Old 06-15-2004, 06:02 PM   #51
Quagmire
A splendid one to behold
Quagmire's Avatar
Originally Posted by 86 Red_Bowtie
Pic's of a LS1 Motor in a 68 Chevy
that is a clean truck there. if i'm not mistaken, i got some pics of that exact truck at the starbird's show in okc back in january.
do you know who owns it?
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 06-15-2004, 08:11 PM   #52
Vince M
Vince M's Avatar
A couple of places for info on the LS1.
LS1.com
LS2.com
They have forums and parts for sale much like this site. I got my wiring diagrams off of ebay for a fraction of the original cost. There are also VATS bypasses available and O2 sensor bypasses if you eliminate the catalytic converters.
No matter what the PCM is going to have to have some programming. You can send it to someone but for about the same price you can get the software and cable if your computer savy(laptop needed). Most of the software is keyed in some form or fashion. Some are VIN specific, some are model and year specific. Some of the handhelds have limited functions and some are only readers. I'm probably gong to go with the software which will alow tuning the motor over and over. You'll need to change the gear ratio, tire diameter etc in the PCM. Visit the websites above and you'll get a good idea of what stuff works and what doesn't.
OK nuff for now.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 07-07-2004, 11:44 PM   #53
Quagmire
Quagmire's Avatar
well i lied, not the same truck i was thinking of. either way, it's still pretty trick ride... check it out!
67 swb
02 wrx
Old 07-08-2004, 08:56 AM   #54
piecesparts
Parts and more parts
piecesparts's Avatar
The plans are to put a LS-1/4L60E motor/tranny combo, out of a 2000 'F' Body, with a cam upgrade and intake changeout in a 1968 Chevy short bed. The finishing toucheswill be Street and Performance, to get a one place fits all deal. They have their own Wiring harness and electronics Guru, that can match the PCM to the cam profile. The engine will be painted to match the exterior truck color and the intake will be polished along with the valve covers. This all will be run through the 3:73 posi rear gears. I am always looking for other installs for ideas.
piecesparts is offline   Reply With Quote
Old 07-08-2004, 12:18 PM   #55
FirstGen
Just Don't Stop!
FirstGen's Avatar
Good plans. I have a 6.0 liter LS1 and a T-56 6 speed going in my 68. The truck motors 4.8, 5.3, 6.0 are considerably cheaper than the 5.7 and have a better intake although it isn't nearly as pretty as the LS1/6. All the LS1/ Gen III motors have interchangable bottom ends along with valve train parts and MANY others. You might look into other options for the wiring harness, I am having one built by Jared at Current Performance (currentperformance.com). He builds these from scratch all the time to give you the cleanest look possible and can give you any length of lead you need for your PCM (if you want to mount it in cab or whereever. Speed Scence Wiring is another one.
Just some ideas...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-08-2004, 01:47 PM   #56
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
heres 1 i found
the other one i haves pic is too big but ill send more to anyone who wants it. the truck is a huge 4 door with modern dash and suicide doors.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 07-08-2004, 03:15 PM   #57
Quagmire
Quagmire's Avatar
Just some ideas...
even the 6.0 is cheaper than the 5.7? well, not around here anyway. maybe i need to make a trip down to dallas... you guys have the hookup down there at a salvage yard or something?
67 swb
02 wrx
