Old 02-19-2006, 11:44 PM   #51
Rokcrln
Rokcrln's Avatar
Re: Project Penicillin~ 68 crewcab build up!
Another day down! Today was spent building a new driver side "B" post, door strike, door strike jamb area and mounting plate. In order to make this crewcab look factory once it is completed I had to match the passenger side "B" post and related items. It is a major difference between the two sides of a burb. Their was alot of thought that went into making a third door work properly. This means a good bit of one off parts to make a fourth door work as well.
First thing I had to do was rebuild the jamb (parts came from the donor truck extd56 picked up for this project) are for the new strike plate. If you notice the strike plate on a stock drivers side is at a slite slant and the pass side is vertical. This is done so the third door hinge's can mount to a flat surface and not interfear with the front door strike. Then I made the new strike to a mirror image of the pass side and it took 3 strike plate to built this one. Next I modified a stock drivers side nut plate for the strike to bolt to. Last thing before closing things up was to build a mounting plate retainer since you will not be able to get to the nut plate like you can on a pick up.
Once all that was finished up I started on the new "B" post it self. I am using 18ga steel to fill in between the two jambs. It extendes 2" into the post and will have a second plate on the out side once the entire post is fabricated.
Hope you enjoy the pic's
Kevin
Rokcrln is offline   Reply With Quote
Old 02-19-2006, 11:49 PM   #52
Rokcrln
Rokcrln's Avatar
The rest of the pic's!
Kevin
Old 02-19-2006, 11:50 PM   #53
matthufham
i'm gonna leave all that fabrication to you, seems too complicated for me. what's sad is nobody's going to know all the engineering that took place in the buildup of this truck unless you tell them.
matthufham is offline   Reply With Quote
Old 02-19-2006, 11:59 PM   #54
Rokcrln
Rokcrln's Avatar
If nobody knows what was done, then my job was done correctly! The best part will be when that guy come up to you and says my dad had one just like this!!
Kevin
Old 02-20-2006, 12:11 AM   #55
extd56
extd56's Avatar
I hope you are taking good notes for when I need replacement parts or you want to convert a burb to a 4 door.
extd56 is offline   Reply With Quote
Old 02-20-2006, 12:20 AM   #56
1967k30
1967k30's Avatar
How much $$$$ are involved in the job? I'd like a 4door as well,but I'd really just like to have an ex-cab.Any idea what you would charge to do one? Thanks
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 02-20-2006, 12:43 AM   #57
Rokcrln
Rokcrln's Avatar
In simple numbers~ ALOT!
I won't know untill this one is done. Then I am thinking a 4door Tahoe would be slick!
Kevin
Old 02-20-2006, 11:22 AM   #58
1967k30
1967k30's Avatar
Too bad you are so far away.I'd have you rebuild the floor,rockers,cab corners,ect on my 67'. I've never seen someone work so fast on a vehicle.
Old 02-20-2006, 12:20 PM   #59
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Your super "leet" skills make me want to throw up on myself.......
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 02-20-2006, 12:22 PM   #60
ClemsonChevy
I can barely tie my shoes in comparison to this crap......blah.......you make me sick! Maybe one day I can be a tenth that good.
95 2500 350 w/ 3.73
Old 02-20-2006, 12:25 PM   #61
Rokcrln
Rokcrln's Avatar
Heck I would be happy if someday I am as good as you all say I am! But thanks for the good words... Well the shop should be warm by now so time to get cracking!
Kevin
Old 02-20-2006, 03:55 PM   #62
Rokcrln
Rokcrln's Avatar
Lunch break! I will start the rocker build after I eat a bite or two! Once the rocker is finished then I can skin the out side of the "B" post with its final layer and it will be time to start fab'n up a fourth door!
Kevin
Old 02-20-2006, 04:11 PM   #63
hotrodhomi
hotrodhomi's Avatar
I like your project Kevin. I can't wait to see that thing put together.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 02-20-2006, 07:15 PM   #64
Long Roof
Old School, New Style
Long Roof's Avatar
You are my hero. Keep up the great work.
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 02-20-2006, 07:20 PM   #65
Excellent. Love to watch your builds.
Palf70Step is online now   Reply With Quote
Old 02-20-2006, 09:40 PM   #66
Rokcrln
Rokcrln's Avatar
Well it is almost a swinger!! I jot the rocker built an dscrewed in place untill the door is complete and working. I then cut down a drivers side truck door as my donor for the fourth door. I cut out the un-needed section and slid them together and just tacked the inside and cleco'd the outer skin. I modified the lower hinge mount on the door to recieve the lower hinge. I still need to section the upper hinge mount and lower it a few inches. That will be another day!! Back to work tomarow so progress will slow a bit on the truck since I only get 1 or 2 hours in the evening to work on it during the week.
Kevin
Old 02-20-2006, 09:42 PM   #67
Rokcrln
Rokcrln's Avatar
A few more!
Kevin
Old 02-20-2006, 10:22 PM   #68
matthufham
DONE ALREADY??? wow close though. that's just amazing and i can't find ANY flaws since you seem to be a quick thinker, and a good engineer. looks great!
Old 02-20-2006, 11:49 PM   #69
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
This is impressive.
Nice work Kevin!
Mike
onetoncrewcab is offline   Reply With Quote
Old 02-21-2006, 11:16 AM   #70
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
You are a Freak'n Magician!
Hot Damn! that looks good. I can't believe how fast you work and how good it looks. Amazing. Freak'n Amazing.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 02-21-2006, 09:49 PM   #71
Rokcrln
Rokcrln's Avatar
It is now infact a four door crew cab!!!!
After lowering the top hinge and doing some clearance adjustments it now has a swing fourth door
Their is still alot of work to be done to get this door and jamb 100% comlpete but I feel the hard part is over.
Kevin
Old 02-21-2006, 10:15 PM   #72
71chevytruckguy
71chevytruckguy's Avatar
dang. u've got some amazing body work skills. wish i was half as good as that.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 02-21-2006, 10:17 PM   #73
matthufham
when do you want your 1st place trophy? i thought you had very little time to work during the week.
Old 02-22-2006, 05:54 AM   #74
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
wow!!!....
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 02-22-2006, 06:25 AM   #75
67shortie
Green club
67shortie's Avatar
WOW, nice work and quick as well...
I can't wait to see this done, going to be a one of a kind that's for sure.
And to think it took me 3 days to put 2 rockers on my truck, sheesh
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
