Old 11-17-2006, 12:29 AM   #51
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
Originally Posted by xlcooplx View Post
what setup are you using on the front? i see you're an ART dealer so i didnt know if it was a kit or if you had pieced the kit together..looks good though man!
Like Kevin said, the frontend is a Dropmember. There are a couple of different versions... the one above, and the DropmemberC4 (lets you bolt up C4 Corvette suspension). They are both bolt-in and make the frame-rails the lowest point on the truck. There are a couple more threads about them here in the suspension forum.
The Dropmember is designed to use Air Ride's Strong arms, but will work with other brand tubular arms and also stock arms... the lower stock arms from 63-72 will need a little bit of clearance work to mount up without interfrence.
Yeah, if only I had 25 hrs in a day!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-20-2006, 11:14 PM   #52
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
Got some more done on the 66... it is now a running driver. There is still some more work to get done... plumb the air and install the valves, (Air Ride Tech. Big Red Valves) install the compressor (Oasis... one bad pump!), install the tanks, and install the three Optima batteries.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-20-2006, 11:18 PM   #53
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
A few more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-20-2006, 11:19 PM   #54
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
One more of the exhaust.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-20-2006, 11:26 PM   #55
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Dino63's 66SWB
That truck looks great.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 11-21-2006, 12:18 AM   #56
Shane
Shane's Avatar
Re: Dino63's 66SWB
Da-yum! That thing is low ... and SWEET!
Shane is offline   Reply With Quote
Old 11-21-2006, 12:43 AM   #57
powell72
powell72's Avatar
Re: Dino63's 66SWB
I love it, it looks like a street sweeper in the head on shot.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-21-2006, 03:25 AM   #58
jimmydean
jimmydean's Avatar
Re: Dino63's 66SWB
PB, amazing as always! I love that body style too. I looked long and hard for a '66 before I gave up and bought my '69.
I can't wait to run a drop member in my truck.
jimmydean is offline   Reply With Quote
Old 11-21-2006, 07:19 AM   #59
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Dino63's 66SWB
that is awesome!! that is exactly what look i am going for!!!
gostranger is offline   Reply With Quote
Old 11-21-2006, 03:59 PM   #60
xlcooplx
xlcooplx's Avatar
Re: Dino63's 66SWB
Not to whore up the thread, but will the C4 suspension bolt up to a 62? I know that it uses the torsion bar front end so i didnt know if it would or wouldnt. Thanks again for the help man!
79 GMC C10 "Heavy Half"
90 GMC K5 Jimmy
xlcooplx is offline   Reply With Quote
Old 11-21-2006, 07:15 PM   #61
kylejamers
Re: Dino63's 66SWB
the truck is super sick
kylejamers is offline   Reply With Quote
Old 11-22-2006, 12:07 AM   #62
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
I love these trucks too... I have a 66 SWB big window and a 66 Suburban that will one day recieve the royal treatment. The sub will be going under the knife shortly (losing a lot of its sheetmetal and some of its wheelbase).
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-22-2006, 12:09 AM   #63
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
I am pretty sure the frame-rails on the torsion bar frames are a bit narrower. I have heard of 2wd crossmembers with coils being swapped over... if that's the case I don't know why not. I have not personally done the conversion so am unable to confirm it will work. I have a 61 SWB out in the yard and can check some measurements... one of these days!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-22-2006, 12:40 AM   #64
thekid54
Re: Dino63's 66SWB
Damn! That thing is on the ground! That's what I'm going for on my '62.
I have a couple of questions for you if you don't mind:
1. What are you using for hood hinges, because is doesn't look like you could run inner fenders?
2. How much did you have to cut the rear of the cab to clear the drive shaft?
thekid54 is offline   Reply With Quote
Old 11-22-2006, 12:55 AM   #65
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
As for the hood hinges... they will be just like they are on Dino's panel (http://67-72chevytrucks.com/vboard/s...d.php?t=200506) you can find the pics there.
I had to cut ZERO inches out of the back of the cab! However I did have to cut the stock trans tunnel out where it meets the firewall for clearance at the bellhousing.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-22-2006, 01:21 AM   #66
thekid54
Re: Dino63's 66SWB
Ahhhh, that's pretty slick! You do some awesome work! Thanks for the quick response. I'm assuming you didn't have to cut the rear of the cab because your Dropmember keeps the engine pretty low in the truck? I Z'd my frame 3" so I'm thinking I'll have to cut my cab...a lot! I wish I had seen your Dropmember before I Z'd my frame, but there's no turning back now!
Old 11-25-2006, 06:05 PM   #67
Grunion
Grunion's Avatar
Re: Dino63's 66SWB
looks cool dino
Grunion is offline   Reply With Quote
Old 11-25-2006, 06:15 PM   #68
culookn
culookn's Avatar
Re: Dino63's 66SWB
pimp! what is the rear out of b/c i disc brake setup?
culookn is offline   Reply With Quote
Old 11-26-2006, 02:15 AM   #69
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
2001 S-10 4WD Blazer.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-26-2006, 09:00 AM   #70
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Dino63's 66SWB
Simply Beautiful, I want mine done
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-26-2006, 10:16 PM   #71
leftcoast66
leftcoast66's Avatar
Re: Dino63's 66SWB
Looks awesome, just curious what headers are those, I can't find any which fit w/ my truck layed out.
leftcoast66 is offline   Reply With Quote
Old 11-27-2006, 12:52 AM   #72
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
They're the "shorty" style headers used on chevelles, camaros, and novas... I think a few guys have had some clearance issues running them with a stock motor mount... the driver's side doesn't clear??? They work perfectly with a Dropmember .
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-27-2006, 02:18 AM   #73
leftcoast66
Re: Dino63's 66SWB
Thanks, I like the look a lot. I'm thinking this summer I'm going to build something similar to the dropmember, don't have the money to buy one. I love the idea and u've got amazing work
Old 12-02-2006, 12:56 AM   #74
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
Here's some exhaust pics.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 12-02-2006, 12:57 AM   #75
PBFAB.COM
PBFAB.COM's Avatar
Re: Dino63's 66SWB
a few more...
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
