Old 01-04-2005, 08:09 PM   #51
nate68
does anyone know how much of a weight savings these are?
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 01-04-2005, 08:36 PM   #52
XXL
Seņor Member
XXL's Avatar
Insignificant at best.
XXL is offline   Reply With Quote
Old 01-05-2005, 05:32 PM   #53
smbrouss70
smbrouss70's Avatar
What about the sway bar mounts? Will they accept the factory style sway bar with two bolts on either side or do you need an aftermarket type with the single bolt endlinks?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-03-2005, 12:34 AM   #54
72dually
72dually's Avatar
Just curious if the price has changed on the complete coolride w/arms as posted by shev from suicide doors?
I already purchased there plates and cups a couple month's ago, guess I wont be using the cups if I decide to go this route
72dually is offline   Reply With Quote
Old 02-03-2005, 10:00 AM   #55
SCOTI
SCOTI's Avatar
They require the use of aftermarket 'end-link' style sway-bars.
I don't know about the prices from SD's, but the plates will need to be notched @ the bag mounting holes as the AirRide arms move the bag slightly forward vs. a stock lower a-arm w/cups & bag.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2005, 01:03 PM   #56
Shev
Head Peon
Shev's Avatar
The SD deal is still good...just tell Jason which board you saw it on. I would just order a set of Art plates when you order the arms (they are only like $25 for the set) and sell the kit you bought already. If you buy the complete coolride kit it comes with the correct plates...
Ooops...forgot one thing, you could always send back the SD kit you already have and get full credit for it...one of the great things about Jason, no restocking fees...
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 02-03-2005, 01:58 PM   #57
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I just noticed this thread and just wanted to say cool pics. (I know I am late, but it bumped the post again.)
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-03-2005, 09:19 PM   #58
72dually
72dually's Avatar
Thanks for the reply's
Im considering the whole shabang, but I'd like to hear from all sides, I love the detailed write up by MrShelley, who didnt do the arms, and I see the detailed write up this month (march issue) of StreetTrucks on the strong arm coolride set-up, but this is a magazine feature, which are known to sugar coat. Are the strong arms that exceptional?
Old 02-04-2005, 12:21 AM   #59
SCOTI
SCOTI's Avatar
..... I love the detailed write up by MrShelley, who didnt do the arms, and I see the detailed write up this month (march issue) of StreetTrucks on the strong arm coolride set-up, but this is a magazine feature, which are known to sugar coat. Are the strong arms that exceptional?
They are well built & look nice. They correct geometry issues that arise from lowering. They can use either rubber or poly bushings, whichever you prefer. Their down side? . . ..... Cost.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-04-2005, 09:48 PM   #60
72dually
72dually's Avatar
Thanks SCOTI..........I understand the benefits, and yes there perty, but Im curious if the difference in handling/ride quality is that substancial, versus an air bagged truck w/stock control arms?
Also, how low before the geometry issue's come into play?
Old 02-04-2005, 11:37 PM   #61
SCOTI
SCOTI's Avatar
..... Im curious if the difference in handling/ride quality is that substancial, versus an air bagged truck w/stock control arms?
Ride quality won't change. The handling will improve because of better BJ angles & improved caster vs. stock arms limits.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-05-2005, 12:07 AM   #62
XXL
Seņor Member
XXL's Avatar
2° KPI instead of the factory 4°. When you drop the truck a lot without moving the KPI more toward vertical you end up with go-kart-itis in the steering... as in serious bump-steer.
Old 02-05-2005, 10:03 PM   #63
72dually
72dually's Avatar
Thanks guys, thats what I was looking for, I have plenty of expierence w/bump steer from my short track days, I should have figured that out, thanks for jaring my memory
Old 02-06-2005, 10:11 PM   #64
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
How much ground clearance is gained over stock lower arms?
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 02-07-2005, 12:41 AM   #65
SCOTI
SCOTI's Avatar
None. Where the arms attach to the bottom of the crossmember is still the lowest point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2005, 02:31 PM   #66
luckydog
< Fav Place on Earth!
luckydog's Avatar
Will the arms get you any lower than stock arms? I don't think this question has been asked yet, but I just skimmed through it.
Horsepower is how FAST you hit the wall, torque is how HARD
luckydog is offline   Reply With Quote
Old 02-07-2005, 10:43 PM   #67
72dually
72dually's Avatar
Shev...............Just a couple more dumb questions.......Im ready to buy the strong arm/coolride kit, are they only available in black, I prefer the silver, and what type of bags and brand are in this kit?
Old 02-08-2005, 11:17 PM   #68
72dually
72dually's Avatar
Can anyone answer my question, as Im getting home to late to call myself, I appreciate any details you can provide
Old 02-08-2005, 11:45 PM   #69
cysko9
MI '69
cysko9's Avatar
i think they only come in the black, im more sure of that if you purchase them from suicidedoors... and the bags that it comes with are firestone. at least thats what they gave me
1967 Chevy (Project Frankenstein)
1973 K5 Blazer
cysko9 is offline   Reply With Quote
Old 02-09-2005, 12:44 AM   #70
72dually
72dually's Avatar
Thanks cysko9.............I was starting to think it was a big secret
That changed my mind, too some, might not be a big deal, but It changes the theme I had planned, anyone else have deals going?
Old 02-09-2005, 10:08 AM   #71
XXL
Seņor Member
XXL's Avatar
cysko9 is correct... black. But a new color is just a powdercoat away.
Old 02-12-2005, 07:00 PM   #72
72dually
72dually's Avatar
Yep, just more money, I might as well pay the extra and get what I want, plus different bags
Old 02-13-2005, 09:01 PM   #73
bagged72blaz
Got L.E.D.s
Do you think it would hurt to just buy the lower arms and upper latter? My lower arms have taken a beating.
Old 02-13-2005, 09:39 PM   #74
XXL
Seņor Member
XXL's Avatar
I don't think ART offers them that way.
Old 02-13-2005, 09:43 PM   #75
cysko9
MI '69
cysko9's Avatar
I'll just sell you my set of origionals.... they are in decent shape... surface rust. I can snap some pictures if your interested.
1973 K5 Blazer
