Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 09-17-2004, 09:10 PM   #51
clay68c10
clay68c10's Avatar
Has anyone thought about the set up like the 70's Internationals? Filler neck is behind the door (in the same area as our trucks), but the tank is under the floor and bed... I always thought that would be an interesting way to do it. Hard to do if you have dual exhaust. Maybe a 73-87 tank would work.... Just something I thought of when working on pop's 73 IH.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline
Old 09-19-2004, 01:30 AM   #52
Nixon
Nixon's Avatar
Talk about a bomb!!!
As I recall, Chevy has been sued for their outside the frame rail tanks on these year models. Seems in a T-bone collision they do a pretty good job of blowing up. I have seen some video and its not pretty. It wasn't really a recall because of the vast number of these trucks out there. It wasn't financially feasible. So what Chevy did was send all registered owners of these year models a $500 gift certificate towards a new vehicle if the owner also traded in his affected truck.
To make a long story short. I certainly wouldn't entertain this idea for a second if a class action suit has already been won against the factory's version.
My girlfriend caught me cheatin on her with another woman and now she's threatening to tell my wife!
____________________________________
71 Chevy lwb Rough and Ready Baby!!
Nixon is offline
Old 09-19-2004, 09:38 AM   #53
Joe67
67 is sold
Yep - Considering the location of those 73-87 tanks, I wouldn't put one in mine intentionally
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline
Old 09-19-2004, 10:52 AM   #54
obsesive23
Who me?
obsesive23's Avatar
I installed a new poly blazer tank in my 68 and even though it installed ok and works fine, It does hang low and when it gets a v8 I'm gonna give fuel cell guy a call.
Living the dream
72 2WD Blazer, under going porter built surgery
67 GT Mustang fastback
67 Mustang coupe C/S clone
64 Falcon sprint hardtop
obsesive23 is offline
Old 09-22-2004, 03:34 AM   #55
Kas68c10
Kas68c10's Avatar
I will add my two bits....The video you refer to was worse because- I think,it was Dateline NBC actually put explosives in the car to make the explosion look better, for ratings. However, they did explode on impact and that is bad enuff. I called the National Transportation and Safety board when I put my tank in the back. They have no records of in cab tanks exploding, but then the records dont go back past the 70's. His concern was of a leak/gas smell in the cab, and a dropped cigarette, not so much side impact. He did recommend moving it though, and using a outside the frame rail tank was a no-no. I found a van tank at the wrecker and used it, no one even saw the tank but it only held 11 gallons.I odered a poly tank from GMC paul, put a hitch around it, and I can hold over 20 gallons now. I am at stock height though, if I lowered it I would probably go back to the other tank. If anyone wants it, let me know.....
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline
Old 09-22-2004, 06:24 AM   #56
Russell
Professional Grade
Russell's Avatar
I just finished installing a 31 gallon Blazer tank from a 78 Blazer, other than sitting at a slight angle (I wanted to use the skid plate, otherwise you can use the factory brackets already on your truck and have the tank sit perfectly level, at least with a 73-87. The tank sits about an inch higher in the front than the back, no big worry. I can fix the incorrect gauge reading by adding a resistor or capacitator as needed to make the tank's sending unit have no resistance when the tank is empty) I found the tank only sits about 2" below my step bumper, not even worth thinking about as far as clearance is concerned on a stock 3/4 ton with 32" tires...
I'm also wondering if those 67-72 blazer tanks have a vent or not, becuase my buddy is running the exact same blazer tank as I installed, and it doesn't click off at all at any gas station. I've also found that just the empty fuel tank improved my ride quality by putting a but more weight at the back.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline
Old 09-22-2004, 04:56 PM   #57
Kas68c10
Kas68c10's Avatar
My tank came with vent holes, will take gas as fars as you can pump it
Kas68c10 is offline
Old 09-23-2004, 10:06 PM   #58
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
You would have a hard time using the 73-87 tank anyway. The cab mounts are in the way.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline
Old 04-11-2005, 08:00 PM   #59
sporticus
I have a 68 c10 i might restore, the wife has seen it and hates the tank behind the seat idea, if you relocate than where does the spare tire go ?
in the bed ?
sporticus is offline
Old 04-11-2005, 09:30 PM   #60
Joe67
67 is sold
in the bed ?
