#51 | |
Thats the Hillbilly way
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#52 | |
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#53 |
I ordered the whole set up today.
APC harness Hella lights And a set of H4 bulbs having a 55/100 low/high beam. ![]() Last edited by vtblazer; 09-21-2005 at 06:21 PM. |
#54 | |
The LuvShack Garage
Just one set?, the fleets gonna be jelous ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#55 | |
#56 | |
I looked for the part numbers but I think I deleted the e-mail they sent me, sorry. I had to look under 'headlights' on their search function. Total with shipping was like $140.00 2 headights @ 55/65 1 harness with relays 2 additional bulbs @ 55/100 |
#57 |
Better late than never
![]() Join Date: Dec 2001
http://store.summitracing.com/partde...sp?part=108995
I received this in the mail today. Has anyone installed this kit? At first glance it looks like there are connectors to cut off and some splicing to do.
1970 C/10 SWB Stepside |
#58 |
The Hella E-code H4 halogen lights and lens assys are arguably the best halogen upgrade. Hella E-code H4 lenses are NOT DOT legal, though. Sold as "off-road use only." I found a site that explains why better than I have here in the past:
http://www.garbee.net/~cabell/headlights.htm Click on pic #6 and you'll go to the best pic of the H4 lens that I've found: http://www.garbee.net/~cabell/decemb...t/DSCN1361.JPG Hella's E-code H4 lenses are not simply H4 bulbs in lame (by comparison) DOT legal lenses that most every other headlight maker markets. As you can see in the second link, the E-code H4 lens assys have "H4" cast into the glass lens right smack in the middle of the lens. That cast-in "H4" is the proof you're looking for to go E-code (European) lenses in the Hella brand. I don't know if other brands offer the same E-code lens pattern with or without the "H4" cast in the lenses. As the first link's author claims, the E-code (European) beam pattern is sharper with a superior pattern than Hella Vision Plus lenses or other DOT legal lenses, IMO. The comment in the first link that other drivers are not bothered by the E-code low-beam lens pattern despite the H4 bulb brightness is what I've also found to be true with my Hella E-code H4 lenses and H4 bulbs (60/55w). They are flat lenses, as well, which makes for a cleaner look on our trucks. The flat lenses look better on IHCs and Land Cruisers, too (I've moved them around as I've changed daily drivers amongst my "fleet" ![]() I bought my 7" H4s back in the '90s after reading about them in a 4x4 mag. I still have Hella's original packaging that I keep old sealed beams in for protection. I don't know if the package info is still valid, but here goes anyway for Hella E-code H4 lens assys (with H4 bulbs): Hella Halogen Headlight Conversion Kit H4 7" High beam/Low beam Order No. 70476 (Hella Part No. 1A6 002 395-991) Includes an H4 12v 60/55w bulb. In the middle of making this post, I decided to do some research. Looks like Susquehanna Motorsports (rallylights.com) sells the E-code H4 conversion kits (marked as for "off-road use only"). Also note that one can order the conversion kit with a higher rated bulb than I have: http://www.rallylights.com/hella/headlamps.asp 7" Conversion kit: http://www.rallylights.com/hella/7in.asp Enlarged pic that shows the "H4" cast into the lens: http://www.rallylights.com/hella/hel...ages/7%20E.jpg GMC 4-headlight page: http://www.rallylights.com/hella/5.75_lo.asp Ha! As I was perusing Susquehanna's E-code page, I noticed that they provided a link to a page that explains everything about why the Europeans have headlight design right: http://www.rallylights.com/useful_info/Vision_Plus.htm With that info, consider whether you want to upgrade your truck's electricals to send full power to strong H4 bulbs unfortunately stuck behind DOT legal lenses with their inherent limitations. With just relays and H4 bulbs, you might actually offend other drivers from the extra brightness sent through inferior DOT beam pattens that have side and overhead diffusion requirements that E-code lenses lack. As Susquehanna explained, due to the DOT-mandated superfluous diffusion requirements, you won't have as much light on the road, either. Of course, you might miss some unlit, overhead signs. ![]() ![]() Made in Germany. One overseas product worth procuring, IMO. Enjoy ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 09-24-2005 at 03:56 AM. |
#59 | |
#60 | |
I ordered right off the link cause I was being lazy and didn't look around, my bad. ![]() But, yes I was mistaken about the 'HID' part, time to go edit. |
#61 | |
#62 | |
100W! ![]() I will modify the rest of the harness to work. Thank you for pointing that out. Last edited by FormerMember; 09-24-2005 at 11:45 AM. |
#63 |
On the Harness for the 9005 Hi beam and 9006 Lo beam there is a Gray socket and a Black socket which takes the 9005 and the 9006 ?
#64 | |
AFAIK, you can use the stock connectors from your truck with a common ground on that harness and still be ahead, price wise. |
#65 | |
black is 9005 |
#66 | |
#67 | |
Upgrade wire kit - part # AMC-509102 for use with a two bulb H4 set up Head lamp replacement (Hellas) part # HLA-70477 55 watt low/100 watt high beam bulbs part # HLA-78158 Ordered it all from Summit. Received it two days. |
#68 |
Alex
Sorry I haven't responded until now. I'll look at my pigtails b/c I think you can take them out and install larger size wire. I'll let you know when I find out.
#69 | |
Okay, I've installed and tested the above headlight upgrade parts. Very easy/simple installation, total plug and play set up. Having the 55watt low beam nobody flashed me driving through town and on the back roads the 100watt high beam was awesome. Really nice light pattern, both high and low. Cost was under $140 shipped. |
#70 | |
The LuvShack Garage
From where again, I must have missed that, and you really like it ![]()
#71 | |
Couple posts back bud. ![]() Yes, I like the entire set up. Simple installation All plug in applications, only need to ground the two headlight wires Good lighting pattern from the Hellas Very bright when you kick in those illegal 100 watters too ![]() Last edited by vtblazer; 09-25-2005 at 09:12 AM. |
#72 |
I got the plugs and relays and tied everything in for $18.00 to run my regular Halogen lights. That's all I needed and works great. I guess if you want the fancy lights, go for it, and the big bucks. To each his own, but are neat setups. Keep in mine that some state laws prohibit certain kinds of lighting though. Like in Maryland here, blue lights are outlawed unless came with certain newer cars.....Would be a real b*tch to put all that money into that project, just to get pulled over buy the man. Just my 2 cents worth......
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 09-25-2005 at 08:55 AM. |
#73 |
Hey mods / admins ... can we copy this post over to the "FAQ / How To" section ... this is great information!
#74 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I agree very nice mod for our trucks looks like I will have to put it on my list of things to do..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#75 |
aquik72gmc350, thanks for replying. I would be very interested in the gauge of the wire.
