Old 07-26-2007, 08:16 AM   #51
Jim85IROC
Jim85IROC's Avatar
Re: Progress on 87 K30 project
Wow, this was a fun thread to read. My truck is an 87 1 ton with the 454/th400, and I put a 4" skyjacker lift in with 33" tires on 16.5" wheels. It's really fun watching you make such a similar truck look (and run) so good!
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 07-26-2007, 10:55 AM   #52
Roper
Originally Posted by Dean View Post
I measured from the middle of the front lower fender lip to the center of the hub and get 29". I'm not sure what that is telling me. This is a 87 K30 with a Skyjacker lift. The front had an additional leaf added from Skyjacker for the weight of the big block.
Cut your front wheels, example like your making a tight turn. Get out and look at how close your 33" tires are now to the fender.
With 35" tires, spring compression and your wheels turned in any direction except straight im thinking your going to wreck your fenders.
Roper is offline   Reply With Quote
Old 07-26-2007, 11:09 AM   #53
Jim85IROC
Jim85IROC's Avatar
Sometimes I still get a fender rub with my 33s at full lock.
454
TH400
My Sounddomain Page
Old 07-26-2007, 11:54 AM   #54
Dean
Dean's Avatar
I've had the 35" BFG from one my 71 K20s on the K30 and no issues or rubbing. I don't think I'd want to do serious off roading with any of them but I don't do that anyway. I do have the extra Skyjacker spring for the front for the big block weight which helps as well. The K30 is higher than both my 71 and 72 K20s for some reason.
Dean is offline   Reply With Quote
Old 07-26-2007, 01:36 PM   #55
Jim85IROC
Jim85IROC's Avatar
Do you have a part number for that extra spring? My front end sits a little low.
454
TH400
My Sounddomain Page
Old 07-26-2007, 03:58 PM   #56
Roper
Your wheels dont have to be cut full lock for your wheels to hit the fender.
My truck has the HD Superlift 4" set up with the extra leaf in front.
When my wheels are straight it looks like I have lots of room in the wheel wells to clear bigger tires but I know I dont because I do drive off road.
Old 07-26-2007, 04:06 PM   #57
Roper
You want your front end to be a little lower than the back. See those trucks have different wheel well opening in the front than they do in the back. If your truck sets absolute level then its going to look like its driving up hill all the time.
Example when I put the 4" suspension kit under my truck the distance from the top of my front tire to the top of the wheel well opening was something like 12" but the same distance on top of my rear tires was about 10.5", but my truck was perfectly level.
I actually had to add 1.5" lift blocks to my rear suspension to give my truck the right stance. Now it sits with the hind end up a litttle bit but the truck looks level.
Old 07-27-2007, 09:39 AM   #58
grinch4om
dang its hot
grinch4om's Avatar
for vapor lock, do you have a return fuel system? never seen one vapor lock
grinch4om is offline   Reply With Quote
Old 10-16-2007, 11:50 PM   #59
abebummy26
abebummy26's Avatar
This truck is sweet perfect stance cherry body and the most bad @$$ gas motor ever.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 02-09-2008, 09:34 AM   #60
abebummy26
abebummy26's Avatar
Nevermind did some digging and found the answer to my question.
-Lincoln
Old 02-09-2008, 11:44 AM   #61
andresco50
andresco50's Avatar
Woooow congrats a 572
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 02-09-2008, 11:53 PM   #62
oldwagon
oldwagon's Avatar
Luv the super block. Even better in that truck!!!!!
oldwagon is offline   Reply With Quote
Old 02-10-2008, 06:43 AM   #63
87Bob
Hey Dean let me know what parts you'll have for sale! I have a long shopping list for my 85.
87Bob is offline   Reply With Quote
