#51 |
You get what you pay for
![]() Join Date: Dec 1999
I don't have any way of recording sound. I've been putting off buying a digital camcorder. Maybe one day I'll break down and buy one. Until then, you will have to take my word for it.
![]() It is much quieter. Even my 16 yo son, who never says much about my truck (he's a skateboarder, what do you expect), said it was quiet. He says he liked it better with the Aeros because it was louder. Of course he would. He's a teenager and likes loud noises. ![]() I was hunting for a quieter system, I have found it. Don't get me wrong, it is plenty loud if you stand behind the truck. What I like about it is I can now listen to my MP3's and not get headaches. ![]() As for going to school to learn how to weld. That's out. I had enough of school when I had to go. I don't want to learn to weld bad enough to go to school to do it. |
#52 | |
DAMN, I love Big Blocks!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#53 |
Professional Grade
Hey Swerve -- what did you do with your old Aeros?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#54 |
Brandon (79BIG10) has them.
Mike 1985 Chevy C-10 |
#55 | |
www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#56 | |
![]() It's ok. I painted one ford blue. My 79 had a POS Legit rebuild in it. Thye paint the engines pontiac blue. Well I was doing a timing chain decided to drop the pan and pull the oil covers and reseal that leaky motor. The ford blue paint and the pontiac blue was side by side ant Auto zone. Thought I grabbed the pontiac but managed to grab the ford. So there I am 8pm just cleaned and sanded oil pan, valve covers and timing chain cover. Start to spray and realize what I have done. Too late now so finished the job. put the parts on. Then went to piss off my diehard Chevy buddy who is also a ASE mechanic that I generaly bug if I am having a problems. So I go over his place and tell him cant get it to run right. he has me pop the hood. Hood goes up and slams back fdown about two seconds later. He says "I found the problem. somebody snuck in there ant put some POS ford motor in your chevy". He refused to touch that motor ever again LOL. ![]() OK sorry for the hyjack. OK Capt KAOS what you got that will fit my 454 Burb that's not so loud? it has 2.5 inch down pipes and the rest of the system is 3 inch after the Y pipe. I honesly wouldn't mind loosing the Y pipe and putting on a X pipe. It's 3/4 ton and I'm emissions exempt but I would like to remove the Y without damage so that if I sell it I can reinstall it and not have a issue with compliance brought up. Just toss the factory system in the rafters for now.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#57 |
I'm not 100% certain of the era, but ALL Chevrolet built engines were "Chevy Blue" for a period (77-84??). At least every one I've ever worked on, L-6, V-6 or V-8.
#58 |
They started painting them GM corporate blue when they went to the same small block in all makes, ie, Buick, Chevy, Olds, etc. My 85 came with a 305 of course and was blue. 86's are blue. I'm not sure of the 87 pickups, but the one in my 87 van is blue, so is the 305 in my 92 van.
#59 | |
#60 |
Right turn Clyde
Do you have any installed pictures? Im wondering how it tucks and the double hump crossmember are. What did you have to have enlarge (cats?) or the system?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#61 |
This is the only pic I have that shows anything at all. I should have taken some before taking it off the jackstands. It's tough to get any good pics of it with it on the ground since my truck is so low. It tucks real well and you can't even see it from the side of the truck, well except for the tailpipe that is behind the axle and turns out behind the rear tires.
I had to enlarge the adapter pieces it comes with. It comes with 2.5" pipe in front, 2.5" in/out mufflers and 3" tailpipe. They supply two adapter pieces that I gathered were for hooking the mufflers to the tailpipe. The adapters were the exact same size as the muffler outlet on one end and the tailpipe on the other. It could have been welded but no way of slip fitting together. ![]()
#62 |
Right turn Clyde
If I read that right, the adapters needed to be about 1/8 bigger ID in and out to slip over for the mufflers and tailpipes?
I am more than likely getting the pypes system. ![]() ![]() Does it fit well around the transmission crossmember being a double hump?
#63 |
Yes, it fits great around the crossmember, although I do have cats which I mounted behind the crossmember for heat reasons. My truck is lowered 4/6 and even the 3" pipes go over the axle real well and fit nice.
You are right on the adapter pieces. I had to enlarge the small (2.5" end) to fit over the 2.5" muffler outlet. I enlarged the 3" tailpipe ends instead of the adapter so all slip fit joints would be going inside the next piece. If you were welding (what I am still planning on doing), it wouldn't matter which end went where. Edit: I meant to add that the x-pipe fits the spaces in the double hump crossmember perfectly. |
#64 | |
Apparently I missed this. A Burb is shorter than a LWB pickup, so I would think if you had some downtubes made to replace the Y pipes you could use this system. Currently this is the only one they make for out years.
#65 | |
If it is a few inches different it might be more of an issue on a 2wd?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#66 |
Yes, they are only 2" of difference. Kit was designed for headers and was mocked on a 4x2. Wouldn't think you would run into many problems if it was a 4x4 since it goe under everything.
#67 |
Captkaos, I could swear I posted this in this thread somewheres, but anyways..... Will this system hang from the stock dual-exhaust equipped hangers, or do you have to use those cheesy aftermarket hangers?
#68 |
Marc,
They come with the cheesy aftermarket hangers. I don't know if you could use the existing ones, Swerve might, but you could weld hangers to the pipe if you wanted I guess.
#69 |
Tonawanda 454
take it to a local shop, ask them if they can raise it on a lifter or when you go to get it welded, take some pics, i am looking for something like this for my 76GMC
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
#70 | |
Saving penneys. When I have enough I'll drop ya a line. ![]()
#71 | |
#72 | |
#73 |
As you can see in the pic above, I have a hanger at the back behind the axle. The hangers up front are on the front end of the muffler and hung from the crossmember piece where the fuel lines and wires go for dual tanks, right at the back of the cab.
