Old 01-18-2007, 12:51 AM   #51
bigjimzlll
bigjimzlll's Avatar
Re: Can we talk about 350 ci power
heres an in car video
Click here to watch in-caragainst-cop-car
I'll post some pics later
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-18-2007, 12:52 AM   #52
Billla
Billla's Avatar
Originally Posted by bigjimzlll View Post
I personally don't like using vacuum advance. It was invented to help burn exhaust gases at just off throttle(emissions) There is no performance to be gained.
Why "don't like" better driveability and improved cruise fuel economy? It was added to increase ignition advance in conditions where the engine could tolerate it...EXACTLY like the modern computer-controlled engines like the LS series. It's not an emissions control device...although better combustion does reduce emissions.
Billla is offline   Reply With Quote
Old 01-18-2007, 11:17 AM   #53
bigjimzlll
bigjimzlll's Avatar
I think of as a generic bandaid. A one size fits all fix to low octane/low compression EPA requirements. Anytime you "hop" up an engine, and you use vacuum advance, it should be tuned to respond to the engine mods.
I also subscribe to using full manifold vacuum instead of ported vacuum for the vacuum advance, but this is on a modified engine with a larger cam. With a larger cam you have less vacuum at idle and by using manifold vacuum it can help with idle quality and throttle response.
Vacuum advance can be a good thing if properly tuned to the exact combo. A blanket statement that it is the only way to go..untuned..is not correct. As always this is just my opinion. Learned through my experiences. And god knows I don't know everything.
Anderson,CA
