Old 04-09-2005, 06:59 PM   #51
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
maybe a stupid question... in haste to get the project going, did you maybe forget the converter bolts?
Old 04-09-2005, 07:04 PM   #52
incoma
incoma's Avatar
That's a valid question. Nope, they're in there tight.
incoma is offline   Reply With Quote
Old 04-09-2005, 07:06 PM   #53
krue
Designated A-hole!
krue's Avatar
Was the torque convertor full of fluid when you installed it?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-09-2005, 07:16 PM   #54
Longhorn Man
and the shift linkage is in fact moving the shifter shaft on the tranny...not just sliding around it?
Not trying to treat you like a dummy...just trying to look at the overlooked items. I have fallen for lots of stupid mistakes.
Old 04-09-2005, 08:32 PM   #55
screamin_c102
screamin_c102's Avatar
Is it possible for the cable to fall off the valve? Bear with me on this. The th-350 kick-down cable is attached to a piece of linkage inside the tranny and if it is allowed to go slack it can come loose and fall out of the hole. Is it possible that this may be the case?
I know its a TV cable and not a detent cable, but is it possible for it to come loose in the same manner?
Just tossin' out ideas
screamin_c102 is offline   Reply With Quote
Old 04-09-2005, 10:33 PM   #56
incoma
incoma's Avatar
Krue - I did install the converter dry, but the fluid pump in the tranny pumped it full of fluid.
Longhorn Man - The shift linkage is moving the shifter shaft on the tranny. You can feel it shift the tranny. Its just nothing's catching.
screamin_c10 - I see what you're saying with the cable/valve connection. This cable attaches to a plunger with a J connection. I installed it with slack in the line, and I can feel the valve open if I pull on the cable.
I appreciate the ideas guys. I just got back from my neighbors and am going to borrow his scissor lift in the morning. I'm going to swap out these tranny's tomorrow and get this truck mobile.
Old 04-09-2005, 10:51 PM   #57
72GMC51
72GMC51
72GMC51's Avatar
Go to this link http://www.sallee-chevrolet.com/frame.html put 4L60 in the search, go to installation instructions, it is instructions on the installation of a 4L60/700r4/200r4. You can use the brake switch to engage and disengage the converter. I have this set up and it works great. Bowtieoverdrive.com also sells the same type of set up.
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 04-09-2005, 11:02 PM   #58
screamin_c102
I'm sorry man I'm outa suggestions. I hope it works out for you. Let me know what happens.
Good luck..........Bill
Old 04-09-2005, 11:09 PM   #59
jostrans68
Jostrans68
jostrans68's Avatar
I just got a deal on one out of a 85 Monte low mileage no metal in pan smells good. going to beef it a little and install 125.00 cant go wrong
plus I got the shipping case for it
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