The only reason I moved mine was increased legroom and to remove the big old fill tube from the side. They are actually very safe inside the cab
I don't plan to run a spare tire unless I'm on a long trip. Some guys end up putting them in the bed.
Joe67 is offline
Old 04-12-2005, 11:44 AM   #61
sporticus
I was thinking that ............................. "no spare unless on a long trip"
I think I'll relocate the tank in time and use this theory. With gas at $2.50+ even for the cheap stuff I doubt I will drive very far. I can just imagine calling my wife and telling her to put my spare in her car and bring it to me somewhere.
Old 04-12-2005, 07:18 PM   #62
70c10swb
no brain no headache
70c10swb's Avatar
so how much leg room do you gain when you remove the tank from the cab?
i want to do the same, but i dunno if i want to go with FCG or a poly summit fuel cell
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline
Old 04-13-2005, 07:59 AM   #63
Joe67
67 is sold
I'm not exactly sure how much room is gained, but enough to run some late model buckets
Joe67 is offline
Old 04-13-2005, 01:20 PM   #64
Low69CST
You don't gain any leg room with stock seats, cuz the track doesn't go back any farther?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline
Old 04-13-2005, 06:29 PM   #65
70c10swb
70c10swb's Avatar
yeah im probly going to run OBS buckets or buckets from a late 2nd Gen TA
1996 GMC Sierra z71
70c10swb is offline
Old 04-13-2005, 08:59 PM   #66
Joe67
67 is sold
I'm partial to the NBS (new body style) truck buckets because the seat belts are already integrated, but I have a couple of other ideas mulling around up there
Joe67 is offline
Old 04-13-2005, 09:17 PM   #67
70c10swb
70c10swb's Avatar
yeah ive thought about the nbs buckets too but ive heard that they mount higer up. im 6'3 and i dont want to thwap my head off the roof
1996 GMC Sierra z71
70c10swb is offline
Old 04-14-2005, 02:01 PM   #68
Dano69c10
Dano69c10's Avatar
I think there has been some confusion about which "truck shop" some people are refering to.
The "Truck Shop" that has the conversion (fuel tank, mounting straps, fuel sending unit, O-ring seal and lock ring for the sending unit) for $166 is;
Truck Shop
739 North Batavia
Orange, CA 92868
1-800-243-8947
www.truckandcarshop.com
Hope this clears up the confusion
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 04-14-2005, 02:30 PM   #69
rays68
I just called to order one and the new price is 173 + tax since im located in california. still not a bad price
rays68 is offline
Old 04-14-2005, 04:59 PM   #70
Dano69c10
Dano69c10's Avatar
Sorry for the price misquote; was looking at their 2005 catalogue.
Dano
'69 Fleet
Old 04-14-2005, 06:14 PM   #71
72BLAZERDUDE
72BLAZERDUDE's Avatar
I got the one from www.truckandcarshop.com to replace the dented one in my Blazer. It was 203.00 to my door complete. As far as the tank in the cab I know there was something on one of the news programs a few years back about older trucks with the filler neck on the side of the cab and in a roll over on the side the filler neck was sheared off and all the gas that was in the tank came out.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline
Old 04-15-2005, 12:28 AM   #72
TheRedRooster
What about the 69/70 mustang 22 gallon gas tanks? I heard those drop right in between and bolt on to the rails. The demensions of the tanks are 30 1/4" x 22" x 9 3/4". What are the demensions in between the back rails?
If this works, new galvanized steel mustang gas tanks run around $100.
Anyone have experience with this?
TheRedRooster is offline
Old 04-15-2005, 07:51 AM   #73
72MARIO
72MARIO's Avatar
I think my frame rails were 27 1/2 wide x 20 deep with the the ECE crossmember.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 04-21-2005, 12:03 PM   #74
ChevyDude
Just sent Mark AKA ....FuelCellGuy, a PM to get a tank built!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline
Old 04-21-2005, 01:19 PM   #75
71swb4x4
71swb4x4's Avatar
You will be happy with that tank...I love mine!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline
