kits, the rotors are already turned to fit your axle.
Plus there are differences in rotor manufacturers. there are slight thickness differences that we have come across since being in the rear disc business for 5-6 years.
At that point it became a liabilty issue for us.
When you buy a kit we gladly give you all and any info about the products you will receive, but not before hand.
It is the customers choice to get a caliper cheaper and always the same no matter were you buy it to go with the brackets and rotors, than to have you get a wrong rotor or have a machine shop mess it up, then you come back to us upset about our products and how it doesn't seam to fit or work right..
But Like I said, We support this board and are here to try to correctly answer any questions you guys have.
But mainly we are just an option. As to there is alot of info on the net and other places to buy than us.
If you guys have any questions just PM me.
I am sorry to RagedJim for taking over his post..
Support The Board
drink2mny is offline   Reply With Quote
Old 05-15-2005, 11:22 PM   #54
SCOTI
SCOTI's Avatar
Fair enough.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-15-2005, 11:27 PM   #55
Shane
Shane's Avatar
Why machine the rotor ... why not just pull the axle and machine the lug flange ... then you can go to AutoZone / Pep Boys / Local Supplier and buy "off the shelf" peices that don't require machining?
Not meant as a flame, that's just the way I did it. Thinking ahead .. I can machine the axles ONE time and skip that process if I ever have to replace the rotors.
Just my thoughts ... not meant as an insult or put down to anyone.
Shane is offline   Reply With Quote
Old 05-15-2005, 11:27 PM   #56
knight_182
how easy is it
i was wondering how easy it is to switch the front disc brakes,and if there is anything u messed up on that i might need to know.thanks alot
knight_182 is offline   Reply With Quote
Old 05-16-2005, 12:13 AM   #57
SCOTI
SCOTI's Avatar
This was my logic as well. I just don't understand getting something like rotors from out of town. It's so much easier to go down the street to the local supplier in the event of an issue or when wear dictates replacement.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-16-2005, 02:24 AM   #58
FirstGen
Just Don't Stop!
FirstGen's Avatar
Exactly.... took the words right out of my mouth!
TT LSA/6L90e/9"
Old 05-16-2005, 02:32 AM   #59
FirstGen
Just Don't Stop!
FirstGen's Avatar
I really don't see the big issue when you are talking about slight differences in rotors from different companies espically when we are using them on the rear which everyone knows only does 10-30% of the vehicle braking anyway...
I might be concerned about the quality of the rotors I put on the FRONT of my truck but honestly I think that just about any mass manufactured rotor would be fine for the rear on my truck.
Maybe I am missing something here?
I was also going to note that I already have aftermarket axles in mind that have a smaller center bore so that I won't need any machining work done. I also already run 14mm studs all the way around so redrilling for the smaller factory studs is not an issue. Interested in selling only the brackets as a one off sell? Seems like marketing 101. PM me if interested...
Thanks.
TT LSA/6L90e/9"
Old 05-16-2005, 07:44 AM   #60
1low1967
1low1967's Avatar
Can I get a copy of the drawing please. Did you find out if they will work witht the caddy rotors yet??
gtiracer55@hotmail.com
Thank you very much
1low1967 is offline   Reply With Quote
Old 05-16-2005, 08:46 AM   #61
drink2mny
drink2mny's Avatar
All you guys are absolutely right.
But what you forget is there are alot of people out there that don't have the capabilities or don't even want to mess around with machining.
They just want a bolt on kit, which is what ours are...
Thats also why we sell custom kits. We are the only ones that have the widest variety of custom made and the ones on our site.
And as for ordering rotors from out of town, we don't ask you to buy rotors from us we just give you stock numbers to the ones we use so you can buy them at a local auto parts store.
Support The Board
Old 05-16-2005, 10:40 AM   #62
SCOTI
SCOTI's Avatar
....And as for ordering rotors from out of town, we don't ask you to buy rotors from us we just give you stock numbers to the ones we use so you can buy them at a local auto parts store.
Ok, now that makes sense.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-16-2005, 10:59 AM   #63
FirstGen
Just Don't Stop!
FirstGen's Avatar
You mean after the origional purchase which includes the rotors correct?
Thanks for taking the time to explain everything.
Taylor
TT LSA/6L90e/9"
Old 05-16-2005, 11:12 AM   #64
drink2mny
drink2mny's Avatar
No problem.
Yes, after the original purchase.
Later.
Support The Board
Old 05-16-2005, 12:38 PM   #65
raggedjim
raggedjim's Avatar
Sorry guys I have been out of town... To those who have requested a copy of the AutoCad drawing it will be Friday, I have alot of travelling to do for work this week.
As far as the caddy calipers, I hate to admit I haven't tried it.
I don't want to mis-lead anyone with this post. If you have the resources (AutoCad, CNC, machine tools) you CAN do this, but as I mentioned before, if you don't have the resources and don't like figuring things out, BUY a kit! You'll have fewer problems to work out.
I have tried to let everyone know the problems I have had messing with these trucks so far and will continue to as I progress (SLOWLY I admit...)
Don't worry about adding to this post, I have thick skin and I have been around long enuff to know that there are many ways to do things, some easier, some cheeper, some better. My way is only one way, and I can't say it is the best.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 05-16-2005, 12:42 PM   #66
raggedjim
raggedjim's Avatar
Knight 182, front discs are a whole different topic, try looking in the suspension board, it too has been beat to death...
Good luck, Rg
Old 05-17-2005, 08:08 PM   #67
1970chevy
Looks good their but why did you use the corvette master cylinder was their lot of fabricating to put that master cylinder.Do you have any pics of the master cylinder
1970chevy is offline   Reply With Quote
Old 05-19-2005, 09:52 PM   #68
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I have decided to buy a weld on bracket when doing rear brakes on my Dana 60 rear. The problem i have is that I am cutting down a Dana 60 to fit my 92 stepside truck. I want to keep the 5x5 bolt patern on the wheels. Also I hav to put new housing ends on and mixing the 5x5 rotor with a ford housing end isnt easy to find with a bolt on kit. So Im using a weld on bracket with a 78 caddy seville front rotor 11 1/4" and a 82-92 camaro front caliper and pads. I may have to machine the axleto fit but thats no big prob. Just set the brackets up on the rear set the caliper into place with pads. Take a air chuck and apply pressure to seat the pads and line everything up. Put on a few tacks to hold the bracket to the rearend. After that pull it apart to finish weld. The brackets are only like $18 a piece.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-19-2005, 10:03 PM   #69
FirstGen
Just Don't Stop!
FirstGen's Avatar
Not a bad idea, where did you get the brackets from? Have a pic?
Thanks.
TT LSA/6L90e/9"
Old 05-19-2005, 10:23 PM   #70
Shane
Shane's Avatar
do a search at Speedway Motors ... they have brackets for most anything concerning rear discs.
Old 05-27-2005, 04:33 PM   #71
a1gatorz
a1gatorz's Avatar
Now I'm realy confused...
Maybe I'm slow, but are you now stating that I can purchase just the brackets and as a bonus to your custamers you're willing to provide correct P\N 's to purchase rotors localy? Sorry if If I'm being a dumba..
a1gatorz is offline   Reply With Quote
Old 05-27-2005, 05:22 PM   #72
FirstGen
Just Don't Stop!
FirstGen's Avatar
No he is not willing to do that.
TT LSA/6L90e/9"
Old 05-27-2005, 06:28 PM   #73
KdawgS10
keller
KdawgS10's Avatar
hears a question for you all.
whats my options for a 83 dually for a dana 70 under it?
it needs rear brakes and I despise drums.
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Old 05-27-2005, 06:45 PM   #74
drink2mny
drink2mny's Avatar
Blackbirds Is the only place on the net that sells a dana 70 dually kit.
http://www.blackbirdscustomtrucks.com/index19.html
We are an option.
Support The Board
Old 05-31-2005, 03:09 PM   #75
Wasted Income
Boosted Member
Wasted Income's Avatar
Hey Roger,
I was just wondering if you (or anyone else who you've already sent it to) can send me the AutoCAD file of those brackets?
Thank you much!
-Jeff
jwjost@mtu.edu
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
