#51 |
Project 2 Resume
Nothing fancy. Tach mounted on the column. Idiot lights still connected and functioning. 3 mechanical gauge pack mounted where change, junk, etc. pocket used to be for a non-a/c cab. Maybe one day I'll get around to putting the dashpad back on.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
#52 |
Here is mine, yes it is accurate. I have recalabrated a few for other board members as well. If I thought about it, I'd only have made it go to 7K, but it looks good.
#53 | |
Happy to be here
![]() Join Date: Mar 2000
#54 | |
Got any pics? I'm having a hard time picturing that.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
#55 | |
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 05-26-2005 at 10:13 PM. |
#56 |
Here's mine.
#57 |
Right turn Clyde
Camaro Tach? Im guessing?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#58 |
inthe dash on the dash
#59 |
No, original GM truck tach, I recalabrated it to read 8K at full scale, and then I made a magnetic face to go over the original so I can convert it back if I want.
#60 | |
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#61 |
yeller
Here is the one I had in my Blazer, and the article I wrote for the one I put in Yeller.
http://www.73-87.com/7387garage/inte...ge_surface.htm FYI - you can mount a tach on the column and NOT have it move when you change gears...you just have to be careful with where you put the mounting strap.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#62 | |
Web Wheeler
![]() ![]() Time for a manual trans or a floor shifter ![]()
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
#63 |
Does anybody have pics of the sunvisor mounted tach?
Ben 84 C10 Silverado 14 Silverado Z71 |
#64 |
I have posted on another thread awhile back, I tried to find it but with search disabled I gave up after a few hundred pages.
Basically I use a function generator to generate the appropriate frequency to simulate the upper RPM limit I am modifying the tach to read, and eliminate the factory 'trim' resistor. I substitute a variable resistor in its place and adjust it to give the correct readings. (I do this over the entire RPM range to best match the tachs linearity with the new face) I then replace the variable resistor with a high tolerance resistor of the same measurement. Of course I check all the circuit components to make sure the capacitors are still reading the correct value and replace those as needed. |
#65 |
Re: Where did you mount your tach in a 73-87 ?
Guys i have a question im looking for tach (NOS or OEM ) to fit into my truck for 1979 Silverado 454 i found one on ebay looks like the one in the photo. My question is how to fit it into the truck? is there anything i have to buy or change in order to work>?
My truck is fully loaded. Thanx Nas |
#66 |
78K & 79C Jimmys
may want to have a look below in the 78 i went from idiots to factory tach/gauges
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#67 |
