#51 |
Progress = 0%
On a side note, the Borgeson joints/shafts are a little pricey, but are very high quality. True, they don't come with cool decals like the ART stuff, but the joints are engraved with the Borgeson name and part number
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#52 | |
Seņor Member
Re green arrow-- does this mean I can't shut my hood any more? ![]() Re red arrow-- I had no idea your garage wall was on the town line! ![]() OK... gotta go send out some emails, yell at some people, and approve a memo or two.
#53 | |
Progress = 0%
#54 | |
Seņor Member
At least I can put that bungie cord under the seat to use. ![]()
#55 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Slammed67 thanks for sharing. Looking Good XXL!
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#56 |
Progress = 0%
Done!
XXL just left my house and is headed back home to Wichita. Hmmm.... did I remember to tighten the lug nuts?? ![]()
#57 |
Never Done?
![]() Join Date: May 2000
That is just too freakin cool. That's just the inspiration I need to keep plugging away on mine. Just stripped and primed the frame rails today, so I've got a ways to go. Great work guys. Hey Slammed, why is your truck back apart? Got bigger plans?
#58 | |
Progress = 0%
#59 | |
#60 | |
Seņor Member
#61 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Very nice set-up guys....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#62 |
Got L.E.D.s
Slammed67 I like the 72 bumper. I had a 68 stepside with a 72 bumper on it. Lookes cool with all 4 parking lights hooked up.
Bagged 1972 2wd Blazer http://www.earlyclassic.com/home.aspx |
#63 |
MY EX DRIVES A BROOM
looks great
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
#64 |
I does look very nice. I have to avoid two roads around here as it is cause my truck is low, and it's only a 3.5/5 inch drop. The city has decided to put these monsters of speed bumps around town and I coudln't imagine trying to dodge everything driving something that low. It is awesome though.
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
#65 |
Seņor Member
Small update... apparently the oil pan doesn't do well when it comes in contact with concrete. (Who'da thought?)
Anyway, ancillary to the whole oil-pan-too-low issue, it turns out that getting the oil pan off is utterly impossible with the crossmember mod. I still haven't figured out just why/how the crossmember would be an issue, but the fact is, we are in the process of pulling the transmission and flywheel to get the oil pan off so I can fix the leak. ![]()
#66 |
What kind of oil pan you got? Is it a low profile one? How tall is it? I just bought a Hamburger one for mine witch is only 7" deep. But I need to make my own motor mounts. I will make sure mine clears the ground!
#67 | |
Seņor Member
#68 |
Hey XXL;
What size tire, wheel, and backspacing are you using on your ride for the back wheels? I am in the process of getting my frame mods worked-out and want to stuff the largest tire I can under there, but do not want to tub the box. Also, I am going with approximately 6" of drop in the back for ride-height. Lowering the rear on mine even more won't be that much of a problem as the main body of the corvette IRS stays put! I want the front to go low, but I don't think I want to go to the work that you guys have done to chop the crossmember. Sweet ride though! I can't wait till mine is back in some semblence of driveability.
'68 Chevy Stepside in Frame-up Restoration process. 292 CID Clifford Performance Modified T56 6-speed Tranny Slammed, Custom IFS and IRS Money?...Too Much! |
#69 | |
Seņor Member
#70 |
So what is the rear tire size XXL? 255s? I think that I can fit 275s, but I think that they will hit the outer lip. Guess I will have to see when I get the IRS all mocked-into position.
#71 | |
Seņor Member
#72 |
Got L.E.D.s
I'm curious to why the crossmember mod effects the postion of the engine? Would it not raise with the crossmember? If not couldn't you shim the motor mounts higher?
#73 |
Progress = 0%
I don't think the x-member mod had anything to do with the pan clearance. The height of the top of the x-member where the engine stands mount didn't change. I don't think the original design allowed for easy pan removal.
#74 |
Got L.E.D.s
I know I can't remove my pan without unbolting the motor, and jacking it up.
#75 |
Got L.E.D.s
I had a Summit 7 quart oil pan on my blazer and it never hit the ground. It didn't hang lower than the bottom of the crossmember
