Old 02-19-2009, 02:45 PM   #51
evenmadderdawg
Re: 200r4 vs 700r4
Forgive me if this has already been posted;
http://www.carcraft.com/techarticles...ild/index.html
Hope this helps further divide people's opinions...
evenmadderdawg is offline   Reply With Quote
Old 08-21-2009, 10:31 AM   #52
Boomerswany
Retiredoldfarttankerguy
Boomerswany's Avatar
Re: 200r4 vs 700r4
Has anyone every put one of these behind a 250 L6? I'm lazy and often work 60+ miles from home, love the sixer so I'm looking at options. What sort of extra stuff has to be moded and changed. What about shifters? I've currently got the farmers 4 speed, first so low I can pull stumps!
________________________________
Swany
Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it.
Fav - local parts shop. They ship world-wide. www.fillingstation.com
Boomerswany is offline   Reply With Quote
Old 08-21-2009, 01:32 PM   #53
70rs/ss
70rs/ss's Avatar
Re: 200r4 vs 700r4
Yeah a 700 or 200 will work behind a 6, you'll need an auto crossmember and you have to cut out the 4-speed crossmember. You may need to get a driveshaft made, as for the shifter, just get a column out of an auto truck and you can column shift the OD trans.
BTW talk about back from the depths of dead! This is a 3yr old thread!
70rs/ss is offline   Reply With Quote
Old 08-21-2009, 11:12 PM   #54
Boomerswany
Re: 200r4 vs 700r4
Yeah = old thread, but wow... Quick response for and old guy.... I mean thread... A good topic is worth of additions and info.
Thanks -
Swany
Old 08-22-2009, 12:35 AM   #55
seths69
Re: 200r4 vs 700r4
I read this same article and was suprised to learn the 200 was superior to the 700! I always thought the opposite. If I had to do it all over again, I'd go with the 2004R over the 700R4!
seths69 is offline   Reply With Quote
Old 08-31-2009, 09:20 PM   #56
ebfabman
Re: 200r4 vs 700r4
I just put a 2004r behind a stock 250 6cyl (monojet carb & hei dist) and it's a great combo. With the conveter locked it will cruise 75 very easy with the 3.73 rear and 28 inch tall tire.
ebfabman is offline   Reply With Quote
Old 09-01-2009, 06:28 PM   #57
Boomerswany
Re: 200r4 vs 700r4
I'd love to know the specifics... parts etc - drive line, shifter, converter - whatever.
Swany
Old 09-01-2009, 07:50 PM   #58
ebfabman
Re: 200r4 vs 700r4
You need a flexplate, (small tooth count) block mounted starter, (the one with one long bolt and one short bolt) a radiator with a cooler, the cooling lines, an auto shift column, the tv cable linkage, and an auto trans crossmember. My three speed standard drive shaft was the correct lenght.
Old 09-01-2009, 08:10 PM   #59
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: 200r4 vs 700r4
Due to it's smaller size, the 200R4 is the same size as the TH350 and 400 if I recall right.
texanidiot25 is offline   Reply With Quote
Old 09-01-2009, 10:05 PM   #60
nicolas72gmc
nicolas72gmc's Avatar
Re: 200r4 vs 700r4
Just subscribing. There is some valuable info here!!
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 09-01-2009, 10:27 PM   #61
woodwright
Enjoying left field
woodwright's Avatar
Re: 200r4 vs 700r4
Longhorn man mentioned Art Carr for the 200 4r. Here's his site. Great guy, very Knowledgeable. I'll probably go this route with my GMC.
CPT Transmissions
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 09-01-2009, 11:38 PM   #62
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Re: 200r4 vs 700r4
If you want a pampered junkyard 200-4R check out the 80s model square body cadillacs. I've had 3 of them 82, 84 & 88 and they all had 200-4R's and almost all of them will have a weak 307 olds or weaker 4.1 (HT4100) V8 in front of them and none of them have ever been over 70 MPH (except mine lol). The 4100 never made it over 100,000 miles without blowing a head or breaking a crank and yes I experienced both. The 307 never dies but has no balls at all so check the mileage if it is a 307. You'll have to buy a lockup kit to make 4th gear lockup. Very simple pressure valve and a plug for the tranny come provided in the kit, hook up a hot and ground and your rolling in 30 min.
68lwb292 is offline   Reply With Quote
