Old 10-31-2009, 01:01 AM   #51
AceX
>130dB Moderator
AceX's Avatar
Re: Gauges.... Who, What, Where?
Originally Posted by 78-5.3 View Post
i called this morning and they said they DONT have a 73-87 dash bezel ???they have them up to 72 the guy wasnt clear at all!!! i told him what i have, that the harness has the wire for the speedo and tacho coming from the pcm into the cab and he told me i have to run my own wires back to the trans !!! i know thats not right!!!!
Yeah it is. These gauges are going to act completely independent of the original system. The same is true of Autometer and others.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 10-31-2009, 08:33 AM   #52
78-5.3
78-5.3's Avatar
so if the wires coing from the PCM wont work and i have to run my own wires to the trans why do they bother supplying the wires (harness builders)to hook up the tacho and speedo ???
78-5.3 is offline   Reply With Quote
Old 10-31-2009, 08:56 AM   #53
tvblazer78
Low & Fast!
tvblazer78's Avatar
Originally Posted by staggerd86c-10 View Post
tv blazer got anymore pics of your set up? what size guages are those? 3 3/8" speedo and tach and that 2 1/16" smaller ones?
I have some autometer ultra lites i was planning on installing on my truck once i get it back and i like the look of smaller guages and your set up hits the spot. Please post more pictures if you have them. Thanks.
That is what it is and here is a link to my build that has more pics of how I did it.
http://67-72chevytrucks.com/vboard/s...=232873&page=9
Thanks,
Trav
tvblazer78 is offline   Reply With Quote
Old 10-31-2009, 06:38 PM   #54
AceX
>130dB Moderator
AceX's Avatar
Because a replacment harness is configured for a stock aplication unless otherwise requested.
Living Life @ 130dB
RIP El Jay
Old 11-02-2009, 01:21 PM   #55
1979blkchevy
1979blkchevy's Avatar
Originally Posted by N2TRUX View Post
So you don't like this look? It has to be the nicest way to intergrate aftermarket gauges with a 73-87 dash I have ever seen....
wow who did this with the autometer gauges I owuld love to have something like this done if i could just find the right people to do that kind of job
1979blkchevy is offline   Reply With Quote
Old 11-02-2009, 08:10 PM   #56
78-5.3
78-5.3's Avatar
VSS Signal - This wire is a 4000 pulse per mile signal from the PCM used by some aftermarket speedometers. This can also be use for the electric cruise control boxes used on early 90s GM cars & trucks. PCM is reprogrammed to match tire size and axle ratio for you're swap, so this signal is calibrated.
TACH Signal - simply put, on LT1 with distributors, this comes from the negative side of the coil. On LS1, Vortec 4.8/5.3/6.0 this comes from the PCM, which generates this signal for a aftermarket tachometer.
lt1swap did my pcm for the gen 3 swap
Old 11-03-2009, 05:27 AM   #57
AceX
>130dB Moderator
AceX's Avatar
So he modified teh signal being sent?
Living Life @ 130dB
RIP El Jay
Old 11-03-2009, 06:30 AM   #58
78-5.3
78-5.3's Avatar
they modified both of t hem the speedo and the tacho the tacho was modifed because if you leave them they only read 1/2 the RPM
Old 11-03-2009, 05:27 PM   #59
shrtbx
I would too. I just dont have the time to work on stuff like this anymore.
shrtbx is offline   Reply With Quote
Old 11-04-2009, 07:02 AM   #60
AceX
>130dB Moderator
AceX's Avatar
That changes things...
In any case, I'm thinking seriously about picking up a set f these gauges and wiring them in. Hell, If I could do that I might be able to do away with that dam ECU.
Right now I'm working on reconfiguring the emissions system and seeing if I can get it to work without the ECU.
PS; I hate the C.A.R.B.
Living Life @ 130dB
RIP El Jay
Old 11-06-2009, 10:23 PM   #61
ghettoluxury
ghettoluxury's Avatar
Here are the ones I have been working on they are 2" Sunpro gauges with blue led backlight
Now I need a white tach and speedo
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-07-2009, 01:38 PM   #62
1979blkchevy
wow thats nice
Old 11-07-2009, 09:10 PM   #63
ghettoluxury
wow thats nice
Thanks, it was a total pita to make it turn out the way I wanted. I will post how it was done after I finish it
Old 11-08-2009, 09:58 AM   #64
1979blkchevy
yes please keep us posted
Old 11-08-2009, 10:08 AM   #65
78-5.3
78-5.3's Avatar
diesel bezel !how did you mount them??? what will you use for the taco and speedo they only make 3 3/8" i think in sunpro?
Old 11-08-2009, 10:10 AM   #66
78-5.3
78-5.3's Avatar
this is what i want !! those gauges ! do you have the part # for them all ??? did you modifly the bezel much???
Old 11-08-2009, 09:08 PM   #67
ghettoluxury
Good Eye. Sunpro also makes a 5" tach, but we will have to see what will work. Haven't found a speedo yet so I am thinking of using a white face overlay.
Old 03-25-2010, 04:55 PM   #68
RatMtr
aspeacialz were do you get the instrument bezel
email back at ebahm@amkor.com
thanks
RatMtr is offline   Reply With Quote
Old 03-25-2010, 05:42 PM   #69
RatMtr
Originally Posted by AspecialZ View Post
heres my setup from tpi
AspecialZ. Can you tell me were your bought that silver instrument bezel for your gauges, I have spent days on internet looking for that bezel i have no luck.
Thanks Man for your time.
Eric AKA ratmtr my email is ebahm@amkor.com
Old 03-25-2010, 05:45 PM   #70
RatMtr
were did you get that bezel at.
Old 03-25-2010, 09:11 PM   #71
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
covans makes a bezel for the square bodies. IMO i think using the factory bezel looks the best.
staggerd86c-10 is offline   Reply With Quote
Old 03-25-2010, 09:52 PM   #72
Stitch
Location: Where I come from, it's cornbread and chicken...
digging up bones....lol...
you might want to pm captkaos on here...he's a vendor and he can get it for you...
Stitch is offline   Reply With Quote
Old 03-27-2010, 11:35 PM   #73
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
dang putfile site took a poo and a lot of my photos are gone... good news is Im looking at the unfinished cluster right now... its a dodge/chevy hybrid... funny b/c Im putting dodge brakes on my truck... anyway I'll take a good picture tomarrow. If you can imagine how the new new trucks are how the light shines through the dial and looks normal.. well I'm putting those in the factory cluster.. its got a 120mph speedo which is handy, a 1-6k tach... both fit perfectly in the large holes, and then fuel, volts and so on for the small holes... perfect. only problem is its been 1.5 years and I still havent finished... someday... I've got all the autocad layout for the placement just dont have a lot of time.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-28-2010, 04:47 PM   #74
87chevy.com
incomplete but heres the inprogress photo
Old 03-28-2010, 04:52 PM   #75
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
do you mind sharing some info on that?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
