Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 07-03-2007, 11:42 AM   #51
1969k10stepside
Re: My Build Begins!
2 and 1/2 ton Rockwells That's gonna be one bad a$$ blazer,Andy.I cant wait to see the k5 once you have the drivetrain under it.I dont think there is any other k5 in the hoosier state with 2 & 1/2 ton Rockwells and a tire above 44
1969k10stepside is offline   Reply With Quote
Old 07-03-2007, 11:45 AM   #52
Yukon Jack
Post Whore
Yukon Jack's Avatar
Originally Posted by tallhoedude View Post
AS FAR AS THE 1TON SETUP.ITS MOST LIKELY GETTING TOSSED INFAVOR OF ROCKWELL 2 1/2 TON MILITARY AXLES AND 46 OR 49" MEATS.
Schweeet! Can't wait to watch that stage of your project!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-03-2007, 12:04 PM   #53
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
thanks for the compliments and encouragement guys.but be patient it may be a little slow going.
UNLESS....if i can sell the tahoe then most of that $$ i can put into the k5.
ive got my 5.3 wiring harness about 80% complete(removed un-needed wiring and sensors,rerouted)cant do much more with it untill the engine is sitting between the framerails.
i am researching and experimenting with a home-fabbed wheel brake setup for the rockwells so it will be somewhat streetable.pinion brakes are for sure cheaper to fab and install...im just not sure how safe they are on the street.
i am also working out some suspension ideas:4 link all around would be cool,but would cost a lot of $$ for the front to ride and drive the way i want.i think im going with leaf springs up front and a triangulated 4 link in the rear.i just think the rear will be easier fab work,its not like im building a rock crawler needing massive flex so a rear 4 link should be good enough.
well as i get more pics and ideas ill let you all know.
this board has been a great resource for great people and great info...
thanks to all..........
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 07-03-2007, 10:38 PM   #54
badass72
badass72's Avatar
your doing a hell of job keep it up
badass72 is offline   Reply With Quote
Old 07-05-2007, 05:15 AM   #55
krue
Designated A-hole!
krue's Avatar
Can't wait to see it on the ground! Or rather in the air!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-21-2007, 08:10 AM   #56
tallhoedude
Re: My Build Begins!*updated 8-21-2007
update photos:
found lots of ugly damage on the right bedside.cut parts from a shortbed i had lying around to fix it.
MY BUILD THREAD:
Old 08-21-2007, 08:11 AM   #57
tallhoedude
one more of bed:
MY BUILD THREAD:
Old 08-21-2007, 08:12 AM   #58
tallhoedude
heres the diy4x b52 kit.this is very nice stuff.
MY BUILD THREAD:
Old 08-21-2007, 08:12 AM   #59
tallhoedude
my s&w 10point cage kit:
MY BUILD THREAD:
Old 08-21-2007, 08:13 AM   #60
tallhoedude
heres the rear axle,just before disassembly...if you dont have a crane or engine hoist,dont plan on thionking of moving these....heavy sob's
MY BUILD THREAD:
Old 08-21-2007, 08:14 AM   #61
tallhoedude
heres the front axle after teardown:
MY BUILD THREAD:
Old 08-21-2007, 08:15 AM   #62
tallhoedude
heres the stock rockwell shafts compared to dana 60 1ton axle.
MY BUILD THREAD:
Old 08-21-2007, 08:46 AM   #63
Luba
Luba's Avatar
What do you think about that cage?
Luba is offline   Reply With Quote
Old 08-21-2007, 08:50 AM   #64
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Wow...
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 08-21-2007, 09:24 AM   #65
vtblazer
vtblazer's Avatar
Good to see your moving ahead with this build.
Doing anything to 'stay light'?
No really, you think you'll be able to be under 7K lbs in the end?
vtblazer is offline   Reply With Quote
Old 08-21-2007, 09:32 AM   #66
tallhoedude
So Far In Mock Up The Cage Looks Nice.plus For $250.00 I Couldnt Pass It Up.
Does Not Planning To Run The Top On Count As Trying To Be Light??
Future Plans Are Including The 16k Winch.cause If This Pig Gets Stuck............its Gonna Be Stuck!!!!!
Interior Will Be Sparse,but Extra Addons Will Still Outweight
The Stock Interior Stuff..
MY BUILD THREAD:
Old 08-21-2007, 09:44 AM   #67
Thealien
Thealien's Avatar
Excellant work, Look forward to progress!!
Old 08-21-2007, 10:39 AM   #68
Yukon Jack
Post Whore
Yukon Jack's Avatar
I'm digging the tires that are on the rockwell axle. That's quite a bedside repair. Can't wait to see more progress!
Old 08-21-2007, 10:59 AM   #69
tallhoedude
the tires on the rockwell axle in the photos are the stockers..about 42" tall.heavy as hell...but will be good to use as mockups to get ready for the 49's
MY BUILD THREAD:
Old 08-21-2007, 11:52 AM   #70
Ludington1
Wow... Great work on the Blazer, and those Rockwells are gonna be awesome under there!!!
Now that your bodywork skills are getting so good, just let me know when you're ready and I will send up one of the old Dodges... maybe not 4x4 but at least the yellow one has a 4.10 Dana 60... does that count?
Later,
D
AKA "Little Brother"
Ludington1 is offline   Reply With Quote
Old 08-21-2007, 12:10 PM   #71
tallhoedude
yeah,build me a shop and the bodywork is free!!!!!!!!!!!!
i will have to be careful.....dont want the house to burst into flames when i pull a CHRYSLER/DODGE into the shop...
MY BUILD THREAD:
Old 08-21-2007, 06:08 PM   #72
jamie72
jamie72's Avatar
i will have to be careful.....dont want the house to burst into flames when i pull a CHRYSLER/DODGE into the shop...[/QUOTE]
lol... hey great body work... you can just imagine what i thought(and said) when i seen the first pic of your tub..lol
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-22-2007, 08:31 AM   #73
tallhoedude
thanks all for the encouragement.
if you didnt catch it. the guy with the old chryslers/dodges is my little brother.musta got dropped a lot when he was young
MY BUILD THREAD:
Old 08-22-2007, 10:23 AM   #74
Big J
Its lookin' like a Blazer!
Big J's Avatar
Great Work Keep the pics comin'.....
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 09-05-2007, 09:18 AM   #75
tallhoedude
Re: My Build Begins!update 09-03-07
got some more work done on the diffs,got centers cut out,cleaned,new high clearance and strength skids indsalled.axles painted,begin assembly next week.i am narrowing frt axle,wilkl have more pics.
MY BUILD THREAD:
