06-15-2006, 10:19 PM | #51 |
I'm back with 2nd truck!
Re: major problems, major fixes (bit rambly)
Sounds much better. Idle is a bit high. Get a tach on there to get it back down. You're getting it better off than where it was.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
06-15-2006, 11:11 PM | #52 |
7000 #'s of american IRON
it was on high idle in the video
06-15-2006, 11:26 PM | #53 |
also, whats the cheapest tach made that i can mount on my dash or something? I'm really not used to not having a tach...i like knowing how/where my engine is running.
06-15-2006, 11:48 PM | #54 |
You can get a cheap small dial one from Summit or Jeg's cheap. Also might check your local store for a cheap one.
06-16-2006, 12:51 AM | #55 |
thanks, found one for 36, see if i can find one for cheaper. We might have a 5" monster tach in the boxes, that would just be for testing..no way i could fit a 5" tachometer in my truck..anywhere.
Do i have it advanced far enough, or should i move it some more and put it there on the edge of predetonation? Last edited by magnethead; 06-16-2006 at 12:55 AM. |
06-16-2006, 12:54 AM | #56 |
I did on my column. Mine had a bracket with a curved mount. I used a hose clamp around the column and mounted it on there behind the shifter and saw between the fuel gauge and the speedo.
06-16-2006, 01:19 AM | #57 | |
(granted it'd help if the wheel wasn't turned) Last edited by magnethead; 06-16-2006 at 02:05 AM. |
06-16-2006, 04:01 AM | #58 |
question: Since my rotor and cap checked out ok (cap was clear, rotor had minute buildup), can i just get autolite platinums and accell wires with a MSD HEI coil thats up in the 42-50Kv range? How many volts is the stock coil?
06-16-2006, 06:30 PM | #59 |
well I was checking if my vac advance was working, and the engine spat out black smoke for a second. After some deliberation with mylilbowtie, i found that everything was fine. And yes, the vacuum advance does work, but it sounds like it's sticking at the very high end- that or i'm simply depleting the coil. I found the tach from our racecar, a 4 wire 4" autometer pro comp II unit. I'll investigate how it connects and i'll see if i can get a RPM reading off my engine (and maybe perm. fasten it under my column or something). The photo's aren't great, the shutter's acting up.
06-16-2006, 09:00 PM | #60 |
Right turn Clyde
Is there a model number on the tach? It should be one hot one ground one that hooks to the distributor and one light.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
06-16-2006, 11:10 PM | #61 |
i talked with the guys in chat about it, it has a yellow lead and no green lead, which means it might be for magneto only?
the only thing i could see that could be any ID is "D-1028". Last edited by magnethead; 06-16-2006 at 11:11 PM. |
06-17-2006, 01:07 PM | #62 |
just talked to my dad some...here's a long list of things that need replacing...It doesn't even contain the multiple wants! (and it's probably not complete)
5 roof clearence light lenses (busted) 9-14 clearence light bulbs (burned out) Autolite Plugs (replace existing ones) 22.43 Accel wires (replace existing ones) 32.47 fiber glass hood kit (bent hood, sticky hinge) ~450.00 + ~28.00 2 front fender (body cancer) ~192.00 driver side rocker panel (body cancer) ~22.00 carburetor, intake, cam (Edelbrock Performer Cam kit) ~635.00 Dead Pedal Floor repair (body Cancer) Cab sanded and Primered (dire need) PAINT! (dire need) Last edited by magnethead; 06-17-2006 at 01:31 PM. |
