Old 12-28-2008, 01:21 AM   #51
vern350
like a rock
vern350's Avatar
Re: 2wd to 4x4 build
I don't know how long this project has been put off, but its time to get back at it. My father and myself will be using his 86 scottsdale body on this truck, as his is getting tough in some areas and needs some attention. The mint cab that I found will be kept for something nicer than a 4x4 that will see winter. Rolled the frame back into the shop part of the garage tonight. Progess will begin shortly. Pictures to follow.
vern350 is offline   Reply With Quote
Old 12-28-2008, 04:19 AM   #52
ChaseDale3and8
ChaseDale3and8's Avatar
Looking forward to seeing your progress! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 12-28-2008, 07:00 PM   #53
84 400
Sb 400 club
84 400's Avatar
cool to see this being brought back. So what happened with the 82? Also since your dad is donating his 86 what square is replacing his or is he gonna use this one?
Should look good with the 6 inch lift.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-28-2008, 08:13 PM   #54
vern350
like a rock
vern350's Avatar
The 82 is still kicking around for parts. My dad will be using an 87 chevy pickup we just got on the road. Dads truck need some attention and the 305/700R4/3.08 is getting tired with around 330,000 kms. We have been using it for all our towing.... so its only fair it gets some freshing up. Tucked the cab away in the corner for now, the garage needs major cleaning and organizing.
Old 01-04-2009, 11:27 PM   #55
vern350
like a rock
vern350's Avatar
Both front and rear axles were dropped for some cleaning up/paint and to make way for 6" lift. Burned up the rubber seal on the top ball joint on the drivers side while removing the stock steering arm. Stock steering arm is to be replaced with one that has correction for lift. So new ball joints for drivers side. Hopefully have the diffs back under the truck early this up coming week with new oil, seals, and brakes installed. U-bolts are to be ready for pickup monday afternoon. Had to get some made for 3/4 ton axles.
Old 01-04-2009, 11:28 PM   #56
vern350
like a rock
vern350's Avatar
more
Old 01-04-2009, 11:50 PM   #57
62 short step
62 short step's Avatar
Looking good!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-05-2009, 06:23 PM   #58
vern350
like a rock
vern350's Avatar
Dad went to the states today to get some parts;
front calipers
pads
steering damper
rear wheel cylinders
brake lines for the rear
diff cover gaskets
pinion seals
positraction differential fluid additive
U bolts were also ready for pickup. So hopefully get things back together shortly.
Old 01-05-2009, 10:45 PM   #59
vern350
like a rock
vern350's Avatar
Got the rear diff in tonight, still needs fluid.
Old 01-06-2009, 12:24 AM   #60
84 400
Sb 400 club
84 400's Avatar
looks good.
1985 C10 LWB Sold
Old 01-12-2009, 09:18 PM   #61
vern350
like a rock
vern350's Avatar
Front axle is bolted in, rear brakes are installed. Installation of front brakes, hubs, axle shafts, etc is next. Hopefully have the truck rolling shortly, to free the hoist up. Going to need to pick out some rims and tires for this beast shorty. I need to order longer brake lines, shock boots, and a front sway bar drop. Off Road Design has a nice quick disconnect one. I think down the road I'll replace the 4" blocks with ORD 4" shackle flip.
Old 01-22-2009, 10:55 PM   #62
vern350
like a rock
vern350's Avatar
Well its rolling again. Only thing not done on the front axle is the calipers and pads, which will be put on when its ready to hit the road. Came across a small problem with the rear hanger not being a 4x4 version, but thanks to softballrnd27 we'll on our merry way again. Heres a picture of the 2wd hanger currently on the truck and how much shorter it is then a 4x4 one.
Old 02-19-2009, 09:14 PM   #63
vern350
like a rock
vern350's Avatar
Update: dad started tearing apart his own truck! Getting ready to do some minor rust repair on his cab and to insert a 4x4 transmission hump. Decided to use this truck for the body donor because its at the state where the rust needs attention before it gets worse. Also added a picture of the helper.
Old 02-20-2009, 04:22 AM   #64
84 400
Sb 400 club
84 400's Avatar
hahah your dads helper looks alot like mine........
1985 C10 LWB Sold
Old 04-20-2009, 11:44 PM   #65
vern350
like a rock
vern350's Avatar
Not much done to the truck since the 4 week break over the holidays, been busy with school and dad with work. Had a chance this pass weekend to do some work in the garage, got a box on the truck just temporary while fixing up another 87 pickup. Got an idea how it will sit with the lift minus the front of the rear 4x4 hangers and some bigger tires.
Old 04-21-2009, 08:06 PM   #66
Dusty4x4
Dusty4x4's Avatar
looking good
1980 1/2 ton shortbed project
1978 grand prix project
Never stop trying...
Dusty4x4 is offline   Reply With Quote
Old 06-21-2009, 09:25 PM   #67
vern350
like a rock
vern350's Avatar
Finally found some rims for the truck, some old 16.5x9.75 slots. I will be getting 35" BFG all terrain for them. Very limited choice in tires, BFG may be the only company to make a bigger 16.5 tire. Discount tire said they can still get them. I wanted to make sure I could get a decent tire before getting the rims.
Old 06-21-2009, 09:33 PM   #68
vern350
like a rock
vern350's Avatar
Double post, please delete.
Old 11-25-2009, 05:36 PM   #69
joe231
joe231's Avatar
what's going on with this bad-boy??
updates?
CHEVY ONLY
Old 12-01-2009, 01:03 AM   #70
vern350
like a rock
vern350's Avatar
Just waiting on time for myself and dad to get to time together, and I need parts like brake lines, tires, etc. Just a matter of putting it together. Hopefully some updates over the holidays.
Old 12-03-2010, 01:23 PM   #71
Big bad Green
Big bad Green's Avatar
SO wait your not using the org frame from the GMc?
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
