Old 05-04-2006, 03:03 PM   #51
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
Re: Are hand throttles rare?
Tonight I'll try to get pics of the handle and handle shaft. My cable is not attatched, so I won't be able to get any pics of the OEM cable fastener, but would appreciate someone else doing so.
My father-in-law was telling me that he has several of this type of controller on the dash of his airplane. He said that the knobs have buttons in the middle. Push the button to release pressure on the threads and make course adjustments or turn to make fine adjustments.
Aircraft maybe another source for repair parts or non-OEM replacements.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-04-2006, 03:25 PM   #52
Woody
My Dad had one on his '67 C-10 (6 cyc/3 on the Tree) he bought new in '67. I always thought it was neat. His truck didn't have a PTO or anything else special about it, just a plain jane '67 long fleetside wood bed 6 cyc/3 speed. No radio, no chrome, standard mirrors, with a hand throttle.
Woody is offline   Reply With Quote
Old 05-05-2006, 10:29 AM   #53
flatbedchev
flatbedchev's Avatar
I took mine out of the truck and sold it. It was like having redneck cruise control. Kinda cool, but I really didn't need it
flatbedchev is offline   Reply With Quote
Old 04-15-2007, 07:41 PM   #54
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Originally Posted by Bob Moore View Post
Most of the hand throttle cables I come accross now (35 years old approx) are broken - do not operate when turned. The mechanism is a worm gear but the cable has become detached internally.
Has anyone had any luck repairing these?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 04-15-2007, 07:45 PM   #55
MT1972cheyenne
MT1972cheyenne's Avatar
I had a 72 k-10 cheyenne that had one. I don't know why either. It was on the glove box tag. It did come off of a farm, but had no PTO. It was an automatic too.
MT1972cheyenne is offline   Reply With Quote
Old 04-16-2007, 11:51 AM   #56
bucket
bucket's Avatar
If you read earlier posts in the thread, i have repaired mine.
bucket is offline   Reply With Quote
Old 04-16-2007, 02:57 PM   #57
boundstaffpress
I tried to repair mine like bucket said, but didn't have any luck keeping the "boss" on the cable after I got it small enought to fit into the handle shaft. I've since moved onto bigget things, but though the best way would be to tack weld a steel BB onto the end of the bicycle cable. Just haven't gotten it done yet.
Justin
Old 04-16-2007, 04:41 PM   #58
VA_short_67
VA_short_67's Avatar
Had one on My 72 Blazer
VA_short_67 is offline   Reply With Quote
Old 04-16-2007, 05:56 PM   #59
byrdman
Here's some pics of my '71 with the "manual throttle" option.
The middle pic is a little blury, but it is the actual hand throttle.
The cable from the dash goes down and connects to the straight verticle piece above the throttle peddle.
'72 Blazer, A/C, tach, tilt. Not on the road at this time
'87 v30 Custom Deluxe, standard cab, SRW, Utility bed
'86 c10 Silverado longbed (for now)
'19 ecsb, 2500, 4x4
'15 Subaru Legacy - commuter
byrdman is offline   Reply With Quote
Old 04-16-2007, 08:10 PM   #60
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
To help with the sticky cable,remove it from the vehicle,clean it with WD or something similar,then just chuck it in the oil drain pan when full.Leave it to soak up oil and lube itself for a few days.I did it with a heater cable and it has lasted several years with no problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-16-2007, 09:00 PM   #61
badpeanut
badpeanut's Avatar
byrdman, does your "straight verticle piece" look like the loose bracket on the floor of my truck? Where does it mount?
bucket, mine turns okay under no load, but pops out of place when in use. Would a modified bicycle shift cable repair as you described fix this or do I have problems with the "drive" portion?
'70 GMC LWB trailer
Old 04-16-2007, 10:50 PM   #62
byrdman
I believe this circled part here is where my cable is attached. But, my cable/handle is seized-up ,so I can not say for sure that this is the same cable (as some other cable may terminate here?).
'19 ecsb, 2500, 4x4
Old 04-16-2007, 10:58 PM   #63
Aubigmac
my 72 has one but it is mounted on the left side below the headlight switch. Never has worked but if it is this unique I might have to try getting i back in when I rebuild the truck.
Does everyone elses label that says Throttle look like it's added after the fact at the dealer?
Aubigmac is offline   Reply With Quote
Old 04-16-2007, 10:59 PM   #64
bucket
bucket's Avatar
if i remember right, i think i also enlarged the access hole in the side of the shaft by drilling it out so i could insert the boss.
Old 04-22-2007, 11:41 PM   #65
69TowRig
It is just a nameplate that sets over the threaded part of that knob assembly and gets sandwiched in there when the knob is mounted to the dash bezel.
I think the one I just bought might have that same "popping" issue described earlier. I really won't be able to tell if it will work right until I install it.
Now I have a question: Does anyone know where the cable bracket inside the cab goes? My setup came with another bracket and I haven't seen a picture of it installed anywhere.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 04-23-2007, 12:20 AM   #66
bucket
bucket's Avatar
mine "pops" out of place if i don't apply pressure to the gas pedal while turning the knob. once in place, it does not slip back, however. i'm not sure the new cable would help. you might check to see that the outer housing that the knob threads into has not split apart.
Old 11-28-2007, 04:18 PM   #67
~Shep~
~Shep~'s Avatar
Would anyone on here be willing to sell or know someone who would sell their throttle name plate? Mine has long since been lost, and I took it off so nothing would happen to it...go figure.
1972 Cheyenne K20
Cool Options Include Manual Throttle - Tilt - Dual Gas Tanks - Sliding Rear Glass
...they just forgot to put a super emblem on at the factory!
~Shep~ is offline   Reply With Quote
Old 11-28-2007, 04:43 PM   #68
jkaylor68gmc
jkaylor68gmc's Avatar
I believe uncommon and rare are the same thing. If it is uncommon that makes it rare.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 11-28-2007, 05:42 PM   #69
Husker
Husker's Avatar
My 70 GMC K15 has one, bought it from a farmer/rancher, It works.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
