06-25-2005, 02:29 AM | #51 | |
Pictures, lots of pictures so all of us can experience this project vicariously through Southern Mississippi. Many years ago I was stationed at Biloxi for tech school and I loved it.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-25-2005, 11:07 AM | #52 |
I know where alot of minds are gonna go on this one, so let the obvious slide and lets deal with the dash. What are the thoughts on how to mount it from the back without showing any screwing from the front. Type of hardware, etc.
06-25-2005, 11:12 AM | #53 |
67 is sold
That yellow dash is nice!
I have heard of using a glove box door for the clusters as well and it looks great with the aftermarket gauges |
06-25-2005, 05:59 PM | #54 | |
Designated A-hole!
ironed it out in my head yet. I also found a piece of stainless sheet and aluminum to try an inlay with. I don't know what putter's got in mind, but I have been thinking on it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-26-2005, 12:13 AM | #55 |
Careful, they attack...
To mount, you could drill and tap some holes, then run studs in with lock-tite. Let it set up for a couple hours and it will be good to go. Since you would be using small bolts/studs, it would be difficult to tack them in place. Maybe with a TIG...
06-27-2005, 10:06 AM | #56 |
More Cowbell....
When I did my lights in the roll pan, I welded some small diameter bolts (like 3/16) on the back side and used the nuts with nylon inserts. Should be the same with the glove box door....since it is a two-layer piece. I just have to get my hands on a box door. I don't expect that this will be nearly as involved as you might think.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
06-27-2005, 11:45 PM | #57 |
Cut the back out of a glove box door tonight and test fitted it. It looks pretty good, there was a 1/8" gap on the top and right side though. It might be necessary to cut the light switch ears off the dash for it to sit flush.
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! Last edited by ronh72c10; 06-27-2005 at 11:46 PM. |
06-28-2005, 04:00 AM | #58 |
heres a nice painted plastic dash, looks nice
06-28-2005, 02:09 PM | #59 |
Some guys are happy with just idiot lights? I know I was, until I found out about the
gauges. |
06-28-2005, 03:15 PM | #60 |
A-Adam A-Adam
That is a pretty neat Idea!
70 3/4 ton GMC Camper Special |
06-28-2005, 06:51 PM | #61 |
I want to weld studs on this one and paint it red with some black rubber trim around the edges. I am tired of the stainless look.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
