#51 |
I kind of liked the idea of rocking the truck in order to burp the cooling system --------tee-hee
#52 |
ureckmefixit2@cox.net
A temp sender or a themol switch. I know on roush racing uses a controler thats like the fan switch under a refridgerator. a temp sender will run your battery dead. You need something like an idiot lite sender. Matt
#53 |
PS temp senders for these trucks. Well you have to use the sender for your year for your gauge you cant miss and match. A sender for a 73 will show very hot in a newer truck, or is it the other way around. I have newer heads on my truck, difernt hole size for the sender I have a sender in each head wired to the gauge and thats the only way the gauge reads right. Matt
